Crazy's 1st gen build up
Started by crazykooter, August 08, 2009, 06:43:32 AM
fordh8r
So...does this mean you're still going?  :crossed:
crazykooter
Quote from: fordh8r on September 09, 2009, 07:52:16 AM
I am working my ass off to get things done so I can go.  Gonna be very tight on money tho.
I have bout 2-3 hrs left on my high steer and 3 hrs or so on swapping my 3rds.  If all goes well enough I can go shopping and pack tomorrow night and be ready to leave early friday morning.
Blah last minute stuff is rough
Jud
Quote from: crazykooter on September 09, 2009, 08:45:30 PM
Get on it! That would be way cool if you get it done and make it all thw ay in to the springs with no/little problems.
"bout tree fiddy"
fordh8r
Quote from: Jud on September 09, 2009, 10:47:15 PM
:werd:
krawler79
Nice truck man! :thumbs: More pics please. :disturbed:
How can I get more flex? That is the question.
fordh8r
Glad to see you made it to the springs Josh!  :thumbs:  Sorry we didn't get to hang out much I was with kinda a big group.  :moods:
Jud
Nice talking with you Saturday. Glad you got it done and had no real problems making it to the springs.
"bout tree fiddy"
ajordan1975
your bob came out really nice.....    :beerchug:
looking good!
crazykooter
Thanks guys I had a ball.  I am gonna head out and make the drive home here in a few mins.
crazykooter
Thought I would update a tad bit.  Tho most of what ive done has been to try and fix my death wobble and drive line vibration.  I think redoing my front bushings solve the wobble.  Need to drive it more.  The drive line vib is better since I got a new shaft but its like 2"s short so im on the very end of my slip yoke which isnt good.  It vibrates some times then fine others.  It has to be the CV.
I installed a new drivers seat which feels pretty good so far.  I cut my original seats up and used them to make the newer seats fit in stock location.
As soon as I can get another front drive shaft and rear plus a spare ill be ready for the con again.   :crossed: :turtle:
crazykooter
Welp I think ive sorted almost all the kinks back out of my truck besides the drive line clinking.  It may be I havent set the rear pinion angle but I get no vibration at all so it makes me wonder.
I finished painting my newer rear bumper I got and plan to install it tomorrow.  Besides that since I am dead broke I will have to wait for any real upgrades.  I do have some left over 1/4" plate I am gonna make axle armor with.  Lord knows after the con run my axles really need it.  :disturbed: :crazy:
crazykooter
Just a little update.  I started hearing things which I thought was coming from the engine compartment but since my truck is rather loud I wasnt sure till today.  It turns out my trans is going out and doing it rather quickly.  Just 2 days ago I heard a slight whine which is why I thought maybe a belt or something.  Well today I was heading back from a friends shop and the whine is more of a howl.  Its extremely noticeable on decel.  Plus I get a chatter at any rpm above 3k.  Sounds like a fan hitting the shroud but its not. Ive replaced engine mounts and trans mount with no luck.  So I pull the boot off my tcase shifter so I could hear if the sound was coming from around there.  Its def coming from the trans. Both sounds are.  So in a matter of less then a week its went from being pretty silent to outright loud.
Not sure how I am gonna get it fixed at this point.  It only has 1200 miles on it, but since I cant really explain more into the new trans thing I will just have to grin and bare it.
crazykooter
Thought I would upload a few pics I took with my cell of the fill and drain plug from my trans.  I rubbed it with my fingers and felt some larger pieces of metal so thats what bothers me most.  :sad2: :crazy:
What do yall think ?
unclejpl4x4
I have  seen worse    can u feel any play or slap  or super noisey      just be glad u have mag plugs  or that stuff would be floating around.  how big are the bigger chunks?
P-DiseToy24
I've also seen way worst in other rigs and my own.  If the other pieces arent any bigger than whats there i wouldnt worry about it.
hilux-1983
Maybe I missed it but, who did you buy it from? Don't they have a warranty of any sort?
crazykooter
What you see on the plugs is most of it but inside that goop is a few pieces that were noticeable to me.  Most of the time its just fine particles which is good.  Either or its whining pretty good in all gears just worse in 5th atm.  Either or I will drive it since I dont have many options.  The warranty is kind of hard to explain.  Well see what happens.
