4runnerchevy and his Chevy powered 86
Started by 4RunnerChevy, February 14, 2009, 08:21:13 AM
yota4x4sc
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
4RunnerChevy
#121
Just for whatever, not sure where my thread went. I did have problems with photobucket, and I am trying to get it all on one thread..
http://s203.photobucket.com/albums/aa116/4runnerchevy/Tires/
Seating a bead with starting fluid.
90 sa-yota
Quote from: 4runnerchevy on November 07, 2010, 05:13:33 PM
I am a mechanic, but in my field you need to be a jack of all trades.  I am not an auto-mechanic by any means, more of an industrial type.
I work for parks and rec. and see ur truck over by the quick stock u ever take it out?
90 Yota truggy 4banger dual t-cases, front linked fj80, rear t100 axle on 39 Bfg's
DD 00 Fird f250 x-cab 7.3 auto on 33's tow rig
DD 2006 yota taco prerunner
DD 82 yota 4wd on 33's play toy
Future LONG TRAVEL toy 04 taco 4 dr. Prerunner
90 sa-yota
4RunnerChevy
Quote from: 90 sa-yota on November 24, 2010, 11:06:44 PM
hahaha meant quick stop  :chew:
Not in the winter, but with my doors back, I'll take it out more.
81yotalove
my dad and i have seated many beads with starting fluid. mainly his semi truck tires after changing them ourselves. works like a charm lol.
81 swb 22re 35's
yota4x4sc
i use electrical cleaner to seat the beads.. that stuff works even better that startin fluid.. u only have to use a little bit.. bug spray works good too
4RunnerChevy
Quote from: yota4x4sc on November 25, 2010, 09:29:25 AM
In that vid, the bead sheared the valve stem, and shot it across our vehicle shop.  I had to replace the stem and set the bead again.  I am Running 10 oz of airsoft, in those tires and they balanced perfect.
Gotta love Ether :P
90 sa-yota
Quote from: 4runnerchevy on November 25, 2010, 07:10:54 AM
Thinking of going out 2 hollister the first saturday of december. What u up 2 that day?
4RunnerChevy
Quote from: 90 sa-yota on November 27, 2010, 09:37:18 PM
Anything is possible, next Saturday, i'll have to check.
yota4x4sc
im tryin to go.. i just gotta figure out how to make this stupid samurai alt work.. i cant figure it out
4RunnerChevy
Quote from: yota4x4sc on November 28, 2010, 03:13:10 PM
Samarai alternator ?  Whats to make work.
the_white_shadow
The proportioning valve behind your twin sticks: I am guessing it controls the rears discs? I like the placement of it.
4RunnerChevy
Quote from: the_white_shadow on November 29, 2010, 03:44:03 PM
Thanks, I had it under the hood, but I decided to reduce the line adapters and go with a direct connection to the line lock.
4RunnerChevy
Got the Cromo, bolts (got 30 need 16), bearings.
Bearings.  There are only so many ways to go.  17mm, 20mm, and 25mm.  All basicely hold the same dimensions ( a slight variaton on the 25mm  ), if you want off the shelf.  The 25mm are all ISO, wether its Kyoyo, Tim or NSK.  I prefer Kyoyo (back order till Feb.).
Here is the bearings (slightly chopped for the site), upper 25mm, lower 17mm
the_white_shadow
Whats the reasoning for the line lock since you have the 700r4?
81yotalove
im guessing he knows that automatic park gears aren't very strong and shouldn't be used to park on inclines at all.
81 swb 22re 35's
4RunnerChevy
Quote from: the_white_shadow on November 30, 2010, 08:59:45 AM
I dunno, if your parked at 65*, and walk away.  Do you get a warm feeling that your truck may not be in the same spot, when you get back.  Its also part of a future project.
4RunnerChevy
Pins today (4130), before treating.
After treat, pressed in fine, Pics very soon of final arms.
4RunnerChevy
santa cruz crawler
milllllllin ,so sick, thanks for the x member and third, sweet truck ,ill be checkin this steer fab
more picks...........
yota4x4sc
lookin good man.. who heat treats stuff around here?
4RunnerChevy
Byington by the airport (San Jose).  We can do small stuff at work (like steering pins and tooling).
Bazzi
4RunnerChevy
Thanks guys.  I am re-doing my drag link, got the tube insert today, but they forgot the TRE, it will be here tomarrow.  Its custom, TRE at the arm and heim at the box.  I'll be using stainless seamless, nothing bling, and I'll probably paint it.  I'll do the tie rod next, and that will be Cold DOM steel.  Probably install in the next week, if its nice enough
I started cutting my extra rear housing, I will shave it, possible rotate, armor it, and put stuff where I want it.  Rotating would keep my pinion high and brakes in the same position.  I use shims to achieve this now, and I want them gone.
:beer:
SCyotacrawler420
can you heat treat connecting rods for a motor?
