tons 2rz three link front. Now slamming on its nuts spring under rear!newpics
Started by 89sastoyo, March 15, 2009, 11:46:16 PM
GrenadedToy
89sastoyo
Quote from: GrenadedToy on December 31, 2009, 01:00:05 PM
I dont see a shaved 14 bolt.
Really? I took like an inch or more off in spots  I didnt cut the bottom and completely shave it but I did the normall 14 bolt shave.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
GrenadedToy
Grow some balls and cut that pig up!
Dont know if you saw this link in that FAQ
Shaving the 14 Bolt
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=116745
it never shows how that bottom lip is sealed...
89sastoyo
yeah I would be mroe down to do that it there was some more info because I don't want my cover to constantly leak.
92 2wd DD
first gen cab
crawln503
mines shaved and it has a "CUSTOM" diff cover too :talkingn: and i havent had any problems with it leaking
-when i brought my ghetto fab axle home :gap:
-85 ext cab swap on std Toyota frame, 3rz, built narrowed 6 lug 60's duals/4.7 42's iroks
-94 Ford CCLB 12v. 6spd, pump cranked, guages, lifted & lots of other mods:smokin:
-89 ext cab Toyota, 3.4, 5spd on 33's
89sastoyo
joel when i get those studs maybe ill bring them over so i can check out that 14 bolt a little better.
Just curious with the 4deez how much ground clearance do you have to the bottom of the diff?
92 2wd DD
first gen cab
Jud
Quote from: 89sastoyo on January 01, 2010, 07:14:34 PM
Wondering the exact same thing, I have 40" MTR's and I'm up in the air about trading them for some 42" IROCs...
"bout tree fiddy"
89sastoyo
Jud were you going to shave your 14 bolt to? I just did some mild searching on google about shaving them seems pretty easy actually im probably going to do it but I don't have a ring gear in my 14 bolt so ill have to get my gears set up first.
92 2wd DD
first gen cab
Jud
Quote from: 89sastoyo on January 01, 2010, 08:25:39 PM
I'm just gonna take the nasty lip off the bottom for now. Mainly because I'm just gonna beef up the stock diff cover and it isn't beef enough to stay sealed without the lower cover bolts.
"bout tree fiddy"
89sastoyo
for sure thats what I did my buddy took the pictures of it so you cant tell much but mines smooth from axle tube to axle tube so there isn't a lip at all. I don't have a pinion or cover so I'm not to sure what im going to do about that whole situation.
I think your mtrs are really close to the same height as 42" iroks. like maybe an inch difference, I could be wrong but at a local offroad shop there was an 40" mtr and a 42" irok under the table and they were both touching the bottom of the counter.
92 2wd DD
first gen cab
Jud
Yea but mounting the 13.50" wide MTR on a 9" wide wheel plus the beadlock so a 10" wide wheel, verse mounting a 14.50" wide IROC on the same 10" wide setup I think the IROC will be taller.
My buddy runs 40" MTRs on 9" wides with beadlocks and they are about the same height as another buddys 39.5x14.50" IROCs on 8" wide wheels...
"bout tree fiddy"
89sastoyo
Yeah thats true for sure. how'd you already find wheels? I cant find any to save my life so im gonna have to buy some new I think. But iroks are legit just not as many people are running mtrs any more.
92 2wd DD
first gen cab
GrenadedToy
Quote from: 89sastoyo on January 01, 2010, 05:25:54 PM
Its called RTV
89sastoyo
I read up on it, it just seemed sketchy since there was no bolt on the bottom but I found out how I wan't to do it I just have to get my gears set up first so I can see where the ring gear sits ya know? I wanna buy a full 14 bolt swap kit from ruff stuff though thats pretty sweet comes with u bolt flip diff cover and the spring perches and disc brake brackets.
its a deal but I dont wanna buy it and not use the diff cover. There covers are cool I like them but I guess I could try and order it with teh diff ring and build my own cover.
92 2wd DD
first gen cab
yota_krawler
42 in iroks are only a half inch wider than a 40 mtr
toyotanner
text me when you're working on stuff out at the casa so i can stop by and be cool...
you always call casey but never me :rivers:
86bobbedtoy
89sastoyo
Quote from: toyotanner on January 04, 2010, 08:45:29 PM
Will do for sure when do you work now days? nights or days I forgot lol.
Last night I traded my gsr leather seats for some corbeau seats with mounts. They mount on a tubing thing that goes behind the seat and has mounts for harness's and is build around the tunnel and what not. MY buddies camera has pictures so ill post em up when he send them to me.
92 2wd DD
first gen cab
toyotanner
working mon-fri days right now... but might be going to swing shift mon-fri
89sastoyo
nice well yeah ill hit you up when ever I go out there. I am basically going threw everything just doing maintance :pokinit: right now since I haven't been keeping up on it lol. And then im going to start getting stuff ready for the swap.
Here are a few pictures of the new set up.
This ones the tubing and everythign but in the 2nd gen x cab I got them from, in my truck the back mounts are basically right against the rear seats.
And here they are mounted in my truck
I am still tryin to get the pics from my buddy to show how well they fit my subs are snug against the back and fit perfect I also and trying to build a center consol the mount in the center cause theres two pieces of tubing parallel it would be perfect to mount to. one thing is they seem lik they were made for something more narrow like a car or something so I may use this for a while and then build something simallar to fit my truck a little better.
92 2wd DD
first gen cab
yota_krawler
you will be stoked when you get the axles under it!
how are you going to do the hanger and shackles?
GrenadedToy
when your done you can sell them to me  :gap:
looks sweet by the way.
89sastoyo
Quote from: yota_krawler on January 05, 2010, 09:35:00 PM
honestley probably like yours and the shackles I was thinking can I use my boomerangs and put both the spacers on one side? wouldnt that be pretty much the same thing as sky ones? I really like how my truck sits and it will sit higher without those
92 2wd DD
first gen cab
89sastoyo
Quote from: GrenadedToy on January 06, 2010, 12:07:16 AM
For sure and thanks you gotta see it in person and how clean and tight everything fits im really stoked like my interior was something that has never impressed me. I mean it still isnt nice or anything but I just like how that eliminated :pokinit: floating around all over the place its just a million times more legit
92 2wd DD
first gen cab
gnarrkill
79 toyota duals,caged,40 mtrs
89sastoyo
haha for sure dude there really nice just kinda sucks to look out the window and to get in and out of
92 2wd DD
first gen cab
89sastoyo
here are some more pictures of the seats and bracket there mounted to
hids
92 2wd DD
first gen cab
