dude, just have a local shop do a high power rebuild on a stock alt. brodway auto elec in san diego here did mine for 200 and it chuns out 120 amps suppose to be a 100 amp upgrade!no mods needed!!!
I checked 3 repuatable alt shops in sf bay area, and no one would do it...they all recommended te premier power alternator..its a bit pricey for my budget...200$$ is doable, over 400$ ..but im sure their product is exellent
um, your stock alternator didn't put out 20 amps.... so i don't know about 100 amp upgradejust get the bracket from yotatech and get a $80 alternator for a chevy.... problems solved, and way cheaper than a rewired alt, and readily available, cheap replacements should it be needed....
I bought this same alternator (brand new Toyota Denso MR2 100 AMP) from a guy on craiglist for $60. the plugs from the back are exactly the same. the mr2 just a little bigger. see pictures. You will need to swap out the pulleys. Your stock one is a single or V-groove while the MR2 has a wider, flatter groove pulley. Anyhoo, I used an old front bumper bracket, cut it to the appropriate length, drilled a couple holes, added a couple bolts and nuts, 1 hour later, I was done with the swap. the hardest part of the swap was to make the old pulley to fit with the MR2 alternator shaft. the MR2 alternator shaft is slighter bigger I'm running dual batteries so I've noticed it charged up the batteries a lot quicker now. It wasn't a bad mod to do and it was cheap to get from 60AMP to 100 AMP. Give it a shot
i got some brakets from a friend of mine do it matter what year chevy the Alternator come from any sugestions
Started by guywithuglyyota Engine
Started by toy85ota Rig Gallery
Started by THE ROCK Toyota Pickup/4Runner Tech 1979-95
Started by REG535 General 4WD Discussion
Started by 85yotabox Project Research and Build-Ups
