Author Topic: cooling problem on ranger  (Read 1501 times)
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« on: Feb 27, 2009, 05:40:21 PM »
so my girlfriends ranger has had a cooling problem for a while now and at this point I'm just frustrated.
the symptoms
~ heater doesnt work
~ temp gauge doesnt lift off cold
~ outside the engine it doesnt circulate very well or at all
~ i have changed the thermostat
~ you can grab and hold any coolant line, even after a 3 hour drive(none of the lines are HOT)
~ its not overheating
my three thoughts are
~ thermostat (but i already changed)
~clogged coolant line
~ water pump (but if it was the pump then it would proble overheat)
i just dont know
UA 342
STEAMFITTERS
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
Re: cooling problem on ranger
« Reply #1 on: Feb 28, 2009, 05:25:25 PM »
id check the water pump and flush the cooling system it might be a defective thermostat btw what motor does she have
93tonkatoy
  • Male Posts: 463
  • Member since Jul '07
« Reply #2 on: Feb 28, 2009, 06:26:22 PM »
All six of those symptoms are saying that the coolant is free-flowing through the water jacket, such as the thermostat being stuck open, or not there at all. I don't know the details of the ford hose connections and layout, but, IS it possible to have hoses crossed and bypass the thermostat? It doesn't take a large line to pass enough coolant around the thermostat to make the engine stay cold.
SAVE TELLICO post 491
Steve_925 [OP]
  • Male Posts: 1,876
« Reply #3 on: Feb 28, 2009, 10:14:02 PM »
its a 4cyl. im pretty sure its flowing ok in the engine but outside the engine it isnt. i think i might try a nother thermostat. i have never really messed with flushing a sytem(i assume you mean in reverse) any tips on how to do it
UA 342
STEAMFITTERS
93tonkatoy
  • Male Posts: 463
« Reply #4 on: Feb 28, 2009, 10:37:27 PM »
If the coolant were ONLY circulating in the block, it would overheat and boil over in just a few minutes. Since you say it is NOT overheating, then the coolant has to be travelling through either the radiator or at least the heater core (but you say you are getting no heat). That says to me that there is no restriction to the flow making the coolant stay IN the block long enough to heat up. I'll bet the gas mileage sucks pretty bad, too, right?
Steve_925 [OP]
  • Male Posts: 1,876
« Reply #5 on: Feb 28, 2009, 10:44:36 PM »
ok there is a coolant hose that goes to a valve for the heater core. if i turn the A/C on it shuts the valve off. i know exactly how the valve works, with the valve closed the coolant inlet and out let off that valve should be the same exact temp since its not going through the heater core. the inlet is barley warm and the outlet is cold. wich leads me to belive that there is no flow. oh and i just replaced that valve.
UA 342
STEAMFITTERS
93tonkatoy
  • Male Posts: 463
« Reply #6 on: Feb 28, 2009, 11:10:15 PM »
With the engine cold, remove the radiator cap, start the engine, and see if the coolant is flowing through the radiator. If it is, then the thermostat is open when it is cold. If the coolant does not stay in the block until it warms up, then the engine will not get warm.
93tonkatoy
  • Male Posts: 463
« Reply #7 on: Mar 04, 2009, 03:17:36 PM »
Have you found anything out yet?
Steve_925 [OP]
  • Male Posts: 1,876
« Reply #8 on: Mar 04, 2009, 05:42:13 PM »
nope, i dont even feel like touching it. its not a overheating problem so im not to concered. one day ill try another atempt at figuring it out
UA 342
STEAMFITTERS
Last post Jul 14, 2004, 10:37:16 AM
by 84runner
Last post Jul 15, 2005, 06:32:50 PM
by Uncle Jesse
Last post Oct 03, 2005, 05:10:39 PM
by Willy Mammoth
cooling ?
Last post Oct 17, 2006, 01:11:42 AM
by 2utadud
Last post Jun 11, 2009, 08:45:27 PM
by kneedownnate
