Author Topic: Dash break Light and battery light  (Read 7418 times)
Creature83
  • Male Posts: 35
  • Member since Apr '11
« on: May 08, 2011, 09:57:51 PM »
I have an 83 Toyota that has the break light and battery charge light on the dash always on.  I was wondering if any one knew what might cause this?
Creature83
David
  • Turtle Points: 218
  • Male Posts: 263
  • Member since Jan '03
  • I love Marlin Crawler!
Re: Dash break Light and battery light
« Reply #1 on: May 08, 2011, 10:06:06 PM »
There has been a thread on this subject already. Here is some of the banter:  http://board.marlincrawler.com/index.php?action=search2
Check the obvious, fuses, loose connection at the alt, check all grounds including the grounds at the engine and frame, take them off and clean them.
I had the same problem on my 83, turned out to be the main ground on the drivers side, mine was wrapped up with the alternator wires.
rockin86runner
  • Turtle Points: -18
  • Male Posts: 871
  • Member since Nov '07
« Reply #2 on: May 08, 2011, 10:13:03 PM »
those lights have been on in mine for years looked all over for something and still cant find anything
85 toy runner tons 4link front and rear ORIs 42 pitbulls
86 runner some other things  pained orange STOLEN REWARD IF FOUND
70 cj-5 renegade1 buick 231 v-6 t-18 dana20 dana 30,44 32in BFG at
 :usa: USN SEABEE EO2 SCW .....We Build.We Fight.We Defend....Hoo-Rah  GOD BLESS OUR TROOPS :usa:
24SHORTIE
  • Turtle Points: 184
  • Female Posts: 313
« Reply #3 on: May 09, 2011, 09:33:03 AM »
trust me, he wont stop trying to fix it till its fixed. he is like that.
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #4 on: May 09, 2011, 09:49:06 AM »
WOW, extremely common Toyota prob right here u guys, he has a prob with his charging system
Bust out the volt meter and start from the easiest poin, its most likely your alt tho
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Drinking me beer
« Reply #5 on: May 09, 2011, 11:57:59 AM »
ALt
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
« Reply #6 on: May 09, 2011, 05:26:30 PM »
Its not the alt.  Mine has been doing this for a while now.  Im pretty sure it has to do with the e brake switch.  If I pull the e brake out then push it back in, it will shut off the lights.  It very well could be the ground causing it but tbh I have the stock voltage gauge and so ill know if theres a problem with the alt.
I might look into it some days soon.  Not really on the top of my list.   Its just a 1st gen bug.
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #7 on: May 09, 2011, 06:12:33 PM »
alt bad and you need to relese the parking brake before driving.
junya92toy
  • Male Posts: 1,500
  • Drinking me beer
« Reply #8 on: May 09, 2011, 07:03:06 PM »
Dont want to be a smartass
« Last Edit: May 10, 2011, 04:14:41 AM by junya92toy »
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
« Reply #9 on: May 09, 2011, 07:14:49 PM »
Alt or voltage reg.
You'll never take me alive
Crawlota
  • Male Posts: 13
  • Member since May '11
« Reply #10 on: May 09, 2011, 09:11:02 PM »
Voltage issue
Creature83 [OP]
  • Male Posts: 35
« Reply #11 on: May 09, 2011, 10:58:07 PM »
There is nothing wrong with the alt.  I'm not stupid and that doesn't explain the brake light which stays on after the parking break is released smart ass.
Creature83
Sparkplug
  • Male Posts: 2,046
« Reply #12 on: May 09, 2011, 11:37:24 PM »
Toyota elec sytems in these truks are extremely tempermetal, The brake and charge light will come on when there is any interruption at all, even so much as a small short in your clock, all the way to a bad alt, or fried ecu. Most COMMON cause is a bad alt, Hence why was told its a common prob and you need to bust out your volt meter to find out.
