Making Of The Willy Mammoth
Started by Willy Mammoth, November 18, 2004, 08:06:16 PM
0 Members and 114 Guests are viewing this topic.
Willy Mammoth
#30
Well I sawed the housing apart and started milling them down to the proper size. I will continue in the morning and try to get it welded back together.
reklund5
Wow!!!! Now THAT is some custom fab!!!!  It looks GREAT!!!
Ryan
Lady Di
#32
A quick update, Mark's finished milling the housing and is now out in the garage :flamer: welding the two halves back together with the tig. WOOT! He's da man! :smooch:
Time to start researching trail ride jamboree's! Time's a wastin'  :driving:
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
Willy Mammoth
#33
  :idea: I know, lets try to cut our finger off with the band saw.  :yupyup: Well the band saw isn't my first choice for cutting finger nails but it will work and quite well I might add. That only slowed me down a little bit till I could tape it up and back to work. :_oops2:  Any way the welding is almost done and then its on to setting up the shifter linkage.
Willy Mammoth
#34
 :flamer: More progress to report. I located the proper steering box for this project and now have it installed. The frame hade to be plated on both sides and bushings needed to be made to support the frame from crushing where the bolts goe through. I plan to finish plateing the other frame rail tomorow and start mounting the springs to the frame.
Willy Mammoth
#35
Mor Pics
Willy Mammoth
#36
Even Mor pics
Hey man, come on, this is your HOME GARAGE? Geeze.. Tig welder, Drill Press, Band Saw, LATHE,  :conf:  :conf: Plus more!!
You got it made in the shade! :bowdown: very nice very nice :gap:
Hmmm did that tierod end for a fj80 have the same taper as the scout pitman arm??  If so Im in luck!
Willy Mammoth
Quote from: WHITE_TRASH on December 18, 2004, 10:52:47 PM
Not yet, it is a little larger. I am going to make an insert to weld into the end that will fit. I may also need to shorten the arm or not I haven't decided yet.
Willy Mammoth
Big Mike,
I started collecting this stuff when I was knee high to a grasshopper and have had my own body shop since I was 23. Started hacking up cars at 15 and haven't grown out of it yet. I am always looking for the easier way to do things hense the tools. Now I whish I had a shop again to spread out. I would like to be able to get into some kind of custom fab work because I enjoy making things. I may have to do a history of on my web site and show off some of the things I have done to date.
Thanks Mike, I would like to be able to meet you guys, But I am way over here on the east cost. Maybe some day.
Lady Di
He likes to make things! He certainly has a way with the understatement! He is one of the most inventive people I have ever met. I have been working  :whip: alongside him in the bodyshop business, fabrication business and on our own projects, for about 14-15 years now, and he never ceases to amaze me.   :cheer:  :smooch:
And wot he said about meeting youse guys one of these days. :beerchug:  I believe a road trip is in order in the not too distant future.  :driving:
Willy Mammoth
#42
More progress, Well we now have the front end mounted to the frame and off the jackstands. :banana:  I spent the day making spring hangers and shackel mounts.  :hammerhead: I finished plating the right side frame rail and welded the spring hangers to the frame.  :flamer: Mrs WM cleaned the steering box and painted it. :whip:  I have to make the same hangers and mounts for the rear springs this week. :hammerhead:  If my parts all come in before Friday I will be putting the engine in this next weekend :crossed: Soon we will be  :driving:  :beerchug: and not the other way around.
Willy Mammoth
#43
Rest of the pics
Mike D
Man that is gonna be awsome and nice work  :biggthumpup:
Flatjeep
Flatjeep
Ok either my typing is way wack or something is up.  I thought I said  This was was cool but it came out all wacked.
Willy, that is a cool idea about making an insert for the box.  That is the same steering box Im using on my latest truck, its also got the same pitman arm.  Its a 2" drop aftermarket arm.  What size are you planning on for the od of the insert?  I will be drilling my pitman arm out to 5/8" to use with my allpoo high steer.  But once I get Marlins steering Ill be needing an insert of some sort.  If youd be willing to make another one Id gladly pay you for it.
Flatjeep:
lol, go into your profile and change the user options to not edit your "cursing".
Flatjeep
  Oh.....  makes lots more sense now  thanks
Flatjeep
Hey Willy Mammoth are you goin weld all the way around those spring hangers or is that enough weld to hold
Willy Mammoth
#50
Quote from: Flatjeep on December 19, 2004, 08:41:24 PM
That is just a heavy tack, I hate having to cut my welds to move somthing. I want to get all the weight in this before welding it completely. I also need to plate the inside of the frame where the hangers attach.
Quote from: WHITE_TRASH on December 19, 2004, 08:31:02 PM
Check with Marlin, The pitman arm that comes with the high steer kit has been done like this, Not my idea. If he can supply the insert it would save both of us a lot of time. Mabe he could offer this as a service.
Mark
To The Floor
This is one of the coolest Jeeps I've ever seen.  Stock Jeeps are pos's in my opinion, but when you go and put new running gear in em' I think they're sick.  You couldn't have picked a more perfect drivetrain to put under one of the sweetest Jeep bodys ever made!
KYOTA
coming right along, you do nice work 8)
88runner
#53
the spring goes at the bottom and the hanger on the frame  :slap:  :slap:
:hahaha:
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
Willy Mammoth
Quotethe spring goes at the bottom and the hanger on the frame
:doh:  :working:  :smack: Good thing it isn't done yet! :ha_ha:
That picture was to show the home made shackle mount :greengrin:
Thanks guys for your kind words. I think it is pretty cool too. I realy like the old willys body style and I have always liked the Toyota running gear, What a combo, the best of both worlds.
:beerchug:  Merry Christmas to all out there in Marlin land. :crazyhappy:
Willy Mammoth
#55
Well thanks to UPS  :moon: we did not get the engine in as planed. My parts are burried in a trailer at the distribution center and they would not dig for them on Friday. I had called them way before to setup things for picking them up, but that was a waste of breath. So I did get the steering shaft made up and working. The steering collum comes through the floor too low to be able to connect it to the box so I had to make up a carrier bearing to correct the sharp angles. I also got the rear springs connected to the frame and there are no more jack stands. (It's free to roll)
  " Free Willy"  :ha_ha:
I am hoping to have a couple of early days this week so I can get the engine in before this weekend because we have plans and I won't be able to work on it at all. :crossed:
I hope everybody had a good Christmas and will have an even better New Years. :beer:  :beerchug:  :driving: and not in that order or you may end up in :jail:
:party:
Willy Mammoth
#56
More pics
mudguts
#57
Willy, you look like you could use a couple or 12 of these  :beer:
You do nice work , and so does The Mrs. You guys make a fine fab team  :thumbs:   :beerchug:
:turtle:  :turtle:
:nerv:        :turtle: I love T.I.T.S. :turtle:
MikeySBF
Lady Di
Quote from: toecutter on December 27, 2004, 01:49:52 AM
:turtle: :turtle:
:acclaim: thank ya, thank ya very much. It's a labor of love :cheer:
oh, and btw...that's not coffee in that mug in front of Mr. Willy  :eyebrow:
