Poll
what color should I paint my front bumper and rock sliders ?
Black as normal
Blue like my arms and truck
Author Topic: THE BLUE MARLIN aka 1980 project build up by Maxwe001  (Read 62517 times)
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« on: Aug 03, 2008, 08:32:55 PM »
I bought this truck for $700.00 from a guy up the road it is a 1980 toyota pickup
the clutch was bad in it and it didnt have a right rear back glass so I put a clutch in it and put the back glass in and then I drove it for a little while and was told that my brake light and reverse lights dont work so I got my trusty test light out and started with the light bulb and they were good and then I worked my way back to the main source
I found no bad spots so I had a buddy of mine help me look at it and he said he isnt gona touch it cause there was to much of a fire hazard so I began to look on the MARLIN CRAWLER FORUM for a 1st gen wire harness I was lucky that Glen aka 79coyotefrg
had a 1983 harness I bought it and I am having to swap over all my pigtails (twist and solder glen I know) to keep me from  having to cut and solder a million wires I bought a combo switch from Collier aka DTB it is a plug and play :psss: we like stuff like that dont we dtb. but I still must swap my ends over on some things so I can plug them into my a/c and heater box and into my motor stuff I saw the chance to buy a marlin lift kit I did this and it has been delivered all I have is a camera on my cell phone so if the pict look kinda crapy its a cell phone cam I will begin to post pict as soon as I get some from my phone to the pc for all of thoes that wanted me to start a thred on this here ya go
« Last Edit: Jan 03, 2010, 06:32:43 PM by DR. maxwe001 »
[img]http://bo
GJToyotabug
  • Male Posts: 969
  • Member since Jan '08
  • The bug is deep in this one
    • Alcan Spring
Re: 1980 project build up by Maxwe001
« Reply #1 on: Aug 03, 2008, 08:42:51 PM »
:woohoo: i cant wait to see it built up
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #2 on: Aug 03, 2008, 11:25:57 PM »
 :worthless:
Quote
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #3 on: Aug 05, 2008, 06:38:28 AM »
I am gonna pull it out  of the garage after I got through with my 8 hours of daily "W" word but i will give you a heads up on what I have done so far so the pictures will go and and hand.
first I took the front crossmember out of the box and I put the front springs and the bushings in them along with the back front bushings its just mocked up into place that way i can look at everything and have a good idea of how it is going to fit up and I can tell my welder guy to burn the metal to metal. then I began to put the rear springs and bushings together ADD LOTS AND LOTS OF GREASE ITS BETTER TO DO IT NOW THAN FORGET ABOUT IT LATER HAND HAVE SQUEEKY SPRINGS AND BUSHINGS THAT GO OUT PREMATURITLY .as you can see I went ahead and put the rear leaf springer hanger and the frame mount onto the spring I did this so that i would have a good idea of what it will look like and to make sure I put it on the correct end of the spring.  :turtle: MARLIN CRAWLER supplies instructions  :hammerhead: for a reason ALWAYS PUT THE MILATARY WRAP END TO THE FRONT OF THE TRUCK LIKE IT SAYS IN THE INSTRUCTIONS. I then was able to get me some sweet deals on some half doors and also on some tube doors $75.00 for both sets he was asking $50.00 for each but I told him id take both of them for $75.00 he said OK its a deal. so I SKIPPED work all day yesterday and yesterday afternoon I drove to Birmingham about 45 min north of here and met with the guy that had the doors. I believe some slight modification will be needed for the tube doors and I know i need to finish welding up the half doors they do not have any kind of sheet metal covering them to keep me from cutting my legs  I will get Pict today I swear it.
« Last Edit: Aug 05, 2008, 06:45:05 AM by maxwe001 »
[img]http://bo
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #4 on: Aug 05, 2008, 06:43:13 AM »
:worthless:
Yes we do!
Quote
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #5 on: Aug 06, 2008, 06:18:13 AM »
pix are here
[img]http://bo
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #6 on: Aug 06, 2008, 10:11:59 AM »
there will be more pict taken at a later date  if you have a question about any of the pictures you have seen here please feel  free to post in this thread and I will do my best to answer it for you if there is a picture of something you would like to see along the way please feel free to tell me about it so that i may make a mental note to get a copy of it as we go foward in  this process.
[img]http://bo
jonathan82toy
  • Turtle Points: 5
  • Male Posts: 502
  • Member since Mar '07
  • 1St Gens Rule!
