94 Toy ext cab build: sold... Utah bound on august 8th
Started by yota_krawler, July 28, 2009, 09:40:12 PM
yota_krawler
i think my uncle has one but i will let you know, everything is covered in oil, so i want to clean it and make the motor look good you know. but i dont know what to use. i am new to this :pokinit:
P-DiseToy24
that engine foam stuff from auto zone of ace works pretty tits... carb cleaner works good too  :booya:
yota_krawler
little early for this but thinkon about an partial exo. So my question is which fender do you guys like better?
minicrawlin
ya through the coolant system since thats where the combo of that oil and coolant went. . . just a quick start and then drain then water, drain, then coolant. pretty sure thats how it goes but i'd double check JIC. I dig the first fender with the more cut looks dope!
the rocks Rock in South D SON!
yota_krawler
i like the first pic to, but thats alot of fender gone.
84t0y
i like the first one better, but if it was my truck i wouldn't cut it like that. personally i like to only cut as much as necessary.
Dingman.
Eh just pull the fenders off and tube it.
89sastoyo
cheaipest way to clean parts is use oven cleaner you can get it a dollar stores and :pokinit:. I used it on my t case when I got it and some other parts there were just covered in 90 wieght. Just spray it on let it sit for a bit and hose it off. I works really really well with a pressure washer if you have one but if not a regular hose works to.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
IronClad
please for the love of god dont cut your fenders like in the first pic.. its ugly as :pokinit: and serves absolutely no purpose what so ever on a leaf sprung truck
Annihilation  Fabrication
Do you need a Hammer?
Yota87Truck
I like the lower pic. I especially like the top exo dissapering into the fender.  But I do like the straight cut fender.  Maybe just bring it lower to the peak of the arc.  Make a combination of the two...
yota_krawler
it wont be leaf spung its whole life.
yota_krawler
got the head down to jim putney today. got more problems than anticipated. the timing chain guids were bad so there are massive grooves in the cover, it wore through and thats why i had milk in the top end. So i have to get new guides and a new front cover. The head gasket was slighly blown but it was a felpro so thats a good reason why. It got hot and I am hoping the head is not warped.
yota_krawler
yota_krawler
ya i went down there today. He worked for toyota for 15 years plus or something like that. He builds anything toy. And will build as far as he can if you got the cash
ToYocRawleR
Thats sweet cody! Are you getting your whole motor rebuilt or just the top end?
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
yota_krawler
just the top end, im just getting it to run again. If i were to spend money on a motor it wont be on an 22re!
Befroe I went to work I started to drop the oil pan. EVERY bolt was finger tight. :dunno: guess i have to go through this thing and tighten everytthing up.
yota_krawler
almost have the front cover off. picked up a spare tire yesterday and was going to drill and tap my box but didnt end up doing it.
yota_krawler
so now that i know what tranny i have, what case i have. I know what to do for duals.
Moving on. So My rear axle is bent. I am going to attempt to try and straighten it. The guy who had it before me welded on a ubolt eliminator kit. I think the heat warped the alxe. The ends of the axle are bent up so the tires sit like
/----@----\     Not that bad but you get the idea. If it doesnt work I am going to sell the third and shafts and get a rear 60
yota_krawler
i ordered a magnaflow hi flow cat awhile back and it finally came yesterday. Hella stoked, I ordered it from summit. We will see if it passes  :shhh:
yota_krawler
well if i cant get the rear straight i will be sellin the third.
yota_krawler
so i started to paint it today i got the hood and front fenders, not sure if i like it tho. It is flat khaki. I cant find my camera or i ould take a pic. maybe i can get mike to take one tomorrow.
edit: same color as LBs old taco
yota_krawler
i was going to paint it that color but i like the tan better, i wanted something flat. I painted my s10 and i had gloss blue and it turned out like :pokinit:. some of it didnt gloss, so flat was it. i like the color i just need to finish the whole truck. just the front done it doesnt look right
84t0y
cool i like the idea of doing the 2nd gen sr5 stripe things, also good choice on color.
Dingman.
The tan was kinda sweet..
Once you started getting the truck muddy, the contrast from the mud made the truck look grey.
yota_krawler
I have to get this truck done. I am sharing my wifes car and its lame. I miss having my own wheels. maybe i can get a few guys together and just floppin' go to town and get it done. I would like to go to rubicon 4th of july.
I would be farther along if it would stop freakin' raining I dont have a nice shop to work in. I really dont want to roll in the mud.
yota_krawler
i got a new spindle today at pnp so now i can finish putting my 44 together. I have to gusset the front hanger, repack my front springs, move my box forward, get the gears set up in the front, spool it, make a front DL, get all new bolts for shackles and :pokinit:, bend up an exhaust, put the motor back together, shocks front and rear, fix the rear housing, finish bed bob, get a ubolt flip for the rear, change fluids, bumpers, sliders, smog, and :driving: I think that sums it up.
and paint it
Doof
thats one hell of a list, but its a lot of little things. whats up with the motor?
maybe a few solid days with a good crew. do you want a square front dl? if you do give me your :pokinit: and ill take it school and weld it next weeked
