about how much HP gain do you get from doing the hybrid vs stock 22r ?
Not much really, maybe in the 10hp range. You'll doubtfully feel it, you'll just notice it'll pull longer and may find a little more power pulling hills. And glen, you know hp won't break a speedo cable
do you still get all the gain's if your running propane?are they any more write ups on this hybrid thing....i amy in the process of building a motor and want to do it right the first time..and i dont know what to do now...any advice...i have a 22r 81 thur 84 model so what do i need to get and do....thanks brian higdon..
you need a 20R head and intake, also run the 20R, or very early 22r dual row timing chain
ok head and intake... easy to find...how about a cam and vales i got a little lost in that part of this thread.... looked at lce and there cams were like 399.00
Helps to find a 20r head with a fuel pump boss if running gas. Not all had them.
Why'd you go .010 and .010 on intake and exhaust?
can you bolt a 80 model 20r head on a 93 late model engine?
There definately needs to be a tech write-up on the 20R/22R. There is alot of info and alot of opinion and it is all scattered out. It's hard to tell what is tech, what is opinin, and what the actual process is... It would be awesome to see it all in one tech thread.
agreed http://board.marlincrawler.com/index.php?topic=57960.0
would an adjustable cam gear be recomended for a cralwer or is a weak link i should avoid?
Started by 907yota Toyota Pickup/4Runner Tech 1979-95
Started by hotrod Engine
Started by 22remud Project Research and Build-Ups
Started by 82 HiLux « 1 2 3 » Engine
Started by Jokeass-Wheelers Toyota Pickup/4Runner Tech 1979-95
