4runnerchevy and his Chevy powered 86
Started by 4RunnerChevy, February 14, 2009, 08:21:13 AM
bustatoy
i have engine harness and ecm that i bought from a guy that was going to do the swap but deicided not to so i dont have a whole donor rig
4RunnerChevy
Quote from: bustatoy on December 07, 2009, 11:45:26 PM
Hopefully you have all the engine management sensors and whatnot.  I wanted mine to be Cali legal, so I opted for a donor rig, which gave me exhaust, intake and smog equipment.  You should be fine.  What engine are you running ?, and what are your plans for a Tranny ?
bustatoy
its a tpi i believe its out of a 97 blazer. im planing on using toyota 5 speed.
4RunnerChevy
bustatoy
well i changed my mind. im thinking it is going to be easier to put an automatic in it since the blazer that the engine came out of is an automatic. less of a headache with wiring and getting the ecm programed for a manual.
yota4x4sc
why did u swap out the 5mge? how did it compare to the chevy v6? more or less power
yota4x4sc
my buddy and me r installing a 7mgte into  a 3ed gen xcab..i cant wait till we finish that thing up..its gonna haul
Quote from: yota4x4sc on October 29, 2010, 01:47:53 PM
Just remember they are not low end-torque engines.
yota4x4sc
Quote from: THK on October 29, 2010, 02:19:45 PM
o ya huh  watever.. we are 3 linking the front then 4 linking the rear, 70 in the rear and 60 up front so i think it will handle it..i just dont know how the turbo tranny will hold up... :crossed:
Quote from: yota4x4sc on October 29, 2010, 03:04:57 PM
The R series trans will hold up fine.... the supra's use the same series trans and handle gobs of power.
DO you have an engine diagram of what u swapped from the donor rig? what u kept from the 87 4runner, etc..
4RunnerChevy
Not really, I kept the brakes and body harness that's about it.  I did keep the engine fuseblock, so I could get power from it.  What exactly are you looking for, maybe I can help.
Quote from: 4runnerchevy on November 05, 2010, 07:03:25 PM
the toyota engine fuseblock?
Well I am gathering all the info I can for a 96+ 4.3L Swap with 700r4/4L60 swap into my 87 Xcab longbed.
I want to do it the cheapest yet most effective way of swapping. I dont wanna drop my wallet at it... but i dont wanna go with lowgrade crap.
Could you by chance do a electric diagram? of like what is being spliced from the truck to the engine.. for like sensors and stuff.
4RunnerChevy
Quote from: THK on November 05, 2010, 07:38:57 PM
I hear you about saving a buck, give me a little info about your motor.  Is it TPI, CPI, or TBI ?  Does the Computer have another smaller box with it (DRAC) ?  Does it need to be smog legal (California) ?  Will you be running the Toy Transfer case ?
The 4.3 Engine harness is easy, it just goes into the ECU.  There will be about 15-20 left over wires, and you only need about 5.  Your Toyota dash guages/sensors can be plumbed into the block and water jacket.
To save money I used the stock 4.3 radiator.  I also used the wiring harness from the 4.3 and did not buy one.  I am also Cali smog legal, so I had to by an exempt VSS from JTR (these are usually back ordered and take months to get).  I got rid of my DRAC and wired to VSS directly to the ECU.  Although a DRAC can be modified for tire size.
Give me that info mentioned earlier, and I'll send some info.  I have the Downey manual, which is really helpful as well as pinouts for the ECU.
Quote from: 4runnerchevy on November 06, 2010, 06:47:13 AM
Well I do not have one yet.... as I am trying to aquire as much info as I can prior.
I am getting a 96+ CPI Vortec, I live in Idaho... No smog!!!
I will be using a 21spl Toy Transfer Case
Not familiar with DRAC..
4RunnerChevy
Quote from: THK on November 06, 2010, 04:41:40 PM
DRAC takes a vehicle speed sensor signal and splits it to electric speedo, ABS, and ECU.  If you are not using ABS or Electric Speedo, then its not needed.  It does however have jumpers inside to correct for tire size.  I don't use one.  Since you don't have smog then you don't need the VSS, some people just put that wire to ground (I don't know how it affect drivability).  JTR has a VSS that screws into the speedo port of your T-Case, and your speedo cable screws into it.  You will also need a shifter for the auto, I used BM but you could probably find a floor shifter at the junk yard.
