81 Trekker Build
Started by dropzone, December 04, 2011, 04:24:10 AM
UndefinedTaco
love the trekker dude!
i wish i could find one someday
nice build!!
83' Pickup "ShitBox" - more parts
92' Pickup "Doomed" - some parts
dropzone
^^thanks!!
Moved the top in to the garage and put a couple of layers of fiberglass on the outside and inside:
The cold is making the cure time take forever.. With the fumes filling up the garage and not having any luck selling my Marlin bumper decided it was a good time tO play outside:
Some how 7" showed up missing:
Need to trim the mounting bracket a little more and find some 1.25" tubing to do an inner sleeve for the upper tube..
81 Toyota Trekker 221:1
dropzone
Got one side of the bobbed bumper done.
My welding skills are far from perfect but am happy with my 1st time welding tube.
I did an internal sleeve with rosette welds on both upper and lower tubes.
Going to have someone with a real welder to help me with the brackets.
BHT12
1984 4runner. Trailgear fronts, custom backs with shackles, 36 iroks, hi steer, hybrid 20+22r motor, full exhaust, lowsy weber, power everything, rear heat, power Antena,  sr5, altimeter,  back seat eliminator, tube bumper
1981 2wd long bed parts getter. All stock, sr5
1983 Toyota Sandtana Motorhome 4x4 Stock.
dropzone
Wrapped up converting my Marlin Crawler bumper into the short bus edition.
My buddy Paul fired up his 220 welder to do the bumper mounts, thanks Paul:Bigok:
Should have enough clearance for the rear shackles:
mtm
very nice build
it was seeing a trekker that inspired me do do mine. i started out with a pu bobbed it, remover the rear panel then had a soft top made up for it
hilux 82 with mk3 2.4d engine. bobed 18 inches, full soft top, 9 inches of lift,exo cage,swing out tyre carrier, front tube winchbumper with x9, rock sliders, rear tube bumper, front truetrac and rear arb lockers, twin trans adapter with 4.7 crawler gears,20 forward and 4 reverse gears, 38 inch super swampers , rear disc brake conversion, trans disc parking brake, 5.29 r&p ,rear bench seat,hand throtle,custom storage boxes, custom made snorkel,onboard air compressor,cb twin bateries,split charge system, diff guards, low profile gearbox mo
dropzone
Quote from: mtm on February 03, 2012, 02:17:26 PM
very nice build
thanks MTM. I think you are from England if I recognize your truck.  I have always likes your truck.  The V-6 would be nice
toyotanner
nice trekker :thumbsup:  never really thought about coming down the end of powerline but that scares me thinking about it haha
83 Crawler
Quote from: toyotanner on February 11, 2012, 10:06:03 AM
ya I'm scared to go up it!!
daniresch
dropzone
Made a little more progress on the top.
Glassed in the leading edge of the window openings so I could cut it for the new frames:
Test fit the frame:
Still have a little more sanding to do before paint:
Hopefully next week I will have some time to finish the window frames and cut some lexan for the sliding window..
dropzone
Not much of an update but finally found some roll bar padding that I liked (plus my wife said ok:P):
It has most of the padding facing whatever direction you want:
Picked up an 8" tablet that I will be able to also use as a GPS, just need to find some good Android software for it, but it will sure be a lot easier to see than my little Garmin. Also need to find a mount:
Played around with some lighting options, center light is an LED, puts out a ton of light. Just need to figure where to mount them:
Not sure if I like it mounted above the bumper:
88Rokyoat
Good lookin build. I like the lights down on the bumper. My .02
stupid people shouldn't have kids.
toyotanner
to me the lights look better underneath the bar
dropzone
It has been kimd of crappy weather all day so i played with the welder today and welded some tabs for rock light. Ran out of time to wire anything though.
Mounted the HID's
Welding on your back is a pain. Need to invest in  leather welding jacket. The hot stuff down my shirt reminded  me of my army days having hot brass go down my neck:D
dropzone
trying to figure out mounting ideas for the LED light bar.
down by the winch mount would interfere with my planned future winch so tried this:
zip ties are just a cheap way to try different mounting options..
mounted to the cage would help keep it more secure
daylight:
night, puts out a ton of light but would need to make a shield to prevent the light from filling the interior with light.
if I end up keeping it mounting to cage I will move it to the center and move the rearview mirror.
Just not sure how much use it would actually get mounted up there..
may end up selling it...dunno
dropzone
Decided it was time to mount up some rock lights.
I have 10 of these 3w lights:
Made some mounts for the sliders:
3 on the slider:
10 w led at each corner:
Still need to route the wiring. Debating about a separate switch for the front, middle and rear lights.
Thinking of adding a diode to the rear circuit so the back lights would come on with the back up lights.
Yep, only one side is wired...
dropzone
Testing the HID's at night-driving lights along:
Driving lights and headlights:
Front view, kind of crappy I phone pic:
Nimyad
Quote from: ocdropzone on February 28, 2012, 05:13:21 PM
Mounted the HID's
1st off I love your trekker, there was one that showed up on craigslist in my area about 8 months ago that I wanted to get so bad but didn't have the fund at the time. (only $1400 too, completely stock)
2nd I like how it has the Toyota lean!
Tankard
I'm digging the rock lights
"Knowledge without experience is just information." -Mark Twain
yotaneck13
Quote from: nimyad on March 04, 2012, 09:40:25 PM
thats just cuz he has a full gas tank :thumbs:
dropzone
#51
Quote from: yotaneck13 on March 05, 2012, 02:24:59 PM
tank is on passenger side...it does have a slight lean, ignition  is acting wierd and won't shut off so I have to stall the truck with the brake on..causing the truck to bind up, plus my fat butt has been standing on the slider...
the rock lights
Quote from: Tankard on March 05, 2012, 08:09:13 AM
thanks...now if I can get time to get it on the trail and use them :driving:
toyotanner
Quote from: ocdropzone on March 05, 2012, 03:52:27 PM
they still make good garage lights :dunno:
John Doe
Lights look good. I like the idea of the Diode to make the rear lights come on with Reverse I was planning on doing that myself. Where and for how much did you get the 10w led pods?
dropzone
Quote from: John Doe on March 05, 2012, 06:27:21 PM
Thanks.  I found them on ebay, if you search 10W LED flood a bunch of stuff comes up.  I paid around $20 each. the price seems to vary from $17'ish -$30.
http://www.ebay.com/itm/Waterproof-Warm-White-LED-Flood-Light-Lamp-10W-12V-Bulb-/290608119828?_trksid=m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D3%26po%3DLVI%26ps%3D63%26clkid%3D6825647075718172340
they are cheapies but seem to be built half way decent.
Quote from: toyotanner on March 05, 2012, 05:36:55 PM
yep, pretty good for that :beerchug:
Volcom
Nice light setup!  I really would love to get a light bar sometime.  How's the glare from inside the cab with the light bar attached to the cage on the inside?
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
dropzone
Quote from: Volcom on March 07, 2012, 10:08:02 AM
it probably would not have been too bad with a sheet metal shield or something but the glare off the hood wasn't great.
I actually just sold the light yesterday...on its way back east
dropzone
Been looking for a way to have decent sound but not have to worry about unhooking wires every time I take off a door, which is actually a lot.
Followed a boat with a wakeboard mount...thought cool. Picked up a set of wakeboard speakers cheap and mounted them to the age.
They wouldn't quite fit where I wanted due to the angle of the cage so I made an extension
Waterproof and out of the way..
dropzone
Had some time today and was able to finish up my Rocklight install:
I may tweak the aim on the slider mounted lights..
Volcom
Looks great!  You're ready for some night wheeling!
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
