cooling ?
Started by trekker, October 05, 2006, 08:29:23 PM
trekker
I have a 81 toyota 4x4 with a stock 22r and it keeps boiling over a lot.I have put in a new thermostat and radiator cap but that hasn't helped at all. I can drive for 5 minutes and it just pours out. I felt  all  my hoses and there all warm.So does anyone have an idea of whats going on.
thanks in advance josh :beerchug:
I need a running 22r
DTB
u bled the air out of the system right? Toyota thermostat? thermostats not upside down is it?
Duffil
Quote from: Dirt Toy Boy on October 05, 2006, 08:31:58 PM
The copper pellet should go down into the intake.  Do you have bubbles in your coolant?  How about floaty black things?  When it's cool, pop the cap and fire it up.  When the stat opens, you'll see flow.  See if you have bubbles or floaties.
trekker
thermostat is in right. it has a napa thermostat in there.could there be a blockage in the system maybe. The gauge doesn't go past half way mark
Duffil
well, it shouldn't go past half way.  AFAIK, that's normal operating temperature.
trekker
thtas why i cant figure out  why its spewing coolant everywhere
Duffil
what do you mean, everywhere? ALL the hoses?  do you have a leak in a hose/loose clamps, etc.  Open the hood, fire this thing up and wait.
trekker
I have looked for a leak but im going to pressure test the system. My axle is all wet,the bottom of the radiator,the hood is wet,power steering resivoer is wet
Wermz84
what kind of shape is the radiator in? Does it flow ok or is it cloged?  What about your water pump, is it sealed tight or in questionable condition especially around the bearing seal?
I like to Drive!
trekker
I have taken off both hoses andand ran a hose through and it seemed to flow good.I haven't checkedf the water pump yet
skii4x4
The reason why your gauge is not going above half way is because the guage is not making a good connection, therefore not reading accurately.  To fix this problem you need to get the back of the gauge and clean off the connectors behind the gauge.  This will allow the gauge to read properly.
Mine does the same thing.  I fire it up its at half way.  The coolant is boiling over its still at half way.  I have just read on how to fix the problem.  This is why a lot of people run aftermarket temp gauges that work well.
Wermz84
Quote from: skii4x4 on October 12, 2006, 02:01:46 PM
Mine has never worked correctly, it does tha exact same thing that you have described.  Sometimes it bounces from cold to overheating when I first start it, then goes to half way after less than a minute.  Gonna have to try cleaning the connections..
I like to Drive!
2utadud
mine had new rad and t-stat but the coolant does not circulate. gauge used to be
at low just above the bottom white line but now it is halfway. flushed the cooling system and still the same. i do not what is wrong w/ it.
2utadud
sorry guys, i forgot to mention that it is an '85 xtra cab 22r carbed toy.
