Willy Wonka: 87 4runner, 5VZ, SAS w/ FJ62,
Started by zippo, May 11, 2014, 09:29:42 PM
spplater
I had the exact same noise/problem. After I replaced my rear t-case and the noise didn't go away I talking with Marlin, he explained that I needed a CV in the rear with the pinion pointed up at the t-case output. I did what he said and the noise went away.
emsvitil
Quote from: blackdiamond on July 13, 2015, 06:37:33 AM
With a standard driveshaft I thought the t-case flange and the 3rd flange should be parallel so that the two ends are operating at the same angles.
correct
QuoteWith a CV driveshaft I thought the 3rd flange should point directly at the t-case flange so that the standard joint on the 3rd end has no angle in it.
almost got it
With a CV at the transfer, the angle at the diff should be 1/2 to < 1 degree.     You want a small amount of movement so needle bearings have some movement and stay lubed.
Quote
Sounds like you have the CV alignment with a standard driveshaft?  I must be missing something because I would expect major vibration.
that's what the picture looks like to me
The splines on my 86 are on the transfer case side.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
84_yota_4wd
On the phone what you discribed did not sound like a driveshaft. But that being said a cv is almost always a must when driven on the road. Heres how mine is set up. Hahaha not even a few months old and its already a barber pole!
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
zippo
Quote from: 84_yota_4wd on July 13, 2015, 05:06:10 PM
That case is still looking nice though!
If you see it, its for sale.
1985CRAWLER
yep, CV is a must with a dual case setup driveline that sees use on the street.
84_yota_4wd
Yep I hope it stays that way, it's always funny when someone looks at my truck, it's primer on the outside pretty underneath, hahah
Marlin Crawler
helipilot77
Here is the link to what we were talking about the other day about the rules of the Rubicon.
http://www.delalbright.com/Rubicon/ethics.htm
LittleSteve
Quote from: helipilot77 on July 15, 2015, 05:04:29 AM
i would hope anyone would follow these rules regardless of where they are. Cos if they cant.... why they wheelin?!
Refusing to fit in or comply.
Easy is not worth anything.
zippo
zippo
So I rebuilt the rear end and threw in SqWADoosh's old front 4.88 diff. Had my front CV inserted into my rear drive shaft and problem fixed! It runfs like a beast!
84_yota_4wd
Marlin Crawler
zippo
So I got a bunch done today.
First was making bump stop brackets, out of some 1/4 inch plate.
Welded em in.
My rear output had some dripping issued due to some bad pitting on the CV flange. So I swapped in a tripll drilled and a new seal.
Threw in my new Tom Woods front shaft.
I need to add some 4 degree shim to the front. I have 10 degrees of positive caster, want to get it down to 6. Will also help the front shaft angle.
Got some other small things finished up. Still need to find a 3vz fan shround and get some wiring cleaned up.
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
zippo
Quote from: RockcrawlinJK on July 26, 2015, 12:33:02 PM
Any flex shots
If I find the bump stop doesn't break in and give me another inch or so of uptravel, I will take the saw to it.
emsvitil
I've lost count............
How many thread titles have you had?
:headscratch:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Slabzilla
Nice bump stops, those are definitely workin'. :beerchug:
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
zippo
Quote from: emsvitil on July 26, 2015, 10:49:36 PM
:headscratch:
A few. I try to update it when a big change happens. I've always kept the first part the same thoug so people can find their way back.
blackdiamond
Quote from: zippo on July 25, 2015, 11:09:17 PM
I'm assuming that it's has the long travel splines, but how much extension does it have left?  My first thought was you may be at risk for disconnecting it at full suspension droop because the front axle drops down and forward for maximum travel.
zippo
I made the measurements the guy at tome woods asked for and this is what they sent me. It doesn't compress or extend all that much. The pic is also a little decieving.
That said, I need to get her offroad to check everything
Willard
Woods shafts have a 12 inch slider. Way more than enough for your rig. Atleast that's what my front long slip from them has. I want there bamf cv for my rear.
Willard
Correction...mine has 10 inch splines. Nice rig btw.
84_yota_4wd
That springs looks pretty flat in that pic bud. You don't ever want a spring to go past negative. If its flat at full compression id leave the bump strops alone.
Marlin Crawler
Slabzilla
"Roger", what 84_yota said. I went wheelin' with my new springs without new bump stops. Now I need new springs again. Feelin' like a dumba$$ and a lot lighter in the wallet. All 'cause I had to go wheelin' like right now. :hammer:
zippo
Quote from: 84_yota_4wd on August 05, 2015, 03:51:58 PM
Agree. I won't be trimming them. I did bolt on some 35 BFG km2's! All thats left is a rear bumper and winch!
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Slabzilla
I like your KM2's and those wheels too! Are they Coated or painted? I put KM2's on my rig and dig the shizznits out of them. :beerchug:
zippo
Quote from: Slabzilla on August 05, 2015, 07:55:26 PM
They are cast aluminum with a mate finish. Not sure if they are painted or coated. The do look good. I really wanted to keep my steelies, but they just wont fit without a wheel spacer.
84_yota_4wd
 :beerchug:It looks awsome! Weres the turtle stickers hahahah :turtle:
Marlin Crawler
1985CRAWLER
truck is lookin real good zippo!
with a legit rear bumper itll be even better. i bet its still crazy fast with the 35s
