tons 2rz three link front. Now slamming on its nuts spring under rear!newpics
Started by 89sastoyo, March 15, 2009, 11:46:16 PM
0 Members and 8 Guests are viewing this topic.
89sastoyo
this bad boy is slammed now ill take pics while i get it done but i dont know when the next update will be. the plans are 20 frame height in the front 19 in the rear. the rear is sprung under ranger springs 5 inch shackles bolt to bolt. u bolt elim with countersunk alens under the spring. should be pretty rad heres some pictures of mock up. I also intend on running 4-5 inches of up travel which my front has my rear might be a little more difficult
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
89sastoyo
heres what i have for pictures of it
92 2wd DD
first gen cab
89sastoyo
92 2wd DD
first gen cab
89sastoyo
i need to figure out what my photobucket :pokinit: is sorry dudes
:beer:
92 2wd DD
first gen cab
89sastoyo
those three trucks are three linked front 60s two are slammed taco is monster truck but ya gettin it at the shop this winter. cpi 4.3 2rz 2rz
92 2wd DD
first gen cab
89sastoyo
92 2wd DD
first gen cab
89sastoyo
92 2wd DD
first gen cab
89sastoyo
c
92 2wd DD
first gen cab
89sastoyo
92 2wd DD
first gen cab
89sastoyo
this is the new ride hieght
literally as low as it can possible be without c knotching the rear frame hahah and my diff and gas tank hate each other
92 2wd DD
first gen cab
89sastoyo
92 2wd DD
first gen cab
89sastoyo
92 2wd DD
first gen cab
Firstgencrawler
1980 pu 2nd Gen ruf 63's in the rear bobbed 13inches welded 4.10's duals with 4.7 on 39.5 iroks
89sastoyo
Your gay homo! My trucks colorful if that's what you meant. I think it's cool! Okay
92 2wd DD
first gen cab
89sastoyo
Well broke a pass side 60 inner. And have been wheeling it quote a bit lately. Took a trip to browns and then hit some snow a little closer to my house afterwards. Here's some pictures.
Work wise I've reworked my exhaust and rear shocks. Putting a stereo in it thanks to the gf.
92 2wd DD
first gen cab
89sastoyo
92 2wd DD
first gen cab
89sastoyo
92 2wd DD
first gen cab
yotacrawler1
TIMS89CRAWLER
Badass! cool to see this thing is still alive.... well sorta. lol
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
nisota
I'm not hatin' totally appreciatin' This is the lowest one I've seen so far Awesome!  :beer:
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
89sastoyo
Currently just 4 linked the rear and cages it..
Truss I made tg frame mount.. Sorry dudes got a good deal on it.
92 2wd DD
first gen cab
89sastoyo
Oh ya and I boat sided it got bumps in it zero floor left after linking it putting vision x rock lights in it tomorrow cleaning up the interior for this weekend oil in the cases blah blah little boring :pokinit:. Might throw some limit straps on it. Gotta weld the 5 cracks in what's left of the frame. Gusset the shock hoops. And I'm going to the ground hog rock crawl competition this weekend. Ill be sure to post up some pictures when I'm done.
92 2wd DD
first gen cab
Reynolds
-Brian
89sastoyo
Naw I just hang out with buggies.. It's hard not to get a dent here or there.. Then here and there becomes often. Then I'm trying stupid lines and its on its side so on and so forth.
92 2wd DD
first gen cab
twistedtoy92
things flexin like a champ! all the rock rash just gives it character....  :yupyup: beer for you :beerchug:
89sastoyo
Quote from: twistedtoy92 on June 28, 2013, 05:49:47 PM
Thanks man! I really need to tube the frame front and rear it's gone through soapy phases is time. Might need to plate the body mounts also.. Cabs pretty angry these days ripping off the boat sides and kinda pulled tweaked the body mounts. If you measure of the frame all my links are square but the left side is way closer to rubbing fire wall. Ha most people would start over about now but I'm just gonna keep welding aging tubing until it completely falls apart! Ha I love the character and it makes me not care at all.. I honestly avoid dents but when I try buggy lines in not really preventable. Swartz canyon is pretty much buggy territory huge rocks everywhere. You can't really enter it and leave without some dents off camber :pokinit: it's fun! Ground hog quarry I shouldn't get to much but it may happen. There's a comp tomorrow I'm watching because I don't have a winch and you can't enter without didn't have time before but I plan to run the buggy course after the comp.
92 2wd DD
first gen cab
twistedtoy92
sounds like a lot of fun! I really need to get my ass in gear and finish my floppin' runner..... sucks when you wrench all day everyday just really cuts the motivation off after work to do anything on your own rig.... just clocking out infact, time for some cold ones!!! :beerchug:
89sastoyo
Agreed that's why I went with a different career just because I'd hate to ruin the fun factor of it all. But ya you do I miss the old reg standard cab that thing was sick!
So this weekend went well I like the rear end just need to either dial in the air shocks some. Adjust the oil levels in them or build a sway bar or both. It unloads before my front even thinks about it so its kind of weird but the no axle wrap and rigidabilty out of it is awesome. I ended up shearing my ruff stuff upper link mount in the from in half and breaking a stub shaft and hub on the 60. I'm gonna throw a stocker in it for this week I'm going for the 4th. But ordering flanges and 35splines ASAP. No pictures from this weekend really. My girlfriend likes riding with me to much to take pictures lol.
92 2wd DD
first gen cab