« Reply #7 on: Aug 06, 2008, 10:25:34 AM »
Nice pics! Hurry up and finish Jeff
What Is The Truth Behind The Magic Turtle Breeding Program?
S.S. More Powerful Than Superman, Batman, Spiderman And The Incredible Hulk Put Together.
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
« Reply #8 on: Aug 06, 2008, 10:29:44 AM »
sweet....get er done boy! :whip:
Quote
  • Turtle Points: 1051
  • Male Posts: 9,755
  • Member since Oct '04
« Reply #9 on: Aug 06, 2008, 02:41:19 PM »
Sweet, I love 1st gens!
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #10 on: Aug 07, 2008, 02:28:19 PM »
ok today while I was at work a package came via ups and I was wondering what it was it is my bump stops
had to throw this in there its a free advertisement
[img]http://bo
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #11 on: Sep 08, 2008, 06:28:46 AM »
Look I got some pict. for your viewing hope you injoy them  and there will be more to come in the days ahead    :haha: I love my torch and my air tools
more to come later on    :wave:
[img]http://bo
GJToyotabug
  • Male Posts: 969
    • Alcan Spring
« Reply #12 on: Sep 08, 2008, 06:31:27 AM »
love th blue on the hi steer arms PIMP
sabenson82
  • Male Posts: 70
  • Member since Mar '08
« Reply #13 on: Sep 08, 2008, 04:59:06 PM »
lookin good.....keep it up and keep us posted
Build it, Break it, Build it again...STRONGER
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
« Reply #14 on: Sep 09, 2008, 04:32:52 PM »
 :thumbs:
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #15 on: Sep 11, 2008, 07:16:40 AM »
I got a boo-boo last night and had to stop earlier than I wanted and flush my :eye: out I got a piece of dirt or something in it. but I did snap a few pix. b4 all that happened
 :eek: I DONT UNDERSTAND THIS
:tantrum: THE PERSON THAT DID THIS NEEDS TO BE SHOT
I hate manual labor
[img]http://bo
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #16 on: Sep 11, 2008, 01:08:30 PM »
update: my :eye: is ok and I am going ot get back at it as soon as I get off work  I got the passenger side spring down but the drivers side is a little tougher cause of the way that the exhaust is run but I am thin king of either cutting the exhaust (dont wana do that ) or trying to pry it out of my way just enough to get a air socket on it and then put the air to it but then I will have the SAME problem when I reinstall it so I might just cut it ???  any thoughts on what to do ?
« Last Edit: Sep 13, 2008, 11:08:58 AM by maxwe001 »
[img]http://bo
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #17 on: Sep 11, 2008, 01:12:53 PM »
oh nice Jeff. i like it.
Broke_Okie_Ty
  • Turtle Points: -6
  • Male Posts: 733
  • Member since Jun '06
  • slightly deranged
« Reply #18 on: Sep 11, 2008, 10:22:18 PM »
if you have/can weld just cut it. i ran for a while w/o a cat or muffler. it was extremely loud, especially without doors, it would set off every low rider's alarm too  :gap: but its not a huge deal.
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #19 on: Sep 12, 2008, 06:15:28 AM »
more alpaca Drama  I scraped my leg with a wheel  brush lastnight luckily I had on a pair of Kakee work pants that kept my leg from being cut open I was like omg watch what your doing Jeff :smack:  but I did get the driver side spring off I had to sawzall the exhaust pipe off so that i could get the impact on it I know I am going to have to get a small bend in the pipe to clear the new rear spring hanger bolts for the front cause the old set up made the nut get to hot and it got warn down on the side that was facing the pipe I will try to get some pix this weekend my cell phone died on me and couldnt get pictures. but never fear I will get some pict of the old bolt and also from the other crap I did as well
I also played with the torch a little and cut off the stock bump stops and also the old stock shock towers I will get some pix of that as  soon as I can I will be busey tonight with a High School Football Game  but Sat and Sun I will be free. with a fully charged phone
[img]http://bo
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« Reply #20 on: Sep 13, 2008, 10:46:48 AM »
wow i love the doors  im so in love with you right now
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #21 on: Sep 13, 2008, 11:01:05 AM »
well i have some updated pict. for everyone. I didnt have to much to do this Saturday morning however I am well aware of my dead line. (twins birfdays) :woohoo:
this is the bolt that someone  :dunno: put way to close to the exhaust pipe and burnt the end down  :screwy:
In this picture you can see that I have cut off the old bumpstop  but Ihave not grinded it down smooth
In this picture you can see the Old shock mount after I have cut it off I havent goten to close to the frame untill now I used the troch to get as close as I could with out cutting a hole in the frame.
