Need help identifying transmission
Started by 80822R, October 01, 2012, 07:54:43 PM
80822R
Need help. I don't own a 4wd Toyota but all my "Toyota transmission" searches all comes back to this site. Unfortunately due to my newb status, I can't post pics. I have a 1985 Toyota pickup with a 5 speed tranny that whines really bad on 1,2,3 and 5th gears. 4 is fine. Also I have a really bad leak from the transmission. I was able to acquire what I know at least is a 2wd 5 speed transmission.but I don't know what "model" it is? I want to be able to at least get this one rebuilt and then swap out my current one. This is my daily driver so I don't want too much down time. Want to be able to purchase the correct rebuild kit. Any other suggestions/info are welcomed. Please. Thanks guys.
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
80822R
I've looked at those pics. Closest one I can see would be the W55... Although the center section isn't aluminum like the one in the pic. Would that matter?
Royota
If its an 85 its probably a W55if you look under the hood look for the plate on the firewall that says model number and all of that information will be in the long numeric code. It will have it broken up in brackets for you and is easy to figure out. Engine, transmission, transfer case, cab type, frame and model number are all on the truck so just look around. Either the  plate under the hood or the sticker in the driver door. Then find a junkyard
May Bobby Long be forever immortalized in his work and deeds to the Toyota 4x4 community. Because of a select few including this wonderful man, none of us have to drive Jeeps. He will be missed.
Royota
That's the only way I know mine is an 88 manufactured in November 87 with. W56, 22rec, rf1a, and all that jazz
80822R
Quote from: royaydel on October 01, 2012, 11:35:36 PM
Thank you gor the info, but the tranny in question isn't the one in the truck now. It's the one I aquired for cheap and don't have any specufucs on it except it was in a 84-86 toyota truck. I do know it's a 5 speed and for a 2wd. I looked at it closer and found some stamped numbers on it. On the steel center section is... 33111-20090. And on the tail end (under shifter) is... 33141-20090.
I hope they mean something...
Royota
There should be a little piece of metal that hangs off lime a tag on one of the bolts or drain plugs. Its proooobably ripped off though. My bet for an 84-86 is W55 and if not, probably W56. they're very similar so differences are minor and shouldn't matter either way. Good luck!
Royota
http://www.4x4wire.com/toyota/faq/parts/
Check out that little grid though. I will see what else I can come up with that's more specific
Royota
Nevermond that chart is waaayyyy incomplete. My bet is w55 though. Either that or g series but probably not
80822R
Quote from: royaydel on October 02, 2012, 10:58:30 AM
I got pics but can't seem to post 'em due to my current status.  :smack:
OOPS
80822R
OOPS
Here you go.
OOPS
The rest.
bleakhorizon
im just thinking this whole time,,  hes got a 4wd truck wanting to put a 2wd transmission in????  dont you have to change the output shaft
Those are some huge welds!
Tillamook, OR
Royota
^x2. If it were for 4wd you'd see the output shaft with the plate ready to accept a transfer case.
80822R
Quote from: bleakhorizon on October 02, 2012, 01:35:49 PM
No sir. My truck is a 2wd. Might be the wrong forum since everyone is 4wd but all my searches lead back to this site. Figure somebody should know.
Quote from: 79coyotefrg on October 02, 2012, 06:54:20 PM
looks like a L43 to me
It's what I thought at first (according to the chart)but this one I picked up is 5 spd. ???
emsvitil
Not an L43 or L series as the top forward section isn't flat.
If the center-forward case is iron, it could be a W50
http://en.wikipedia.org/wiki/Toyota_W_transmission.
Do a google image search on 'w50 transmission' and you'll get pictures that look like yours.
If you rebuild it, make sure that the L shaped lever from the stick to the internals in the rear upper housing is machined from one piece of metal rather than 2 pieces welded together.    (weld broke on my sisters 76 corona with W50)
http://www.drivetrain.com/parts_catalog/manual_transmission_overhaul_kits/toyota_w50_manual_transmission_illustration.html
part 81
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
80822R
Awesome! Thanks for the info. Now I need to know if it'll fit...