I would go with a 700R4, cause it has less electronics than its newer brother.  The 700R4 requires 1 less adapter to mate with the transfer case.  Keep in mind you will have to change the tailshaft of the 700 with the one that comes with the adapter.  This costed me $200 at a tranny shop, and I got heavy duty clutches at the same time.  Either way you will need a brake light switch from an automatic or a 12 volt NC relay.  This will unlock your Torque converter when you brake.
Other stuff
I used the stock chevy motor mounts and fabbed new frame mounts for the toy, Chevy Motor mounts are in-exspensive.
I was able to locate my crossmember in its stock location, so nothing changed for the shifters.  I mounted the radiator forward, but still behind the grill.  I am able to run the stock fan or electric fans :) .  Yes I have perfect access to my distributor, dis-spell any rumors.
I have a 2" body lift but it can be done without, you may have some clearance issues with the front driveshaft and exhaust crossover pipe.  You don't need smog, so you can eliminate the crossover pipe.
Some good reading,  JTR have been doing conversions forever.
http://www.jagsthatrun.com/V8-chapters/V8-tpi-Speed-Sensors.pdf
http://www.jagsthatrun.com/SpeedSensors_Order.html
http://www.pirate4x4.com/forum/showthread.php?t=384213&highlight=V2.0
PM me a real e-mail address, and I'll send the CPI pinouts, and the images of the Downey manual.
[email protected] :thumbs:
Thanks for that info!!!!!!
That will help greatly.
I have a 3in BL So I will have lots of room... I can even raise my drivetrain up too :D but that could create a higher COG.
Whats this brake light switch you speak of.
4RunnerChevy
Quote from: THK on November 07, 2010, 08:23:02 AM
Brake light switches, behind the pedal.  Most auto's came with a switch that has 1 N.O. contact for the actual lights, and 1 N.C. contact for the Torque converter circuit.
I'll send some info shortly, hope you have High Speed Internet
I have Cable Internet, 7mbps! :D
Send away!
and my truck came stock with a 22R and 5spd (2wd) should have a BLS right?
so the donor i get that will most likely be AT, I will have to get a BLS for the trans to tap into my OEM BLS on the truck.
Is that what you're saying?
4RunnerChevy
My runner was originally 5spd also.  If you get a donor switch you will have to figure out how to mount it to your brake pedal.  I just used an automotive relay with a normally closed contacts.  I fed relay holding coil with the hot from the brake lights, then I ran TCC circuit through the relay.  When you step on the brakes the relay opens up and the Torque converter unlocks.
Sent an e-mail
K
Quote from: 4runnerchevy on November 07, 2010, 08:49:21 AM
Sent an e-mail
K
So would I need this if my truck has a BLS already?
and thanks!
4RunnerChevy
Quote from: THK on November 07, 2010, 09:09:42 AM
and thanks!
Yes sir.
Did you get the email, it rejected the first one.
Yes sir! :P Saved your manual pics. that will help GREATLY! I can eliminate what I dont need... by using the pinouts. right? :P
4RunnerChevy
Quote from: THK on November 07, 2010, 09:40:49 AM
Yup
Let me know if I can help further, I can always go look at my wiring.  When stops raining.
with the 2 pics you sent in the email itself (there was 3) one says "All these connections are in the engine harness and should not need to be connected"
Meaning I dont need that entire plug? that confused me a bit
4RunnerChevy
Quote from: THK on November 07, 2010, 09:58:34 AM
One of the Two plugs that connect to the ECU is engine managment, you should not have to do anything with theses wires,  they connect to the sensors on the engine.  You still need it, but shouldn't have to do anything with it, just plug all the sensors in.
Quote from: 4runnerchevy on November 07, 2010, 10:04:43 AM
Oh okay that makes more sense... its the other plug i have to elim wires from.
On the A10 Pin for VSS, does it have to be connected to VSS or grounded.... or can the wire be pulled from the plug all together.
90 sa-yota
Dam ur rig looks good alot of custom work. Are u a mechanic or a electrical specialist?
90 Yota truggy 4banger dual t-cases, front linked fj80, rear t100 axle on 39 Bfg's
DD 00 Fird f250 x-cab 7.3 auto on 33's tow rig
DD 2006 yota taco prerunner
DD 82 yota 4wd on 33's play toy
Future LONG TRAVEL toy 04 taco 4 dr. Prerunner
