Author Topic: Hybrid Transmission Project! need help please  (Read 1986 times)
22remud
  • Male Posts: 11
  • Member since Jun '09
« on: Jun 08, 2009, 05:30:17 PM »
OK so here is whats going on. i have a 93 Toyota pickup 4x4 with a 22re and a w56, we all know w56 are crap if you beat on them, as mine is in need of a rebuild i am going a new route and i have done a bit of research and have decided for the cost effectiveness and options to do a R-series/AX-15/Dana300 hybrid trans mission set up.i am going to use a R-151F bell housing with a AX-15 transmission and a Dana-300 transfer case. so i know i need a R151f bell housing but my question is what input shaft do i need to work using that combination,the R-151f input shaft or the R-150f input shaft?
1993 Toyota Pickup 4x4 4cyl 5spd
Torsion bars cranked
Fenders and bumper chopped for clearance
33x12.50x15's on 15x8.5 American Racing Vectors
1992 XJ Laredo 4x4 6cyl auto
Front-Procomp arms/3in coils 2 3/4in spacers Rear-b*std 5-6in lift springs
33x12.50's on 15x8 soft 8's
22remud [OP]
  • Male Posts: 11
Re: Hybrid Transmission Project! need help please
« Reply #1 on: Jun 10, 2009, 06:37:16 AM »
bump i need some help from somebody please
dniel
  • Male Posts: 194
  • Member since Feb '09
« Reply #2 on: Jun 10, 2009, 12:59:06 PM »
The turbo input will definitely work. The early model r150 from a 3.0 truck should work and would be cheaper. The later model R150 from a 3.4 vehicle is a little longer and probably will not work.
1uz-fe, 1 tons, 44" tsl
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #3 on: Jun 10, 2009, 02:46:44 PM »
u need to use one that uses the same gear count on the other side of the input shaft on it, they are not all the same, the r 154 and r 150 are different, your best bet might be to use the compleate r150 tranny and the jeep output shaft and tail housing.
Last post Sep 05, 2004, 02:29:03 PM
by Marlin
20/22r hybrid
Last post Mar 15, 2015, 08:33:07 PM
by zippo
Last post May 15, 2005, 02:20:49 PM
by kneedownnate
Last post Apr 15, 2011, 09:11:08 PM
by CaptainRedbeard
Last post May 30, 2016, 05:24:38 PM
by Plainview
