Author Topic: Dual Cases  (Read 2063 times)
TacoCrawler
  • Male Posts: 44
  • Member since Jul '09
Dual Cases
« on: Aug 11, 2009, 01:01:14 AM »
This may be a stupid question but i am just getting into building my rig and a dual case set up is in the near future along with a ton of other work. But What is the advantage to using a dual case adapter theats rotated 10 degrees? Is this to get a better angle on the the drive lines?  :-\ Thanks for the help.
SAS 2002 Tacoma 3.4L, Dual cases, Tons, Etc.
zippo
  • Turtle Points: 550
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
Re: Dual Cases
« Reply #1 on: Aug 11, 2009, 05:56:05 AM »
Front Drive shaft angle
If you see it, its for sale.
micahturner
  • Turtle Points: -2
  • Male Posts: 51
  • Member since Jan '09
Re: Dual Cases
« Reply #2 on: Aug 11, 2009, 06:16:58 AM »
Moves the front output of your transfer up. Helps with clearance.
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
Re: Dual Cases
« Reply #3 on: Aug 11, 2009, 06:58:38 AM »
Yes, if used with a high pinon diff, it will also lifts the lower part of your t case for more clearence.
TacoCrawler [OP]
  • Male Posts: 44
Re: Dual Cases
« Reply #4 on: Aug 11, 2009, 09:59:42 AM »
Ok thanks for the info. Seems like thats the way to go. Also somtimes when I take off from a stop it seems like something binds up in the rear end then pops loose. Any idea what this could be? could it Just be the springs binding or is it something in the rear end?
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
Re: Dual Cases
« Reply #5 on: Aug 13, 2009, 12:11:13 AM »
Are you running blocks? This is a common problem with lift blocks. Make sure the u-bolts are torqued.
87 4Runner redo
TacoCrawler [OP]
  • Male Posts: 44
Re: Dual Cases
« Reply #6 on: Aug 13, 2009, 12:52:18 PM »
No no lift block i will check the u-bolts to make sure. It doesnt happen too often i just dont need anything to break
yjay
  • Male Posts: 555
  • Member since Feb '09
  • SFA Station Wagon
Re: Dual Cases
« Reply #7 on: Aug 13, 2009, 08:37:44 PM »
It makes a more severe front u joint angle. You also have to make your own crossmember as the typical aftermarket ones are made for non rotated cases (I don't believe). They give you more clearance though for sure. I personally did the standard adapter so I could use the crossmember I had and would not have to worry about binding the front u joint at full droop with unturned knuckles. Simplicity.
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
TacoCrawler [OP]
  • Male Posts: 44
Re: Dual Cases
« Reply #8 on: Aug 14, 2009, 01:30:27 PM »
Have you ever had any problem with clearence with it just its standard position? like rocks getting caught on the skid plate?
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: Dual Cases
« Reply #9 on: Aug 14, 2009, 01:58:28 PM »
Remember, the 1-3/16" of ground clearance you're gain will only apply if you have a Front Range Off Road crossmember or some other flat belly cross member. Otherwise, a beneath the transfer case crossmember will nullify the gain in ground clearance, and the only remaining benefit will be a slightly lifted front drive line.
TacoCrawler [OP]
  • Male Posts: 44
Re: Dual Cases
« Reply #10 on: Aug 14, 2009, 02:07:47 PM »
Yea I have been looking at the flat belly cross members. Just a matter of wich way i decide to go now. Also I have a bench seat and could I fit the shifter for the rear case in there and just have it be tight or will I have to change to some bucket seats?
Last post Jun 18, 2003, 05:47:40 AM
by pitter
Last post Jun 23, 2003, 01:32:46 AM
by pitter
Last post Aug 07, 2002, 04:57:01 AM
by BigMike
Last post Apr 28, 2003, 03:22:44 AM
by trdvet
Last post May 07, 2012, 08:17:08 AM
by MT4Runner
