Author Topic: LSPV i need help with it  (Read 4285 times)
BNRSHNTZL
  • Turtle Points: -34
  • Male Posts: 459
  • Member since Jun '06
« on: Jul 17, 2007, 07:38:55 AM »
LSPV (level sensing porpoising valve) i need a fix, the valve is eather stuck in the up position and not allowing fluid to the rear brakes or something i need help?? :confused:
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: LSPV i need help with it
« Reply #1 on: Jul 17, 2007, 07:40:08 AM »
Stuck in the up position would release the most fluid to the rear brakes.
I have mine tied upward with a zip tie.
BNRSHNTZL [OP]
  • Male Posts: 459
« Reply #2 on: Jul 17, 2007, 11:32:02 AM »
even holding it up and pressing the brakes it still will not allow brake fluid to the drums
MiniSimp
  • Male Posts: 5,120
« Reply #3 on: Jul 17, 2007, 11:33:10 AM »
Sounds like you need to flush your lines. Something clogging them. :twocents:
BNRSHNTZL [OP]
  • Male Posts: 459
« Reply #4 on: Jul 17, 2007, 11:38:05 AM »
tried that too reverse flow up to the lsvp. i can get fluid there just not past it. i have taken it apart and cleaned it even cleaned the chevron ring the plunger just stays in the up position
MiniSimp
  • Male Posts: 5,120
« Reply #5 on: Jul 17, 2007, 11:41:12 AM »
Have you checked your drums?
BNRSHNTZL [OP]
  • Male Posts: 459
« Reply #6 on: Jul 17, 2007, 11:42:50 AM »
i will tonight
BNRSHNTZL [OP]
  • Male Posts: 459
« Reply #7 on: Jul 25, 2007, 12:08:46 PM »
master cylinder
MiniSimp
  • Male Posts: 5,120
« Reply #8 on: Jul 25, 2007, 01:10:06 PM »
Sweet.
wflaw45
  • Male Posts: 128
  • Member since Oct '06
« Reply #9 on: Jul 28, 2007, 06:51:59 AM »
so what is the ideal position for this thing? now that my rear is lifted im sure its not braking like it should. and i want to get that crazy long rod out from under my truck
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #10 on: Jul 28, 2007, 01:13:09 PM »
get rid of it and put a prop valve under the hood
Quote
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #11 on: Jul 28, 2007, 01:21:58 PM »
remove it  and  plum the line in direct,  if you have  big tires  you dont need no stinking proportioning valve :gap:
wflaw45
  • Male Posts: 128
« Reply #12 on: Jul 30, 2007, 08:05:44 AM »
what do i do with the rest of the lines going to it?
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #13 on: Jul 30, 2007, 08:08:15 AM »
dont worry about them, they are a non issue.... they are return lines and things like that... if you jsut run a line from the mc to the rear, there is no need to touch any of the oterh lines
Last post Apr 16, 2006, 09:45:43 PM
by reklund5
Last post Apr 27, 2007, 05:13:34 PM
by TurtleTappers91
Last post Sep 09, 2007, 07:16:21 PM
by Black Runner
Last post Jun 21, 2010, 09:18:11 PM
by OOPS
Last post Jan 28, 2011, 10:15:12 PM
by crazykooter
