tons 2rz three link front. Now slamming on its nuts spring under rear!newpics
Started by 89sastoyo, March 15, 2009, 11:46:16 PM
swapped89
did u get a tube bender? im doin hydro assist soon and wanna put the ram kinda infront of my axle like a full hydro and need a hoop. i'm doin it this way toi keep the ram out of my oil pan. O and your truck is gonna be bad @$$ on 1 tons.
P.S. how is max's truck?
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
89sastoyo
its still the exact same he's ordering a mc and stuff for his breaks because they won't blead.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
89sastoyo
and I haven't got it yet i should by next week or so
92 2wd DD
first gen cab
89sastoyo
got my 60 today the things wieghs a million pounds haha but got it none the less. Ill post some pictures of shaving the 14 and some other stuff in a couple days
92 2wd DD
first gen cab
toyotanner
chevy or dodge front 60? how much? do the gears match the 14 bolt?
89sastoyo
well considering the 14 bolt is gear less id say they wont match ahha. but its a chevy king pin 60 stock 410s has pretty much new brakes on it and looks fairly clean. I bought it for 700 and im buyin the ballistic steering arms from the guy for 75 I was hoping to talk him down to six but I still got a deal considering you cant find one for less then 1200 unless its a dually 60.
92 2wd DD
first gen cab
GrenadedToy
Dana 60 = Hernia
I always think about doing the swap, til I pick one up..
89sastoyo
I know man haha I have no idea how Im going to mock that :pokinit: up haha its gonna be retarded ill have to get a bunch of dudes to help lol
92 2wd DD
first gen cab
89sastoyo
so for this build im going to try and keep a price list going to see how much i am into the swap.
so heres the list.
d60 700$
14bolt 12$
5.38s 400$
ballistic arms 75$
all the steel needed including steering 200$
rear disc 225$
I dont think theres much more minus the little things to convert the break lines im planning on running hard line with sae fittings on one end and toy on the other for the front ill by the adapters.
d60 to toy flange and 14bolt to toy flange 400$
so with that said haha adds up fast but ill probably try to keep it around the 2g mark and build as much as I can. I was going to link it but i think ill just throw it on the leaves i have now untill I can afford a link set up.
I'm gonna rock it welded F&R for a while untill I can't stand it anymore and can afford a selectable. My plans for linking it are moving the front axle forwards like 5 more inches so Ill have full hydro and the welded diff wont matter lol.
so my ball park is around
92 2wd DD
first gen cab
GrenadedToy
heres some motivation.
One Ton Toyota Bible:
http://www.pirate4x4.com/forum/showt...82#post9648282
dont forget:
-bigger master cylinder
-go to post  #7 on first page,  save you LOTS insted of buying those spendy diff flanges. funny how 14 bolts are super cheap, but the 14 bolt to toy flange is like $250?
PS if you want help shavin the 14 bolt, Im there.  :biggthumpup:
83 Crawler
Quote from: GrenadedToy on December 29, 2009, 01:02:25 AM
dont forget:
that link doesn't work ryan
89sastoyo
haha Ishaved it last night actually.... haha I thought I worked in the morning but I worked at 4 so I went back out there and shaved it up i was going to post pictures right now but I believe im giong to go rally in the snow instead hahaha.
92 2wd DD
first gen cab
83 Crawler
its a long ass drive to your house man! idk how you do it so much
GrenadedToy
gonna shave the front to match?
toyotanner
if i had 60's it would be welded front and rear... <--- reliability and cheap... IMO
89sastoyo
I have to search more about shaving the 60 there pretty wierd there like shaved on part of it already kinda and then the bottom 2 or so inches sticks down its really stupid but ill search and look into it for sure.
I know its redic dude I have put 20 thousand miles on the crv since july haha. but I can't live out here since I work in town but I try to come and go as least as possible and make trips for a reaason ya know?
and for sure I mean with the strength of a 60 I don't see a problem other than steering it which im hoping to fix as soon as I can. I wanna do hydro asst but i dunno since im planning on running full hydro when I link it.
also just counted the ring and pinionh on the 60 and its factory 4.56s its not a dually axle either im pretty stoked about it even know im not planning on running those gears it just means i got even better of a deal than i thought.
92 2wd DD
first gen cab
83 Crawler
#558
20k! :yikes: thats crazy i would like to know how many miles your dad has put on his truck lol
still got that door  :crossed: and i got some bones for the tranny
GrenadedToy
89sastoyo
im going to keep my toyota axles complete only selling the wheels and tires for 42s.
and yes and yees haha when do you want the tranny?
92 2wd DD
first gen cab
89sastoyo
heres some pics
and heres some of the 60
lift block? assuming it was on a lifted truck
92 2wd DD
first gen cab
maybe to get the steering to clear over a lift spring?
83 Crawler
well i need to figure out what im going to do about the drive lines.
any ideas?
89sastoyo
uh depends on how much longer it will actually make it ya know? might just be different how it mounts or somehting I have no idea to be honest.
And THK I found out what its for its basically to help the steering out and compensate for the lift, just like a drop pitman arm would for a toyota with push pull.
92 2wd DD
first gen cab
mattlosch
just watched the news.. heavy mtn snow tomorrow. we gotta hit it up friday
1983 caged, 22re, slammed
2006 cummins 6spd... somewhere around 750whp for a tow rig
Quote from: 89sastoyo on December 30, 2009, 06:09:14 PM
Thats what it looked like to me.... how cool.
83 Crawler
wanna just do the swap and see whats up after that?
89sastoyo
im thinking thats kinda what you'll have to do.
92 2wd DD
first gen cab
83 Crawler
can i do it at your place? ill wait till matts :pokinit: is out and your trailers done.
