Author Topic: hydrogen conversion ecu questions  (Read 6542 times)
robjuliano
  • Turtle Points: -1
  • Member since May '08
  • Mr. Smith is a know it all
Re: hydrogen conversion ecu questions
« Reply #30 on: Jun 09, 2008, 01:59:49 AM »
Yes toyo487 I am from Oregon... Salem area. Thanks for backing me up oregon89crawler... I understand how everyone feels about spammers. Kind of like telemarketers.. I'm just excited about this thing we're making. We were able to measure the amount of hydrogen it's putting out. 1 gallon every 4 minutes.
oregon89crawler... I had Dale help me with this one. It took us about 5 hours to finish the enhancer. It looks killer... Dale took it to the next level with his talents. So the next one we got it down :) ask Dale about it tomorrow.
The hydrogen cell looks like a bomb...It looks good. I'm enjoying perfecting this thing. We now have blue prints to convert any car into 100% water... This I got to see to believe. Because I don't right now. Some guy out of Portland says he's done it so we are going to meet with him next month. Wouldn't that end up getting me shot by the oil companies????...
We will be finished with this this car tomorrow. I'll tell you how the results end up. It's a 1998 Maxima... a good one to work on.
Caboose
  • Turtle Points: 62
  • Male Posts: 733
  • Member since Jan '05
  • Truth... Justice... Honor...
« Reply #31 on: Jun 09, 2008, 09:51:40 AM »
Pictures say a thousand words...
"Who let the jeeps come?
81 Toy Pickup SR5
ROKTOY829
  • Turtle Points: 45
  • Male Posts: 191
  • Member since Feb '08
« Reply #32 on: Jun 09, 2008, 10:24:47 AM »
Glad I could help out robjuliano. All the enhancer is going to do is trick the ecm.  also did you stop fuel pump contol when switch over with your system or is it mixing with the air fuel.
« Last Edit: Jun 09, 2008, 10:46:13 AM by ROKTOY829 »
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #33 on: Jun 09, 2008, 01:23:47 PM »
Yea , some pic's would be nice.
BoG-ToY
  • Turtle Points: 594
  • Male Posts: 2,122
  • Member since Dec '05
« Reply #34 on: Jun 09, 2008, 06:45:07 PM »
there are SEVERAL things that can increase your mileage on our trucks...... for STARTERS.....DISCONNECT the throttle body heater lines.....YEAH they help the truck start up better...BUT still...not good for mileage....OK...so WHAT do you do with those lines?  bybass them?   cap them?   NO....RUN THEM ALONG THE FUEL HOSES to heat your fuel...will help fuel atomize better....LOL......and YES browns gas helps out with fuel mileage
Caboose
  • Turtle Points: 62
  • Male Posts: 733
« Reply #35 on: Jun 09, 2008, 09:38:34 PM »
 :worthless:  :biggthumpup:
81 Toy Pickup SR5
robjuliano [OP]
  • Turtle Points: -1
« Reply #36 on: Jun 16, 2008, 08:58:28 PM »
I am installing another hydrogen system in a 1999 Toyota Tacoma free Runner. 4 cy. 2wd. Does anyone know the pin position for the MAF sensor on this truck?
We did a 1998 Nissan Maxima last week. the results were just under 50% better mileage. This thing is working.. very cool.
robjuliano [OP]
  • Turtle Points: -1
« Reply #37 on: Jun 16, 2008, 09:02:33 PM »
One last thing... For pictures and some information on the system I created a myspace site for now. Just until we get a website up and running. I can except credit cards with paypal so I had to have the link somewhere. AND... myspace is free so what the hell. Here's the link----> www.myspace.com/waterrancars
Rupreckt86
  • Male Posts: 47
  • Member since May '06
  • DDin' my wheeler.
« Reply #38 on: Jun 16, 2008, 10:25:08 PM »
Everytime you add a neutral plate in between the positive and negative plate, your amperage is cut in half.  To keep the temperature down and produce high HHO, you should use a DC PWM.  Those are the two important parts of a successfull hydrogen generator by water electrolysis.  If you want to do you own research, do a google search on Stan Mayers or Joe Cell.  Either one of those should give you a pretty good start.
I think a SAS is gunna be next.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #39 on: Jun 17, 2008, 09:04:55 AM »
:rofl: Now you have made a shameless plug, should have never posted your Myspace page.  :shake:
Funny thing is Valvoline Instant Oil Change now has a conversion kit too, claims to save between 20% to 40% on your mpg. (and that's my shameless plug)
ROKTOY829
  • Turtle Points: 45
  • Male Posts: 191
« Reply #40 on: Jun 17, 2008, 10:52:58 AM »
robjuliano here are the pin positions for the mass air flow. pin 1- is brown/black is the ground side for the  intake air temp ,egr temp, engine temp,tps, & vapor pressure sensor. pin 2- is yellow/green and is the air intake temp side of the maf should have 5v on it. pin 3-is white/red is the 12v wire gets power from the efi relay. pin 4- is brown/white is the ground side of the hot wire (voltage signal) ground is inside ecm. pin 5- is green/red and is the voltage signal for the hot wire and tells the ecm how much air flow there is (voltage changes with air flow on pin 5) . connector goes left to right oh yea  :worthless:
« Last Edit: Jun 17, 2008, 11:42:23 AM by ROKTOY829 »
sir flops alot
  • Male Posts: 7
  • Member since Jun '08
« Reply #41 on: Jun 18, 2008, 06:24:37 PM »
Will this system work on Diesel engines?
Last post Apr 29, 2005, 09:11:58 PM
by awhotrods
Last post Sep 25, 2005, 11:33:09 PM
by kneedownnate
Last post Oct 05, 2009, 10:43:22 PM
by 854RUN
Last post Mar 25, 2010, 09:51:37 PM
by dntsdad
Last post May 23, 2011, 05:04:42 AM
by jimbo74
