thegoofster21 04 tacoma build SOLD!!!!!!!!!!!!!!!!!!
Started by thegoofster21, August 24, 2009, 05:31:52 PM
0 Members and 8 Guests are viewing this topic.
bob or not
bob it
31 (59.6%)
dont bob it
9 (17.3%)
build a bumper
2 (3.8%)
or cut the bottom of the bed and build a bumper
10 (19.2%)
Total Members Voted: 52
thegoofster21
Quote from: dniel on January 08, 2010, 06:59:50 PM
The 9.25 is a pretty stout axle but they are known to have pinion problems. There are also limited gear and locker options. As far as I know 4.88 is as low as they go. I would recommend a D70U. This will have a smooth bottom and not much less clearance than the 9.25. The 70 will be full float and is available in 35 spline stock. Just gear and lock and you will have an axle you will never have to upgrade. You can get an 8 lug 44 to match and everything will be set up to switch out to a front 60 latter if you want to.
thanks for all the info. just not sure on what to do just yet
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
What does a D70U come under and whats the "U" stand for?
dniel
Quote from: THK90 on January 09, 2010, 11:47:47 PM
I don't know what the u stands for I'm guessing it's just a dana code. They are smooth on the bottom and have better clearance than the regular or HD 70. They came in a lot of stuff. 80s ford would be the best place to look. The newer dodges have them but they have 32 spline shafts that neck down at the carrier. The 70u is probably the best compromise between strength and ground clearance. I think the 14 bolt is the ultimate in strength but the ground clearance sucks. I was mainly throwing this out there to point out that the 9.25 is probably not the best choice. I think d60, d70, and 14blt are all better options.
If a lighter weight semi float is wanted then a ford 9" is the thing to look at. Lots of people run the d44 front 9" rear combo on tacoma sized rigs with good results.
1uz-fe, 1 tons, 44" tsl
bigarms23
i looked it up and the U is just the code for the 70 with a smooth bottom diff
good info guys..... thanks for that,
now my sisters old 87 F250 with a 460... had the Sterling FF rear... would i need to look for a F350? :D
yota_krawler
dniel
Quote from: THK90 on January 11, 2010, 11:51:10 PM
I can't say I really understand fords logic on what truck gets what. I think 1 tons with any motor and 3/4 ton with a diesel would be good starting places. That being said any of these trucks could also have a rear 60 or a sterling. I think in the late eighties and early nineties the sterlings became more common and at some point replaced the Dana stuff all together. I think the most common place for the 70u was the vans but these were 71-72" wide. The van width works well with a DRW 60 front and stock backspace hummer rims. This will give cheap beadlocks and SRW width. to get one in the 66-68" range you need a SRW truck.
I did this research a while back before settling on a 14bt so take it with a grain of salt. I got most of the info off of pirate so that would be a good place to look.
thegoofster21
before and after i put my old lift and new one together
jmoffroad.com
bigarms23
thegoofster21
jmoffroad.com
axled89
i love oregon wheelin.
46&2
thegoofster21
Quote from: -Matt- on January 12, 2010, 05:48:25 PM
did u ever change your shity spark plugs?
not yet $8.90 a pice so ill wait intel i get pail again
jmoffroad.com
86bobbedtoy
thegoofster21
Quote from: 86bobbedtoy on January 13, 2010, 01:04:55 AM
love the taco,
u runnin 33s?
plan on 35s?
yea 33s on it now and thanks. 35s would be nice but i need gears before i do anything more. 4.88s and detroit in the rear is what im going for next
jmoffroad.com
P-DiseToy24
thegoofster21
jmoffroad.com
94MtnYote
Marlin 1200LB clutch
thegoofster21
jmoffroad.com
Quote from: thegoofster21 on January 12, 2010, 06:42:53 PM
what u buying a plug plated in gold? thats ridiculous.
NGK G Power Platinums dude... its like 3$ a plug.
PN - NGK 7090
thegoofster21
jmoffroad.com
Quote from: thegoofster21 on January 24, 2010, 04:27:08 PM
thats what the guy told me
tell him to suck a fat one.
they do not cost 8 bucks a plug bro. lol
thegoofster21
jmoffroad.com
Quote from: thegoofster21 on January 24, 2010, 06:31:54 PM
i went to napa ill have to price them out
Bro i buy 98% of my parts from NAPA and I have NEVER paid that much for a plug... and i mean a good plug.. i run good :pokinit: in my engines.. either what factory recommends or BETTER and i always run NGK, WIX, etc... good :pokinit: :D
thegoofster21
jmoffroad.com
