Willy Wonka: 87 4runner, 5VZ, SAS w/ FJ62,
Started by zippo, May 11, 2014, 09:29:42 PM
zippo
Went wheeling with SqWADoosh and the Timber Tamers had a great day. Runner did awesome. I did have my front drive shaft slipe apart, but oh well.
If you see it, its for sale.
SqWADoosh
You did work today, brother. You are pretty close to ready for September  :smokin:
zippo
Looks like a fun trip!  Your 4Runner is looking great.  Sorry that your driveshaft disconnected on you, that'll put a damper on forward progress.  Remind me of your build again, lockers front and rear, and dual 2.28 transfer case gears, right?  In some of the video's I was thinking open differentials and on others I was thinking lockers.
:driving:
zippo
I have a spartan up front and a open rear.  Duals 2.28 + 4.7. Fj62 front axle with 4.88. 35x12.50r15 bfg km2
I called tom woods. I'm sending it in for a longer slip just have to pay the difference.
1985CRAWLER
Quote from: zippo on August 10, 2015, 09:27:03 PM
he should cover the difference for sending u a lame short slip. :shake:
that 3.4 sounds beast btw! loud fan
zippo
Quote from: 1985CRAWLER on August 10, 2015, 09:37:20 PM
It is crazy loud. I'm wondering if a eletric fan would be a good or bad idea. I dunno.
Dingman.
Quote from: zippo on August 10, 2015, 09:45:53 PM
I ran the stock fan the whole time.  I tried an electric fan once and when i got on it the engine torqued over and a pully hit the fan and toasted the fan and my radiator.  Just make sure you have a slim fan if you go electric!  :thumbs:
That explains churning tires on the same side.  I think a single rear locker pushes better than a single front pulls so you'll notice a nice improvement when you add the second locker.
I thought Tom Woods had already given you the long travel splines?  Does he have more than one length available?  I was just looking at my front driveshaft from Jesse @ High Angle but with the boot on it I couldn't measure the splines that were exposed.  I think it was a 12 inch travel and looks to be about split.
Should have left the IFS in.......
:yupyup: :yupyup:
With IFS,  the front driveshaft won't pull apart.......
:cheese:
Dingman.
Quote from: blackdiamond on August 11, 2015, 10:57:31 AM
They are usually a 12" spline in our long slip shafts.   I normally Make them with 3-4" of compression at static ride height.  It can change between different applications though.
Quote from: Dingman. on August 11, 2015, 06:55:38 PM
Mine has never disconnected so it must be right.
zippo
Found a good deal on a Grizzly. No I just have to put it in.
Picked up the metal for the rear bumper, i'm building this Sunday.
SqWADoosh
Found the videos from the timber tamers run on their YouTube.
zippo
Rear Bumper! Still needs a few little things, some clean up grinding and paint. Frame mounts are 5/8 plate. Main parts is 2x4 3/16". 1.5" 1/8 wall Hrew.
I scored these from a friend of a friend who runs a bumper shop.
Got these from Ruff Stuff. I like them. They are made for 2x4 box.
Scored the 2" x8" reciever from a local trailer shop.
Tacking it all together.
This has a lot of welds. And it needs a few clean up welds and end caps. But I think It looks awesome.
Just what I wanted. Nice and tight to the body, plenty of protection.
Plenty of shackel locations.
I know a lot of people run the bumper back to the frame. I Might do this down the road. But this brace seems like enough. If I plane on towing a heavy load, I might add some bracing the the reciever.
Overall very happy with the project!
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
zippo
The bumper looks great!  The perspective in pictures isn't always the greatest, but is that as tight as you can get it to the body?  I know the rear tailgate requires some room under it to function.  Also, I think the inner shackle mounts will do more harm than good because they hang below the bumper.  The bumper will drag and hang up enough on it's own, I really miss my bobbed 85 sometimes...
zippo
With the bumper down I have about 1/2 inch or so between it and the bumper. I don't think I could get it much tighter. The tailgate hangs down quiet a bit when open. I agree they hang down a little but no more then the receiver. If I find it is a problem I will weld a rounded piece across them to act as a slider.
twistedtoy92
You wheel with Timber Crawlers!?!?! They were our judges on our only course of WE Rock that we got to run and we ended up with the lowest score out of everyone.... They bought your super charger from you right??? Those 2 are AWESOME people, i had more respect for them after 5 minutes than I have for most people I've known for 5 years... Such a small world...
zippo
Quote from: twistedtoy92 on August 25, 2015, 12:41:17 AM
This was my first time out with them. Awesome people. Yeah he bought my SC from me. Glade to see its being used and in a good home. I'de wheel with them any time.
84_yota_4wd
Marlin Crawler
(888) 94-CRAWL / 888-942-7295
SqWADoosh
zippo
No but I welded up the ends with some plate. I need to stop and buy some more paint.
zippo
Bling..
I've needed/wanted one for awhile.
So I don't ahve to borrow someone elses.
Score this free from my father in law.
I had to relocate the contacts or cut the plastic part od the grill.
YAY! Finally.
Rockcrawlintoy
Pretty sure I have a hawes fairlead if you want it
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
zippo
SqWADoosh
Quote from: zippo on August 27, 2015, 09:02:14 PM
I'm good with the roller.  Thx though
Hawse will save you some approach angle....
Quote from: SqWADoosh on August 28, 2015, 07:58:41 AM
It will get chewed up by a steel cable, but if he goes with a synthetic rope...
I think I have a roller fairlead that someone can have if they need a replacement.  It weighs almost as much as my M8000 plus rope.
