I have done it. I run chevy rear disks. I would not go back (I rarely adjust it, except when I am fully loaded), the valve is mounted in the cab. I used SUM-G3905.
Eliminated mine completely just ran like a t sort of mount and wa la all gone, i cant even telll the difference
I did the same thing as Rocksurfer but I definitely don't have as much rear brake as I would like. I like that prop valve 4runnerchevy. Pretty reasonable. What did you do with the unused line?
Not elimination of it but I cut the arm off to about an inch long then tie-wrap it in the full open position, pretty much eliminates it.
The unused line on my runner is still under it, its just not ran to anything. I am going to rip it all out tomorrow I will post some pic's of how I did everthing as soon as I can.
Started by pickemup81 General 4WD Discussion
Started by croberts Toyota Pickup/4Runner Tech 1979-95
Started by BNRSHNTZL Toyota Pickup/4Runner Tech 1979-95
Started by SpencerS Newbie Questions
Started by mossyoak85yota New Member Check-In!