this is the drivers side bumpstop after i cut it and before I grinded it smooth
dirvers side before I grinded it smooth
this is where i had to cut the exhaust to clear the stupid bolt :shake_head:
this is a pict of the exhaust (in case you have never seen one)
this is a picture of the passenger side bumpstop after I grinded it down smooth
this is a picture of the passenger side  old shock tower after I have grinded it down smooth
passenger side before I grinded it smooth
 :yikes: I got to close with the  :flamer: and I cut a hole in the top of the frame  :nerv: I guess I will have to fill that up with a welder   :smack:
passenger side bumpstop grinded down smooth
drivers side top after I grinded it smooth
passenger side grinded smooth and painted to keep it from rusting
passengers side old bumpstop painted to keep it from rusting
passengers side old shock tower area painted to keep it from rusting
 :sad2:  Oh the sweet bitter end I have no Oxygen  I cant go any further with the torch cause i dont have anyone in the local area that has any mind to open up on a saturday morning and sell oxygen :down:
« Last Edit: Sep 13, 2008, 11:12:20 AM by maxwe001 »
[img]http://bo
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #22 on: Sep 13, 2008, 11:25:01 AM »
Posted by: 93rubNtugtoy    wow i love the doors  im so in love with you right now
 :headscratch: SORRY PAL I AM NOT :gay:
[img]http://bo
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #23 on: Sep 13, 2008, 11:49:34 AM »
lol  we do have  a "quote" button.
don't worry about the hole in the frame  I blow holes in metal all the time when welding or torching.
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #24 on: Sep 13, 2008, 11:58:25 AM »
it was too slow I had to hurry up and I thought cut and paist
[img]http://bo
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #25 on: Sep 16, 2008, 06:22:38 AM »
more updates
1st. I finaly got a buddy of mine to come over and help me I put his :moon: to work with a torch cutting some off of the front axle. then I made his :moon: grind down what he had cut as you can see from the pictures.
after all that grinding I told him we could hang the front springs through the frame
I was hopeing that we could have gotten a chance to put the front crossmember up and have it clampted into place however we didnt cause we have not cut the stock old leaf spring mounting place loose on the front. we will try to get this done asap maybe we can cut them off on Wed. of this week  :dunno:
[img]http://bo
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #26 on: Sep 16, 2008, 06:16:53 PM »
woot woot! hey they was short on one knuckle scale, so i made the switch it to a snap ring pliers... that id need.
ill get ya bud :thumbs:
Dr.Maxwe001 [OP]
  • Male Posts: 627
« Reply #27 on: Sep 26, 2008, 01:16:42 PM »
its no biggie I can wait besides i got bigger fish to fry
here are some more build up pict
passenger side  buddy of mine got a little cocky with the torch :thud:
driver side  what I looks like after I grind it down smooth
front view drivers side
pass side front view
close up of the "hole shot" thats gona be coverd up so no worry
 this is a shot looking down the front from the driver side to the passenger side  *** notice how smoth and flat it is ***
 close up of the drivers side
drivers side cutting job  :thumbs:   :clap2:
this is a shot of what a real working man loks like after he has been playing with his toys
[img]http://bo
GJToyotabug
  • Male Posts: 969
    • Alcan Spring
« Reply #28 on: Sep 29, 2008, 06:43:52 AM »
oh man the truck is coming along isnt it? i really like it
GJToyotabug
  • Male Posts: 969
    • Alcan Spring
« Reply #29 on: Sep 29, 2008, 06:44:44 AM »
oh is it page 2 yet? ha ha you need to do more work ha ha and more pics
Last post Jun 13, 2005, 05:34:23 AM
by UNBREAKABLE
Last post Oct 28, 2019, 05:17:38 PM
by Rockcrawlintoy
Last post Feb 15, 2013, 06:17:02 PM
by h0nke
Last post Jul 12, 2013, 04:42:44 AM
by gottadog
Last post Jul 21, 2022, 02:37:30 PM
by toyodaaddict
