Author Topic: Short Shifter  (Read 3748 times)
YellowJacket
  • Turtle Points: -67
  • Member since Sep '02
Short Shifter
« on: Feb 03, 2009, 07:58:28 PM »
Has anyone tried building their own transmission short shifter?
http://www.toyotacatalog.net/M1WebGear/ProductSearch.aspx?Class=1582
LC Engineering has them but not for my application (1987 4Runner R151F). Just seems like it would be fairly easy to make your own.
« Last Edit: Feb 03, 2009, 08:15:46 PM by YellowJacket »
Jordan7118
  • Turtle Points: -21
  • Male Posts: 1,105
Re: Short Shifter
« Reply #1 on: Feb 03, 2009, 11:16:16 PM »
Build a hollow base, extend the shifter below the pivot ball, and I think you'd be good!
94MtnYote
  • Turtle Points: 6
  • Member since Oct '07
  • - 94 std cab-
Re: Short Shifter
« Reply #2 on: Feb 04, 2009, 12:51:18 AM »
 My truck has one it's called a 3'' BL !!!    :gap:  :hammerhead:
 Marlin 1200LB clutch
4RunnerChevy
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
Re: Short Shifter
« Reply #3 on: Feb 04, 2009, 05:44:38 AM »
I did one and I believe its still out there somewhere.  I hollowed out a block of 1" aluminum, with 4 bolt holes (same size and pattern as the shifter).   I extended the ball by using a 1 inch long round piece of steel.  I  beveled the edges to get a full pen weld  (note: I pre heated the steel and let it cool real slow, cause its hard.).  I then shaped, the steel back to cone shape without harming the ball.
All in all, it wasn't worth it.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
Re: Short Shifter
« Reply #4 on: Feb 04, 2009, 07:49:10 PM »
YellowJacket [OP]
Re: Short Shifter
« Reply #5 on: Feb 04, 2009, 10:43:16 PM »
My buddy was saying something similar. The part about having two separate pieces, heating one piece and allowing them to cool together which would be very strong, I guess. How many hours did it take you to complete yours?
I wish I could to a t-case short shifter also, but due to time and money I am going to start on the one that I need the most for my application.
4RunnerChevy
  • Male Posts: 1,426
Re: Short Shifter
« Reply #6 on: Feb 05, 2009, 05:54:39 AM »
I milled the spacer on a Bridgeport, so it took no time at all.  I welded it with stainless filler, on a Tig machine.  It took about 2 hours including cooling time.
YellowJacket [OP]
Re: Short Shifter
« Reply #7 on: Feb 05, 2009, 08:45:22 AM »
Sounds like you got skills! If it only took 2 hrs, I don't see why it wasn't worth it? It doesn't change the height or location of the shifter right? (I have already spent hours modifying my shifters to fit through the boot due to the 7M-GTE motor and the R151F tranny) If someone asked you to build one, how much would you charge?
jonathan82toy
  • Male Posts: 502
  • Member since Mar '07
  • 1St Gens Rule!
Re: Short Shifter
« Reply #8 on: Feb 05, 2009, 08:54:09 AM »
I have one in my 82, L52 HD  :driving:  Feels strange when I drive my 90 runner without
What Is The Truth Behind The Magic Turtle Breeding Program?
S.S. More Powerful Than Superman, Batman, Spiderman And The Incredible Hulk Put Together.
YellowJacket [OP]
Re: Short Shifter
« Reply #9 on: Feb 05, 2009, 09:00:26 AM »
You have a tranny short shifter? where did you get it?
jonathan82toy
  • Male Posts: 502
  • 1St Gens Rule!
Re: Short Shifter
« Reply #10 on: Feb 05, 2009, 09:48:34 AM »
  :turtle:  Only the BEST!  :thumbs:
4RunnerChevy
  • Male Posts: 1,426
Re: Short Shifter
« Reply #11 on: Feb 05, 2009, 04:59:56 PM »
Funny I had my shortie when I had my 5MGE in my runner.  Don't get me wrong but I would have gone 1.5 inches, the 1" was not short enough.  As far as me building one, sure ! but I only do manual machine work, so if you want bling, just buy a production , CNC version.   Cause manual bling wil cost you.  If its custom, then give me a print, and I'll make it.  Weld the shifter yourself, too much liability.  I am pretty reasonable cause I am financing my projects.
YellowJacket [OP]
Re: Short Shifter
« Reply #12 on: Feb 05, 2009, 07:03:49 PM »
That's funny. I was going to mention we had some things in common regarding our rigs BEFORE you said you use to have a 5M.  :) I don't care about bling. You should see my shifters now. I have already had to do some cutting and welding on them and they are not pretty. How thick did you need to go on the base plate? Where can you buy these? How much for your work?
4RunnerChevy
  • Male Posts: 1,426
Re: Short Shifter
« Reply #13 on: Feb 06, 2009, 06:43:22 AM »
I went 1 inch on the base.  You extend the shifter ball the same distance.  I'll look around and see if I have enough aluminum to mill a base for you.  Its gonna cost $50000.00 dollars, JK.
YellowJacket [OP]
Re: Short Shifter
« Reply #14 on: Feb 07, 2009, 08:20:17 AM »
:yikes: LOL! I should probably try building it myself since I am sure it's going to cost me a good amount anyway. Things are tight right now. My wife would kill me if she even knew I was talking about spending money on my rig.
So as long as the base is the same length as the ball extension, your good? What happens when you make them .5" or 1.5"? Just changes the throw? Like a 1.5" extension would be even less throw? I did want to verify that doing this doesn't change the location of the end result right? Like the top of the shifter? Did you mention why you didn't like yours or why you are no longer running it? Sorry your the 20. :bowdown:
93tonkatoy
  • Male Posts: 463
  • Member since Jul '07
Re: Short Shifter
« Reply #15 on: Feb 07, 2009, 10:44:23 PM »
I have the w56 forward shift tranny/t-case with both shifters in one base plate. I looked around for any manufactured ones, and could not find anything for my application, so I made my own, and did a write-up on it.
http://www.fattshack.com/phpbb3/viewtopic.php?f=4&t=1270
It was my first attempt to do something like this, but turned out really good, and I love the tighter feel of the shifting motions. I used a 1.5" spacer, and extended the shifters (both) the same amount. It will raise the shifter up the same amount, and since I am running a BL, I do not know whether or not there would be clearance issues without one.
SAVE TELLICO post 491
4RunnerChevy
  • Male Posts: 1,426
Re: Short Shifter
« Reply #16 on: Feb 08, 2009, 06:58:23 AM »
I couldn't find any aluminum laying around.  Sorry!
Yes, extend the ball, the same thickness as your base.  I don't run it anymore, cause I have a 700R4 tranny  :cool:  Good luck
YellowJacket [OP]
Re: Short Shifter
« Reply #17 on: Feb 08, 2009, 01:49:29 PM »
I should have realized you weren't running the same setup now. :smack:
Well, thanks for all the excellent info!
YellowJacket [OP]
Re: Short Shifter
« Reply #18 on: Feb 08, 2009, 02:10:52 PM »
Thanks for posting! That is a good and valuable thread. Sounds like 1.5" is the way to go. And yet one more reason I like body lifts. I have a 2" so we should be good there.
Last post Feb 01, 2004, 11:41:01 PM
by 84runner
Last post Jan 29, 2006, 04:54:02 PM
by kneedownnate
Last post Feb 14, 2013, 09:03:28 AM
by John Doe
Last post Nov 11, 2014, 03:38:17 PM
by blackdiamond
Last post Feb 07, 2018, 06:56:49 PM
by nlualum82
