Tylers 1981 Toyota Trekker Build
Started by GotMyYotaBack, December 29, 2009, 04:05:00 PM
GotMyYotaBack
More;
More ride height, like a complete dumb azz  :smack: I forgot to take ride height, and wheel base measurements before.
This is the hanger we may have to move back.
Trekker Build- http://board.marlincrawler.com/index.php?topic=64943.0
Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteer be at the rghit pclae. The rset can be a total mses and you can sitll raed it wouthit porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe.
So dont tell me I spelled it wrong! You knew what I ment.
Jud
Quote from: GotMyYotaBack on February 02, 2010, 05:03:46 PM
6, and that was the issue, to get it any better I would have to take it lower and I didnt want to do that. I sure as hell didnt want to start over for the 4th time and it was getting late, Tyler and I were committed to getting it assembled and hung by Sunday. Its gonna get an ARB later, maybe I can take another stab at it then
Yea I fully understand that. haha After they break in it will be like 9-10 which will be perfect. I hate setting up gears too. lol
"bout tree fiddy"
Jud
I would leave the hanger there so the tires don't eat the firewall. Shackle ange isn't super bad, I've seen WAYYY worse plenty of times...
"bout tree fiddy"
Dan id leave that hanger..... it looks perfect to me... remember the front is "raked" up... not level (the frame that is)
GotMyYotaBack
Thanks Jud, Thk90 what do think of the shackle angle alone? I like the ft hanger where its, I just wish I had about ten more degree's at the schackle.
the angle of your dangle looks good. here ill rotate your pic to make your frame level.. so u get a better angle..
Jud
^^^Another person you should NEVER listen to^^^
Check out his "builds"
"bout tree fiddy"
Quote from: Jud on February 03, 2010, 05:27:48 PM
You aren't god dude, shut your mouth.
You never have anything nice to say... TO ANYONE!
and its getting pretty old.
Rockcrawlintoy
haha thats great
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Hyena
Nice :D
Doof
:beerchug: and :beer: to that one brotha hahahah
GotMyYotaBack
Got the steering gear box installed last night. Both of my wrists are soar from a non variable speed high power makita 1/2 drill  :stopit:
I think this truck is gonna settle a little lower when we get the rear back on the ground, I am guessing a flat arm is gonna be in my future.  :driving:
GEARED UP
Jud
Yea a flat pitman arm would be perfect with that setup. I never ran one because of the angle I had on my box. I had set it up so everything would clear just fine with the stock pitman arm.
"bout tree fiddy"
GotMyYotaBack
Okay made some more progress, the rear is in. Finaly got a chance to see final ride height, and its perfect!!  :driving: These are stock chevies, no added springs, just 3 springs and no overload. 2" Aluminum rear block and she sits level!  :greengrin:
Shackle Angles are Perfect IMO
Front:
Rear
GotMyYotaBack
If your doing Chevies, and you dont want a scissor shackle, then I recomend the Sky kit, it is the only one (Andy) found that had all the holes drilled for the smaller 9/16 Chevy bolts, and It came with those bolts too. I drilled the tops out to fit a 18mm greasable shackle bolt and used a johnny joint at the frame.
Here is the rear diff pattern.
Threw a lunch box locker in aswell. Thanks Mike  :wave:
Jud
Front shackle angle looks dialed.
On the other hand, I have those same Sky-Manu spring hangers and shackle plates both brand new with bolts sitting in a box in my closet. lol
"bout tree fiddy"
4x4yota
i cant wait to do my chey rears  BTW datinfab sales just the spring hanger for $29(pair) and all other pieces individual!
Current:
Sold:
4Runtoy
Can wait to see this trecker finished.  :beerchug:
4x4yota
what gear/ tire combo you running or plan to run?
Current:
Sold:
studentwheeler
Dan, not sure how well a satin black paint job would hold up wheelin...the pre-lim research on the net looks like it is real hard to care for. Shows everything and if you try and rub anything out the satin will turn to gloss and you'll have a shiny spot.
Anyone paint their rig satin black and have it hold up well to the abuse of wheelin?
GotMyYotaBack
Quote from: 4x4yota on February 08, 2010, 07:30:27 PM
529's and likely 37" Would love a set of BFG Crawlers, will have to wait and see how the budget recovers.
GotMyYotaBack
Quote from: studentwheeler on February 08, 2010, 10:47:41 PM
Maybe the better angle is black primer, wet sanded. That should give it the flat black rat rod look. Or maybee will have to lean on Tyler to pick an enamel :)
GotMyYotaBack
Quote from: Jud on February 08, 2010, 10:46:13 AM
Can I just get a current inventory sheet, so I stop buying things you have.  :smack:  :greengrin:
4Runtoy
I painted my truck black, no clear coat and its really easy to maintain beside it looks sick. here are some pics.  :biggthumpup:
GotMyYotaBack
4RunToy, what paint is that, and how did you apply it?  It looks great!
4Runtoy
#86
Actually I took it to TJ and got the body work done , they sand it remove all the dents and painted for $250.  :biggthumpup: (no clear coat)
Jud
Quote from: GotMyYotaBack on February 09, 2010, 11:07:50 AM
HAHA I'm almost out of parts, sold my last Toyota axle parts last night.
"bout tree fiddy"
GotMyYotaBack
Quote from: 4Runtoy on February 09, 2010, 04:54:38 PM
Who is TJ?
TheCookieMonster
i love the trekkers, saw one on craigslist a while back and wished i had the money. yours is coming out sweet, gonna look really good with some bigger tires on their  :beerchug:
