If its an 85 its probably a W55if you look under the hood look for the plate on the firewall that says model number and all of that information will be in the long numeric code. It will have it broken up in brackets for you and is easy to figure out. Engine, transmission, transfer case, cab type, frame and model number are all on the truck so just look around. Either the plate under the hood or the sticker in the driver door. Then find a junkyard
Nevermond that chart is waaayyyy incomplete. My bet is w55 though. Either that or g series but probably not
Those are some huge welds!
im just thinking this whole time,, hes got a 4wd truck wanting to put a 2wd transmission in? dont you have to change the output shaft
looks like a L43 to me
Started by malodin General 4WD Discussion
Started by Jason E. Transmission/Clutch
Started by Alfuh Transmission/Clutch
Started by TyGuidry Toyota Pickup/4Runner Tech 1979-95
Started by 87Fontana Axle/Differential/Steering
