the 4wd shift indicator light switch is on the passenger side of the t-case up toards the body you will see two wires going to it my guess is that the switch is screwed up or there is a short some where first check for any missing insalation on the wires trace the wires as far as you can if that dont give you any thing to work on then you need to replace the switch the switch has nothing to do with the hubs i belive what turns it on and off are grooves in the shift fork that push a spring loaded switch in and out so the only problems i can think of are wireing or the switchgood luckps nice avatar
good job now post some more of that avatar
Started by sweet85 General 4WD Discussion
Started by Creature83 Toyota Pickup/4Runner Tech 1979-95
Started by vic and mikes New Member Check-In!
Started by vic and mikes Transfer Case/Drive Line
Started by Toy82 Toyota Pickup/4Runner Tech 1979-95