A dumbass wud wnder why when hey have a chagrer hooked up to their bat and they turn it OFF, their brake and chrage light comes on int ehir tuck if its still hooked up, they wudnt know bout tyta elec sytems
They key of this being that if BOTH the BRAKE AND CHARGE light are on together, you have a bad alt, charging issue, or a short
« Last Edit: May 09, 2011, 11:58:34 PM by Sparkplug »
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #13 on: May 10, 2011, 03:34:13 AM »
If you have a charging issue the brake light does come on with the charge light, dont' know why but it does every time. As to being able to pull the hand brake and release it to turn both the charge light and brake light that is a short which is why the charge light is on too. Creature83 I don't think anyone is being a "smart ass" on this it is a fact that Toyota's do this when there is an electrial issue with charging. It doesn't help to start calling names when you asked the question and people are giving you an honest answer. For whatever reason when the alt. is not giving the proper charge or there is a short they will come on together.
trk4sale
« Reply #14 on: May 10, 2011, 07:02:53 AM »
If you know your alternator/charging system is working then it is probably the relay on the passenger side kick panel. These are notorious for failing. It can be removed without affecting the charging system, but you will lose the ability to tell if there really is a charging issue. I just added a voltmeter which is better than an idiot light anyway. The e-brake light will still function.
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #15 on: May 10, 2011, 09:24:10 PM »
I believe I have one of those relays if your interested?
Creature83 [OP]
  • Male Posts: 35
« Reply #16 on: May 11, 2011, 07:35:41 PM »
Yeah I would be interested in the relay.
Creature83
Creature83 [OP]
  • Male Posts: 35
« Reply #17 on: May 11, 2011, 07:37:09 PM »
This was the only person I was talking about being a smart ass.  Everyone else was helping
Creature83
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #18 on: May 11, 2011, 09:45:30 PM »
what can I say? you got me.  :yupyup: my 83 has the same thing from day one I got it.
every now and then if I slam the pass door the light goes out.  relay.
never bothered to change it out. I put on a volt gage and don't care about the light. butt that's just me.
don't tell big mikey I was being a smart :moon: he'll  :spank: me  :sad2: :shudder:
Creature83 [OP]
  • Male Posts: 35
« Reply #19 on: May 11, 2011, 10:50:43 PM »
Yeah thats what it wound up being.  I unplugged it and everything works again.  It bugs me when stuff doesn't work right.
Creature83
trk4sale
« Reply #20 on: May 12, 2011, 06:58:01 AM »
That relay is like your appendix- essentially useless while it's in and not noticeable after it's out.
Creature83 [OP]
  • Male Posts: 35
« Reply #21 on: May 12, 2011, 07:15:49 AM »
That just makes it where the charge light wont come on if the alternator is bad right?
Creature83
8D3TOY
  • Member since May '05
« Reply #22 on: May 13, 2011, 11:08:28 AM »
Check smog stuff, had the same issue, rebuilt carb, a couple random vacume switches and oxygen sensor solved problem.  I was told by an old Toyota mechanic that the brake charge light combo is like a check engine light.
fatkidskickrocks4x4
  • Turtle Points: -2
  • Male Posts: 216
  • Member since Apr '08
« Reply #23 on: May 16, 2011, 12:46:50 AM »
I might be in love with this thread! I have the same problem and ignored it now something is wrong
If you have to go "balls deep" you aren't doing it righ
Creature83 [OP]
  • Male Posts: 35
« Reply #24 on: May 16, 2011, 06:54:14 PM »
My problem turned out to be the relay.  It just smogged a few month ago.
Creature83
Last post Jan 19, 2019, 08:40:10 PM
by mountain,man1
Last post Feb 12, 2006, 05:13:19 PM
by 79coyotefrg
Last post Oct 06, 2008, 08:29:12 PM
by attitude of gratitude
Last post Nov 09, 2010, 04:13:11 PM
by Sleeve of Wizzard
Last post Dec 05, 2010, 11:43:22 PM
by yoshaleng
