Author Topic: cooling system q.  (Read 2141 times)
2utadud
  • Member since Oct '04
cooling system q.
« on: Oct 02, 2005, 06:43:51 PM »
what is wrong if coolant does not circulate in the radiator? rad, water pump, toy stat are all new. also, fan was turned on the other day and temp gauge was a little higher than normal. turned it off and gauge was a little lower. before the head was replaced last year, temp gauge was low. now it is at 9 o'clock position. thank you
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
Re: cooling system q.
« Reply #1 on: Oct 02, 2005, 08:23:38 PM »
what makes you think the water is not moving? if you run the heater and the temp goes down, theres some movment going on.
more info please.
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« Reply #2 on: Oct 02, 2005, 08:28:24 PM »
What temp thermostat did you install?
190 - 195 - 210 ??
2utadud [OP]
« Reply #3 on: Oct 03, 2005, 04:26:16 PM »
before i used to open the rad cap and see the water flowing when engine is running, but not anymore. now the coolant is just sitting therel.
 all info was mentioned already. thank you
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
« Reply #4 on: Oct 03, 2005, 05:10:39 PM »
Leave the cap off and put a piece of cardboard in front of the radiator. and see if the water dosen't start flowing. If it starts chuging out of the rad the there may be an air lock or the thermostat may be opening late. What  temp tstat did you use?
Another stupid thought is Chevy made water pumps that turned in diferant rotations depending on how the belts are routed, did toyota ever do this?
Last post Sep 04, 2006, 09:51:02 AM
by chevihemi
Last post Mar 08, 2008, 10:01:34 AM
by madmanweaver444
Last post Feb 15, 2010, 07:58:33 AM
by 2manytoys
Last post Dec 11, 2011, 01:44:51 AM
by Rocksurfer
Last post Apr 12, 2014, 10:00:41 PM
by Cheesemaker
