Why not just convert to an EFI fuel tank? It will be more reliable and you can convert the whole carb fuel line (~5 psi) to the larger EFI fuel line (40+ psi) so your engine won't have any chance of running dry.Just find a extra cab 2wd at the wrecking yard and score on a huge (14-16 gallon) tank with the fuel pump, sender, and grab all the fuel lines.
BigMike will cringe at this, but I'm actually using the carbed truck fuel line with zero problems. I cut off one end of the high pressure fuel line at the tank, slipped it over the carbed line and hose clamped it in place. Same trick at the engine. I did this over a year ago with the intention of running a new larger fuel line and plumbing it correctly, but have never gotten around to it. Zero leaks, Zero problems. I know it is absolutely not the correct way to do it , but it works as a "temporary" solution.BTW, I'm using an EFI 4Runner tank in my 84 pickup...Ryan
Reklund can I ask what year Truck EFI system you put on your Truck I want to upgrade my 85
I swapped the EFI off of an '89 runner in my '84. I used the complete wiring harness and EFI system from the '89 and everything went back together perfectly. I didn't have to cut or splice any wiring. This should work on any '84 to '88 truck or '89 runner as long as they are the same body style.
Actually, I do have a heavy-ass size 14 foot. My truck runs fine- with the TRD header and cam and a little Toyota Tech tweaking here and there All of the components for my EFI came from a 1984 Celica with a 22RE. I modified the harness to work and had to extract the AFM, 02, and coil wires from the Celica dash harness and fit them into my pickup. I also made the fuel pump circuit, using the circuit opening relay from the Celica. My fuel tank is from a 1987 4Runner with a stock 7M Turbo engine Supra fuel pump installed. I run 45psi of fuel all day and haven't had ANY trouble with my fuel line setup...Ryan
Started by DeMented Toys Engine
Started by kneedownnate General 4WD Discussion
Started by robjuliano « 1 2 » Engine
Started by 81RedRocket Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by Yota_Junkie Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
