4runnerchevy and his Chevy powered 86
Started by 4RunnerChevy, February 14, 2009, 08:21:13 AM
4RunnerChevy
#150
Quote from: SCyotacrawler420 on December 02, 2010, 04:22:45 AM
can you heat treat connecting rods for a motor?
Do you know exactly what they are made of ?  I am no expert, so you probably don't want me messing with motor internals. :hammer:
4RunnerChevy
Steering arms installed. Went together like a dream.  I had to remove the hydro assist, because angles have changed.  I am gonna redo how its mounted.  No pics yet, I still need to make another tie-rod.
Drove it without hydro-assist, wow its a big difference after being used to assist for years.  I want it back.  I have to modify the ram mounts, the ports, and where its located.  Easy job but more time.
4RunnerChevy
I was surfing the web, found this video of Steel Dragon 2000.  Brings back memories. I had a hand in the building and construction of every part of this massive beast.  We built it in La Selva Beach, CA (Santa Cruz) and constructed it in Japan.
http://www.youtube.com/watch?v=_XMSboc-h-k
4RunnerChevy
4RunnerChevy
Another, what a nightmare working with Disney Engineers.  They designed the ride around the ring gear, without thinking, what if it failed.  We changed it and added shear pins to the gear housing, so lockup would shear pins instead of gearing.  This ride had so much Stainless, for such a middle of the road ride.  10,000 1/8 drill bits and 250,000 rivets later, you get a center piece for Cali Adventure.
http://www.youtube.com/watch?v=HvtPNHMVaPI
4RunnerChevy
There has been a lot of talk about replacement Pads for AP transfer case brakes.  I originally built my brake around AP's disk, cause I can't make the disk.  I built the caliper out of steel and used pads from golf course equipment (probably a Cushman or Jacobson).  I used them cause they looked exactly what was used on AP's full Kit.  When I got the disk from AP it matched the pads perfectly.  I have not worked in the golf industry in many years, but we use the same equipment.
After all this talk I gotta do some research, maybe we can get em cheaper.  When vacation ends I'll look into it, if someone can PM pics of AP's pads, with a ruler next to them (or better yet, a center to center pin measurement).  I bet they are the same, off the shelf.  After all, when I bought my disk, AP said it was so "you can fab your own caliper".
I have since rebuilt the caliper, 6061
yota4x4sc
damn.. thats a sick set up.. is that aluminum? ill measure my ap tommrro when its light out.
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
4RunnerChevy
Quote from: yota4x4sc on December 30, 2010, 08:11:09 PM
Thanks that would be a great help
yota4x4sc
i got board.. it is 6 inch exactly..hard to hold a flash light and a tape and take a pic at the same time lol
4RunnerChevy
#162
Got it, I'll measure mine this morning.  The caliper looks the same.  If it turns out they are, I'll get you a set of pads.  If nothing else we have the material and a brake riveter at work.
Thanks  :beerchug:
Edit:  The pin to pin measurements are the same 6".
VincentVanPwn3d
That exo looks really nice, good work on that!
86 4runner
22re
4RunnerChevy
Quote from: 84dreamyoda on January 02, 2011, 10:00:08 AM
Thanks, although I did stop that project, and I got to make some changes.   :_order:
4RunnerChevy
Finally got the runner out of its parking spot.  Did some suspension tests.
Need to add bumpstop, till I get my flat steering arm.  New fuel pump on the way, so its time to wheel.
4RunnerChevy
Quote from: THK on February 13, 2011, 12:54:17 PM
Very nice Kevin!
Thanks, still alot to do.  Isn't that always the case though.  Its always been a work in progress since '95.
4RunnerChevy
Rear Drive shaft
Rebuilding my rear shaft, adding a modified CV
Pics as they come
More to come.
toygasm
sick runner.cool camo job.cant wait to find one of my own.
Wermz84
Did you make it to HH?  how did it go?
I like to Drive!
4RunnerChevy
Quote from: Wermz84 on March 29, 2011, 05:33:28 PM
It went very nice, a few mods and we'll be out there.  The second week of april, maybe Sunday the 10th, or Fri the 16th.  My facebook has pics.  You should go, some good SC wheelers.
Wermz84
Glad to hear it.  Still need to get mine back together.  We'll have to find each other on FB.
I like to Drive!
4RunnerChevy
Quote from: 4runnerchevy on March 29, 2011, 07:09:07 PM
Quote from: Wermz84 on March 29, 2011, 08:15:54 PM
PM'd
4RunnerChevy
#175
Quote from: THK on March 31, 2011, 02:48:07 PM
PM me your FB.
done
I know your too far away T, but Hollister the 2nd week of April.
Wermz84
Just responded.
Sadly, I will be in Sac that weekend.  Dang.  We will get it soon.
I like to Drive!
Peterbuilt84
Just read through the whole build, very impressive. Wish I had the skills/tools to make custom stuff like that.
4RunnerChevy
Drive line update,  Straightened to .005 and balancing the redneck way.
Found my stall issue  :clap:
Front of Cat is fine.
Still need one before smog (right now).
crawlerbubba
GOT ROCKS?
