New radiator and 180 stat did the trick. Temp doesn't budge over 180 just running it in the driveway, and no more fuel dripping into the throttle bores.Did the best lean idle adjustment per Weber instructions and truck idles best with mixture screw 3 - 3.5 turns out so idle jet is too lean. Suspect the carb is lean overall so need to order a jet kit. Setup is as follows:Air jets:170 primary160 secondaryMain jets:140 primary & secondaryIdle/side jets:60 primary50 secondaryengine bogs real bad then takes off if you snap the throttle wide open from idle. Revs clean to 5500 - I didn't let it run up past that.Been reading about Weber tuning here and on various different forums and trying to get a handle on maintaining the proper relationship between air and main jet sizing and also how the secondary "idle" jet affects things. From what I can tell, the idle/side jets are important for transition between closed & WOT and also the primary idle jet will affect part-throttle cruising. Increasing main jet size makes the carb richer overall and the air jets can fine tune that to a degree. I might have to invest in a wideband O2...
I see that my thread has been "modded." The gas tank was totally clean inside - not one spec of rust and no sludge/gunk. I was amazed. It did have some small rust pinholes though that came through from the outside and that has been patched.Thanks 79coyotefrg, I'll address your questions here:Block decking: Don't know exactly, but not very much. Enough to make it flat. Not more than .010"I'm in Seattle, so sea-level.I've been working slowly on the carb, one thing at a time which means the idle jet first. It's a 70 now and the mixture screw is now at 1-3/4 turns out for best idle. Part throttle pinging is pretty much gone but every once in a while I still hear a trace of it. Engine doesn't feel like it has the power it should, have to floor it to really get it to go so will start richening up the main & secondaries and see what happens.Timing is still at 10* which judging from what LCE told me should be fine (24 total without vacuum). Could use a little more total but will deal with that later.Exhaust manifold is the original from the 22R, the 4-into-2 setup that has two separate pipes that run underneath the truck and join before the cat. Looks like it should flow decently but definitely not as well as a header which will have to wait a little while. The money gun is smoking hot and needs a rest after ordering suspension today and also replacing the power steering pump and pressure hose. Work is kind of on-and-off for me as my company is between big jobs right now. Should be plenty of hours coming in a month and if there's overtime that = header.I have a 20R distributor but it has the dual vacuum ports. I'll get around to playing with it soon.Thanks for all the input. Should I start a project thread for this truck? I have quite a few pics of the engine assembly and other stuff here: http://s114.photobucket.com/user/willhbaker/library/Misc/car%20stuff/Toyota%20TruckAdding more pics as I go.
Drove it to work today and it was a warm day, upper 70s, and it ran fine. It's now way under-geared though... I was cruising 60 MPH in 4th gear at ~2900 RPM. The speedometer has approximately 15% error. Shifting to 5th dropped RPMs to ~2200-2400 which is only doable on the flats.
Started by Twisty Rig Gallery
Started by yoter Project Research and Build-Ups
Started by 70 Cam Guy « 1 2 » Project Research and Build-Ups
Started by 22remud Project Research and Build-Ups
Started by CaptainRedbeard Project Research and Build-Ups
