Good night Turtles,Really can some one tell me what the points deal is all about,,, I think I have entertained you enough to earn that,See ya in the morning
How long must this thread go on
its gonna be the longest thread with nothin but confusing :bull crap: ever on marlin
awesomethanks winner!
Post up the dimensions of the bushing and I will go away,
Really?As people go find brass bushing and measuring tools.
wont work ive already posted the dimensions a while ago and he did nothing but complain about them
hay mike what the hell you been up to?
I saw that you posted the axle dimension and the inner axle seal dimension. Right?He wants the Brass bushing that presses into the spindle.
Ok, I got to the point of scanning very fast through most of this BS.This might be long and honestly sound like something that came out of Wenhar's mouth (or keyboard)FIRST: Toyota sales propaganda; My truck says to change my oil every 12k miles I believe, while the oil salesman wants me to change it every six. Most people who buy a new vehicle, get it serviced at the dealer, so this would be profitable for Toyota to have you change your oil that often. My 2007 prius even with the higher speeds, leaner fuel ratio, and worse fuels recommended 5,000 miles between oil changes.Second: for me, it sounds like KIRK was saying to TAKE IT TO SOMEONE WHO WILL FOLLOW THE FSM.Third: I personally have worked on big rig trailers and trailer dolly hubs that use OIL in there wheel hubs, it actively draws heat and debris away from the bearing surface and provide fresh lubrication.3.1 I believe CV joints do run a thinner jointFour: I have seen a few axles that have knuckles FULL of soup with NO SIGN of grease anywhere.4.1 I have also seen these same axle FULL of soup not leaking it out the wiper sealsI don't know what else to say, I actually tried to keep it short. I have also seen factories do things different then the real world, like different grade bearings or rod journals using color codes from the factory, real world, we would correctly machine the part for the mass produced bearings available. So it wouldn't surprise me if from the factory these were filled with a product that may have been very popular in another country, or with a product that they were able to mass produce or that they ordered in bulk to originally fill these with. It also wouldn't surprise me if the first FSM that left the hand of Toyota technicians headed to the states contained info to fill these knuckles with grease, even if they were filled with something other then that from the factory, as grease would be what was available. So, these live axles were produced for quite a while. I'm sure that a dealer has opened up one recently, maybe an fj80. What was inside the knuckle of an fj80 from the factory? Someone for some reason opened up a knuckle that only had a few thousand miles on it and knows what was inside that knuckle. REGARDLESS of all this crap above.....you need to take into consideration the following:what is the cost and availability of this product, the usefulness of it, what benefits COULD it provide, regardless of what came in the axle.I believe most people prefer grease. It stays put even when you pull apart your axle, when you break something it holds the broken pieces in place instead of allowing them to get into other areas and doing more damage. You can pull apart an axle, replace a part and only need to grease new parts or parts that were cleaned because of contamination. This stuff would have to be properly drained and most likely not be reused especially if a break occurred. I feel that 99% of the time I was in an axle was because of breakage, or even to mess with a diff or brakes. If I had a rig that was using a Toyota live axle to drive freeway miles with a heavy load didn't use 4wd much, and didn't use it for rock crawling (for some reason I feel like I am describing a SAS'ed chinook or dolphin that was used for an out door enthusiast to camp in)BLAH this is too much, I wouldn't use it in something that you intentionally drive into harms way, plan on upgrading, modifying and junk like that.Does it matter if this is what Toyota put in from the factory NOWhat matters is if there would be a benefit TODAY to put this into your knuckle. Ive answered, for me it would not be a benefit.Do I think that there is a use for this product MOST DEFINITALLY, but not on a crawler as he is actively trying to advertise this stuff too. hopefully I can keep up on responses to my post now
ght ieuwy iropw whei dkle urie r ejlr ejiwj jew jwur je jeiwjdkfkcnv jfioew dhjl fjdkl; ej rl fdl fhjdsk dhjk d hjkd dhjkd hjdkoie bcvh he wy fhjd fhewuiyhew fhkd eo ehewh djbkdf j hoe fhjdfh ei dhfd fe ewyey hdgjk hdjkghdsfyoe fdjkhds jkhds fhoiewh oieu dhjks hjksdoiwehwkhdsgjk g s ghdsjgkh jkshgjds gh g shgjkh gjywoieoieugds gjkf dsieo wh hfioewu whefjkd shgfjksoie whjg djf oiw dhjgf jyh fdhsjk fheoewf jkguoiewuf wefh foiwej whefjk hjkfhweoihoiw jkh g fjoiweh oiwh g ds whjoihwe oih dhgsdjhguyruiey r ri utoiru oiew wi twioy thg fdjghfjks ghjkfdl ghjkl frgfjk gf ghjkfhowuoipw;upwq dh f ghfjklhglyruieytu jkbnvmnbxcvmnxzuih troi dh gfhsgjk fhg jfhjkl fghj g ruit tryuw riwt oiwuyt wew uityewroy hds jvbb jkw idshg jkshduewy hdsgjkhjkhr gjfsk hw tryuiwo thjgk ksy gwuytw tyuiyt uiwy dshfjkshuiwy uiewh ukhds ui iuwy rui
I think what you meant to say was lskdfj fdjafslf lkf a lkdfklfsjklja;lsjdjfi fhghiaoi hdi dshhs a ha oishdios hia ofh oai hfhisda hfi oa ifd aoih fhisdh rhuhia r 34t4rfgioh?
Started by motorider228 Chit Chat Camp
Started by cgbemis Chit Chat Camp
Started by KYOTA « 1 2 » Trail Reports, Events, and Gatherings
Started by CTENG in KS « 1 2 ... 5 6 » General 4WD Discussion
Started by abnormaltoy Chit Chat Camp
