G58 and dual cases
Started by pitter, June 18, 2003, 05:47:40 AM
pitter
well i went to put dual cases in my 93 4cylinder 5 speed and i figure out that there is no was my 21 spline carb case will work with my tranny.... is there a way i am missing or ? if i will be changing trannies.. my dual cases already has a carb case from a 84-88 truck setup as the first case and i have a top mount for the rear... so will my cluch and stuff from my tranny work with a G52? and what do i do about a speedo now?  :sob: i guess i wont be wheelin anytime soon :smack:
pitter
#1
#2
You'r carb case needs to be a 89-95 Forward shifting case. The early 84-88 carb cases have longer rods that will not work with your 93 transmission.
No, the clutch and flywheel of the 93 setup will be larger than those used on the G-trans.
My advise would be to simply change the two shift rods on your Crawl Box to 89+ rods and then your set.
Regards,
pitter
#3
i called marlin and found out i have a 26 spline t case so i need a new tranny that has a 21 spline output. or buy a v6 adapter and they will include a taco 2.7 coupler and then i need a 23 spline t case :unhappy:.... or i guess any tranny that bolts to a 22re and will work.... g52. w56...but then i may have to re-do my crawler box for the dual cases.