I need to take my rear drive shaft out and take it down to have the cv u joints replaced since I broke our huge bench vise removing another u joint.  Looking for a good Wilton to replace it.
crazykooter
Been a while since ive posted any updates.  yesterday I cut off old front spring hangers and then welded on a front drop bar and welded up some spring hangers.  Today I finished the job by making a set of ruf springs.  Not sure if its lifted any more or not but it def rides better and my steering is correct now.  Im pretty stoked with it so far.  Here is some pics of it.
Plus I got a new to me set of tires and rims.  They were spray painted black which drives me nuts.  The wheels are welds and are in pretty good shape now that ive cleaned em.
fordh8r
Looks good buddy!  :thumbs:
Are you gonna brace those front hangers more?  ???
crazykooter
The front hangers are on very solid.  I was going to make some braces for them for looks but its not really needed.
Its gonna be tough from here on out since I have to drive to byron to work on my truck.  My ole man is pissed off of late and I cant figure out why.
Looks like I may be homeless here in a few days if I cant sort it out.  Oh well teach me to be on SSDI and try to live in california.
fordh8r
I guess what I was getting at is that you may want to box in the end of the square tube and brace the back end of the hanger (as seen in the 3rd picture) to the frame so the openess of the tube won't have the potential of collapsing with the forces that cross section of tubing will see even with normal driving let alone some hard wheeling. that's all.  :thumbs:
crazykooter
Hey all Been a While since ive updated this thread.  Thought I would post a few pics of some newer additions to my rig since MCR.  Still have a lot more work to do but by this summer I will hope to have an E locker front and maybe even one in the rear. All depends on my luck at pick n pulls.
Since MCR ive swapped out the front axle with a fully gusseted hosing, 27 spline Longfields and 6 shooter knuckles and arms.  The rear is still together but I have a 1st gen gusseted axle with alloy usa shafts and a v6 third that has Yukon 5.29s and a Yukon spool in it.  I still need to get a dual case setup but a friend is suppose to give me his after he rebuilds his other set.  Most of the parts ive upgraded with have been a trade basis so its worked out well for me.   I also got some 35x12.50x15 BFG ATs which were like new.   I will be posting some more pics soon as I am taking ALL my drive-train suspension and swapping it to a 79 Yota which besides it being primer it has like 2 dents in the whole truck and its a short bed.  Other nice thing about it is that its a deluxe so it has factory a/c and P/S.  Also have a internal cage already in it.
crazykooter
Just thought I would post pics of the 79 yota I am gonna be swapping over to.  Its got a body lift on part of it but that will come off plus the whole truck is gonna get sanded any dings or dents fixed and then primered till the weather is suitable to spray in.  I plan on removing all the interior and bed so it will get paint inside out.  Also frame is gonna get wire wheeled and painted.   I am gonna paint it a sweet ars red and put a full exo on it to protect it.  Not sure what color I should use on exo tho.  Kinda wanted to stay away from black.  Maybe ill go with a green or something lol. I should be pretty freaked when I take on the trail the 1st time but hey thats what the exo is for.  Anyways This truck should be awesome by summer.  Just need the DAMN rain to stop.   :crazy: :thumbs:
Yota87Truck
BTW those rims break easily if you smack them against a rock.  But you cleaned the paint off nicely.  They look good.
crazykooter
I have a set of steel rims that are sitting there waiting for me to swap them over.  I never planned on using these on the trail.  Would like a set of 37 MTrs for the trail :) And thanks
crazykooter
Just thought I would post a few pics of a few things ive got lately.
1st one is this E locker which needs a need carrier bearing.  Soon to be in the front of my truck.
This air tank a bud gave me and I am gonna be mounting it on the inside frame rail.  Should work great as a reserve tank.
Heres a few random pics of what ive been doing the last few days.  I think this valve cover looks sweet !!
axled89
yea man that engine looks good. :beer:
i love oregon wheelin.
crazykooter
Quote from: axled89 on March 03, 2010, 08:26:58 PM
Thanks I am tired of building engines.  This is the last one im gonna do for a while. Next engine ill mess with is a 3rz to go into my rig.
axled89
83yota5960
mine fell off to its prety comin with 1st gens
Quote from: toyotanner on August 15, 2009, 10:40:51 AM
so i tried to find something but couldn't whats with the cut rail on the tailgate?
83 short bed yota 35's 5.29's 4.7 f-150's arb front aussie locker rear high steer ifs rear axle
83 short bed yota 31 a/t mild lift welded ifs rear axle
99 audi A4 as my new daily driver.
