4runnerchevy and his Chevy powered 86
Started by 4RunnerChevy, February 14, 2009, 08:21:13 AM
4RunnerChevy
They started as flat plate in my shop when I was working for a surf car rack manufacturer.  The arms are 12 years old and the fifth stud is today, there were not many kits then, and they still serve well.
Wermz84
Very Cool.  :thumbs:    I kinda thought they were home made.
one day I will have fab skills.   :ha_ha:
I like to Drive!
4RunnerChevy
I did a little houscleaning on the runner over the weekend  (while I wait for trunion bearings).  I moved my spare to an upright position (cause who needs to see behind them).  I bolted my ammo can holder to the bed as well as my truck box.  I think I can fit more junk for road trips.  I am still figuring a location for my hi-lift.
4RunnerChevy
#33
Got my Trunion bearings, two sets. The KOYO TR0305A and The NSK 30303, I'll install the KOYO's and stick the NSK's in my spare bin.
Trunion thread
http://board.marlincrawler.com/index.php?topic=56567.msg702413#msg702413
Nothingface5384
good deal,
hey...just wondering, what toyota engine parts do you still need for the chevy..like the oil sending unit? and what else?
Quote from: 86rustbucket on August 05, 2009, 05:16:04 PM
i love your sig your down to a half of a maverick
73 Maverick(jointly owned w/ lil bro)
64 LeSabre(sold)
82 RX7 (scrapped)
92 Toyota p/u 4x4 (dead) resurrecting underway
72 Skylark (dead) resurrecting underway
87 Grand AM (junked)
79 Regal (sold)
90 Geo Prizm (R.I.P)
4RunnerChevy
For the Toy guages to work, You will need the oil sender and adapt that to the block.  You will need the Temp sender and adapt that to the cooling system.  I believe Downey and Allpro sell the adapter bungs.  If currently have EFI then you can use your current fuel pump (I use a chevy tank pump adapted to the toy tank), and the Toy sending unit.  If you go TBI or TPI and had an EFI Toy motor and arn't going smog legal then you can Tap Toyota VSS.  If your Cali smog then you need a VSS from JTR (they are the only ones that are smog legal), and no you can't just ground it out and be smog legal.  Also I use the GM P.S. pump so keep your power steering hoses and put a new end on the high pressure side or buy an adapter.  If you go with a painless harness or Howell then make sure it contains the VSS wiring (in Cali).
I am sure I missed something.
Kevin
offroadin88
vss= vehicle speed sensor I believe
any idea on the mpg you are getting with your set up?
4RunnerChevy
Quote from: offroadin88 on April 10, 2009, 02:19:32 PM
Yes vehicle speed sensor
I am getting around 10-12 around town.  About 14-16 on the Hwy
4RunnerChevy
#39
I finally got my Smog exempt VSS.  Now let the referee games begin.  I should pass, cause I have already been there, and passed tailpipe, evap, and visual (minus VSS).  I will be running the new VSS for smog and my old one after smog.  My old 40 tooth ring allows for tire and gear ratio through a DRAC, so I'll use that after smog.
66cobra
  love the emission nazis i never saw the reason for visual inspections if the tail pipe passed
it's not me, it's you
4RunnerChevy
Its something us in Cali have to live with, it will never get easier to deal with smog.  I can't just pick up and move either.
johnstrings
Johnstrings
66cobra
do you have dual cases,and if so what support are you using? i finally got my rig running yesterday and have alot of vibration transmitting from the drivetrain. I'm pretty sure it's coming from the t'case mount because when I installed it last year with my 22re it increased the vibration significantlly. I suppose it can be from the motor mounts [a a] or a combination. I'm relatively sure it's not from the motor because I had it rebuilt and balanced from a builder who has built some pretty high perf motors for me in the past.
Bazzi
4RunnerChevy
Quote from: 66cobra on May 02, 2009, 07:14:14 AM
I have a single 4.7 case on a custom crossmember, in the stock location, using the Toyota T-case rubber, and no vibration.  Probably no help to you
Nothingface5384
64 LeSabre(sold)
82 RX7 (scrapped)
79 Regal (sold)
4RunnerChevy
Hey that is my shifter, (uni-matic I believe) and yes it works great (comes with the Park/Nuetral switch).  You can put that shifter anywhere ( you will need to make a mounting plate),  I tucked mine very close to the dash, so my guess is that you would have no problems , until duals !
My transfer case is in its stock location so twins were easy, I have room to use duals and my e-brake handle (non stock).  I also have buckets, but a bench would be fine, in my case.
Nothingface5384
awsome, cant ell from the pic, but i imagine that shifter has a gear indicator correct?
and are you working on anything new for youre rig?
64 LeSabre(sold)
82 RX7 (scrapped)
79 Regal (sold)
4RunnerChevy
Quote from: Nothingface5384 on May 10, 2009, 04:48:20 PM
It has a set of stickers, for the 3+OD and just the three.  I never used mine and just remember where I am, I also hooked up a little light for Park/Nuetral which comes directly off the switch, on the shifter.
As far as anything new, not really.  I am just puting the smog crap back on cause I gotta see the referee, at the end of the month.  I also broke some small stuff in Hollister, and I need spring bushings all around.
Cheers !
Kevin
66cobra
what is that canister on the dr side fender for?
4RunnerChevy
bigarms23
4RunnerChevy
The Chevota is California smog legal,  just need to pick the sticker up on Thursday.  :clap2:
46&2
Right on.  :biggthumpup: The CA smog process can be a major PITA some times.
4RunnerChevy
Yeah I am just glad I got in before the laws make it impossible.  CA can suck at times.
miatre
I like it.
Going to do something similar.
4RunnerChevy
Quote from: miatre on November 30, 2009, 07:49:18 PM
I like it.
Nice, let me know if you need anything!
bustatoy
Im starting to get stuff together to do a 4.3 swap and I was wondering if you had any helpful tips and hints to make it an easier swap.
bigarms23
the advice kev gave me was start with the complete donor rig
