Author Topic: what should i do with my new 1985 4runner with blown engine.  (Read 3238 times)
cormuff
  • Member since Nov '09
Well i recently picked up a 85 runner that is currently not running.(blown head gasket) should i do the work and invest the money to fix it? or just scrap it an do a motor swap now:-) which motor would work well. im new to the toyota crawler scene so as usual im tryin to soak up some knowledge and make the best descisions the first time around:-) all answers appreciated.
thanks
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Member since Oct '06
  • Raised suspension
If it a 22re I would just rebuild it and call it good, or find a good low mileage one and swap it.
mayberry
  • Turtle Points: 10
  • Male Posts: 707
  • Member since Nov '07
where are you located? i have a 22re and every thing you would need to make it run
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Since you bought it this way and may not know the history of the engine and how bad it was a full swap would be in order.
cormuff [OP]
im in san diego. u close?!:-)
cormuff [OP]
no one thinks i should just do the v6 or v8 swap?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
no, if you want to crawl you want to keep the 22RE
i'd pull the head and see what the inside of the cylinders look like.  if the pistons are good and snug in their cylinders just do the headgasket, if they will wiggle around and the block is scratched, then  a full rebuild or swap is in order,  but do yourself a favor and keep the 22RE
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
if you want more power than a 22re swap in a 3.4tacoma v6 it all depends on how much you want to spend
  • Momentum Man
  • Lego Enforcement
If you are thinking of that kind of swap a 4.3 or 3.8 V6 would be my suggestion back it up with an auto with dual ultimate's you would still be able to crawl it. If you do the  3.8 swap you could even swap in a T-Type for a bunch more hp. I would say no to the V8 just too heavy.
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
I dont think he had that kind of money in mind when he posted the question. Most likely he has a W56, So I say a 3RZ. But if money is no object, well then toss a 1UZ and auto trans in and be done with it.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
Travis H
  • Turtle Points: -367
  • Male Posts: 789
  • Member since Sep '08
  • 5100 ft
3rz swap.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Best bet would be to do a little research on the motor like Glen said.  If it's questionable, then swapping in a 22r is gravy.  Or build the block and get a http://www.engnbldr.com/ head and run a better exhaust.
We really need to know how far your willing to go to "swap" a motor.  Cause you can really dump a ton of money into a swap, and then there is the smog?
bigarms23
  • Male Posts: 2,897
so what did you decide to go with
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
drayday55
  • Turtle Points: -1
  • Male Posts: 299
  • Member since Feb '09
im in spring valley if you need help,
85yotabox
  • Male Posts: 218
  • Member since Apr '07
  • shitlbuffout
3rz!  i was a bit hesitent when doing it but im almost done and it was a lot easyier then i thought!!
Chicks dig body damage!
build it to beat it!
_____________________
[  ]===TOYOTA===[  ]
my build:  http://board.marlincrawler.com/index.php?topic=51558.0
Last post Aug 02, 2006, 09:11:48 PM
by Thomas P
Last post Jan 14, 2007, 10:18:37 PM
by Oregon Crawler
Last post Jul 18, 2008, 03:58:14 PM
by TOYJOETA
Last post Oct 25, 2009, 08:13:42 AM
by 85toycrawler
Last post Oct 08, 2014, 07:06:03 AM
by daniel_holsapple
