Author Topic: 05 e locker in an 85 straight axle?  (Read 3349 times)
red450r
  • Turtle Points: 3
  • Member since Nov '10
« on: Nov 19, 2010, 07:49:02 PM »
i got this idea form a buddy, dont kno much about it, will the elocker work?, anything special i need to know?, thanks
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
Re: 05 e locker in an 85 straight axle?
« Reply #1 on: Nov 19, 2010, 08:03:52 PM »
If it's an 8" ring it will work. Search out how to modify your housing. It's pretty simple do make everything fit.
Rockdad
  • Turtle Points: 70
  • Member since Oct '10
« Reply #2 on: Nov 20, 2010, 12:30:57 AM »
Do you need a different housing for the third? or can you just drill a hole for the motor?
TacoRunner's 3 & 4 Link Systems
http://www.4wheelunderground.com/
Ready for any trail adventure you throw at it!
red450r [OP]
  • Turtle Points: 3
« Reply #3 on: Nov 20, 2010, 07:13:43 AM »
I have the complete 3rd, need help with the wiring
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #4 on: Nov 20, 2010, 08:05:43 AM »
The housing has to be clearanced for the elocker and ring gear. There are a bunch of writeups on here and Pirate.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Nov 26, 2010, 11:40:50 AM »
lots of people have this setup
this is a picture of a rear housing but its the same mods needed on the front
vortectoy
  • Turtle Points: -16
  • Male Posts: 67
  • Member since Mar '04
  • 2TR-FE POWER
« Reply #7 on: Nov 26, 2010, 01:57:54 PM »
Im thinking 05 and up thirds are based on the 8.4" not the 8". They use the larger 10mm studs for mounting.
red450r [OP]
  • Turtle Points: 3
« Reply #8 on: Nov 27, 2010, 03:37:48 PM »
thanks guys, i have ordered my r&p and set up kit, waitn for them to get here and imma pull the front end down and get started, i see the one in the pic has an aftermarket skid plate, who carries them
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #10 on: Nov 27, 2010, 07:53:54 PM »
NO,  the Elocker differential has a 8 inch ring gear.  I know because I have a 2005 elocker in my 79
the Elocker uses v6  PRE tacoma r&p and bearings besides the one LARGE bearing
the tacoma 8.4 has a HUGE truss  across the rear of the 3rd member.  the Elocker does NOT
red450r [OP]
  • Turtle Points: 3
« Reply #11 on: Nov 28, 2010, 02:48:35 PM »
i ordered the wrong r&p
red450r [OP]
  • Turtle Points: 3
« Reply #12 on: Nov 28, 2010, 03:35:40 PM »
so in order to get my front and rear r&p i need a v6 set and a 4cyl set?
« Reply #13 on: Nov 28, 2010, 08:07:45 PM »
do you have the elocker in the back and the stock diff in the front??
red450r [OP]
  • Turtle Points: 3
« Reply #14 on: Nov 29, 2010, 03:45:59 AM »
other way around
81yotalove
  • Male Posts: 310
  • Member since Nov '09
« Reply #15 on: Nov 29, 2010, 08:41:21 AM »
you might to run the elocker in the rear. from the research i've done the toyota e locker takes a 5-10 feet to engage and is best in the rear for better street driving but essentially give you a spool once engaged, if you want a selectable locker for the front probably look for an arb. if im wrong someone please chime in.
81 swb 22re 35's
red450r [OP]
  • Turtle Points: 3
« Reply #16 on: Nov 29, 2010, 01:07:52 PM »
im spooling the rear, ive had trucks before that were welded in both ends, and im fine with the way they drove
81yotalove
  • Male Posts: 310
« Reply #17 on: Nov 29, 2010, 02:42:43 PM »
if you have had it with both welded why not spool the front, put the elocker in the rear so its open on the street increasing tire life, allowing for easier turning, and the lock it offroad and its a spool. just my 2 cents. seems logical to me but it seems you have your mind made up. either way good lick with the install.
81 swb 22re 35's
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« Reply #18 on: Nov 29, 2010, 10:49:20 PM »
I run a LP e-locker in the rear of my 80 truck and a HP e-locker in the front of my 80 truck 5.29 gears I went with http://www.inchwormgear.com for my wiring on both of the lockers cause its EASY and SIMPLE  and CHEAP  I also have a writeup on here for the e-locker  :turtle: :turtle: :turtle:
[img]http://bo
Last post Sep 27, 2004, 11:35:45 PM
by mudguts
Last post Mar 15, 2005, 07:24:53 PM
by Riddett
Last post Mar 26, 2007, 10:28:12 PM
by dirtchicken
Last post Apr 23, 2008, 07:11:50 PM
by 808-Yota
Last post Mar 14, 2011, 11:10:01 PM
by possume22
