SqWADoosh's 85 Runner Build Thread
Started by SqWADoosh, December 03, 2014, 12:07:54 PM
SqWADoosh
Quote from: SqWADoosh on July 28, 2016, 06:29:08 AM
Got my new axle with new bearing, collar, and seals all pressed in. Just need to put it back in the housing, fill her up with fresh fluid, refill and bleed my brakes and then I should be back to jammin.  :driving:
Quote from: mudmaster on July 28, 2016, 07:21:20 AM
Did you check the other side?
Any damage or obvious wear near the splines on the broken one?
SqWADoosh
Nope, just sheared off right at the c-clip.
SqWADoosh
Well she is back on her feet. Ended up having to replace both wheel cylinders, the right length of brake line from the "T" on the rear axle and a whole lot of brake fluid. Top tip don't bleed drum brakes without the covers on. Otherwise your wheel cylinders explode from pushing the shoes out too far. Live and let learn  :hammer:
Quote from: SqWADoosh on July 29, 2016, 11:04:56 PM
Did that once myself.
zippo
You can rebuild wheel cylinders. Clean them and put them back together.
If you see it, its for sale.
BigBluePile
Lolz....
Sent from my 0PJA2 using Tapatalk
'86 4Runner SR5 TRD 5VZ-FE
...slightly modified from OEM...
Quote from: zippo on July 30, 2016, 10:47:44 AM
Not when the piston rust welds to the cylinder.................
:twocents:
SqWADoosh
Going to hit Liberty this weekend with another club. Going to learn the trail system up there before taking people up there.  :driving:
SqWADoosh
I replaced bestgen's broken tail light today. You are welcome buddy.  :therethere:
For anyone who has a mini and blows out any kind of light lense I highly recommend the Taiwanese company "Depo" that sells on Amazon. OE quality replacements for a fraction of the cost. This is the second piece I've bought from them and I'm very happy with both. Can not tell the difference holding it up to the OE lense.
SqWADoosh
#1392
52. ARB 63 QT Fridge installed
Long time no update. Yes I am still alive  :hammerhead:
Got my new to me ARB 63 QT fridge mounted up. Drilled the floor and installed 4 D-Rings to use the ARB tie down with. It isn't going anywhere now. Wiring it up tomorrow or the next day then taking it for its first trial run this weekend for mudmaster's coming out party  :talkingn:
Are you back in business or just making an exception for Mudmaster's inaugural trip?  Either way I am excited that you're going to make it happen.
SqWADoosh
Quote from: blackdiamond on September 20, 2016, 08:13:28 PM
The latter. Going to be sending this core in and getting new rear diff soon too though and I'll be back at it. Won't be going to tahuya though. Once per year is enough for me.
OTO Phil
As much as I love reading through this build, any chance you know what page your bumper build is on? lol
SqWADoosh
Quote from: excabswap on September 21, 2016, 12:27:45 AM
Bumper is made by http://badlandbumpers.com out of ravensdale.
Quote from: SqWADoosh on September 20, 2016, 08:38:20 PM
It's a long drive for the quality of wheeling, especially with several better spots closer.
SqWADoosh
Quote from: blackdiamond on September 21, 2016, 05:04:18 AM
Yup.
OTO Phil
You gonna make a trip to Brown's Camp someday?
SqWADoosh
Quote from: excabswap on September 21, 2016, 01:08:37 PM
Spent Memorial day of 15 there. Was considering going for this labor day weekend but then found bunch of metal in my diff. I'm sure I'll hit it up next year.
:)bestgen4runner
How is it for winter wheeling?
I have a couple guys been asking about going there soon. I was thinking about putting something together.
I am 1/5th of Perfect Fit
OTO Phil
It's about an hour drive for me. I'm in Vancouver. Come on down, we'll show you the trails
:)bestgen4runner
I will remember that for sure. How is it in December and January?
You did not answer My question about open and accessable in the winter?
OTO Phil
Oh whoops.. there's a few trails closed, some gnarly holds and stuff.. lemme check and I'll post dates
daniresch
Quote from: :)bestgen4runner on September 21, 2016, 05:37:42 PM
it is open all year :beerchug: during the winter you usually get some snow on higher elevation trails
Not sure what excabswap is referring saying some trails are closed.  :headscratch:
SqWADoosh
Well my fridge's 12volt outlet is dead.  :redface:
OTO Phil
Quote from: daniresch on September 21, 2016, 07:24:30 PM
Parts of University firepower is closed sometimes in the winter.
I only know because my club has keys to the gate [emoji106]
But it's only on a steep hill climb.. i think there's a couple other gates there too
Quote from: SqWADoosh on September 21, 2016, 07:57:14 PM
This is to power something else or how you power the fridge?  Bummer...
mudmaster
Did you get my text with John's number?
Time to go wheelin!
