lspv
Started by pickemup81, April 15, 2006, 05:46:46 PM
pickemup81
I was just wondering if there was a post on here about how to safely bypass the lspv or safely make it work. thanks
86 4runner now with sas and other garbage
IronClad
leave it and cut the rod that runs to the axle about 3-4"  out from the lspv and leave it alone
Annihilation  Fabrication
Do you need a Hammer?
pickemup81
i dont have the rod but it totally disabled my rear brakes
Willy Mammoth
Yes that has been asked a lot. there should be a bunch of threads on the subject.
There is several ways of dealing with it.
Some just remove it all together and others simply tie it up to the frame causing it to be full open.
Otherwise extend the rod the same as you lifted the truck.
You may want to make the rod adjustable to fine tune it if needed.
Hope this helps.
Ooooh!  This gives me an idea!  You could cut it several inches from the valves as suggested, then weld on a ring at the end.  Drill a hole through that then mount a rod vertically that slides through the ring and has several holes drilled through it so you can move your hitch pin to whatever angle you wanna run.  Kinda booty fab, but it could work.
reklund5
Here's my solution:
