Author Topic: Short Throw Shifter  (Read 3051 times)
LA_Fred
  • Turtle Points: -68
  • Male Posts: 228
  • Member since Jan '04
Short Throw Shifter
« on: Jan 29, 2004, 06:59:42 PM »
I have a marlin crawler short throw shifter on my transmission, r150f, and the shifter is now longer than stock. Does anyone know if I need to cut down the shifter and re-weld it to the shifter base to bring it back to the stock length?
1989 x-cab V6, SAS, Marlin dual ultimate crawler, dual arbs, high pinion, 35 mtr's, hot brunette in passenger seat.
Marlin
  • Inspirational Genius
  • Turtle Points: 137
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re:Short Throw Shifter
« Reply #1 on: Jan 31, 2004, 09:38:42 PM »
The trans shifter is now only about 1" taller than stock. I would not change it unless it causes a problem. Any time a solid shaft is cut, shortened, and welded back togeather, there is a chance of the weld failing. This is main reason we do not alter the height of the handle.
Marlin
whitetoy
  • I love Marlin Crawler!
« Reply #2 on: Feb 01, 2004, 08:35:55 AM »
I have the perfect solution :
A one-inch body lift  :greengrin:
Rick
1984 4Runner
4.7 Marlin Crawler TC #67
84runner
  • Turtle Points: 99
  • Member since Dec '02
« Reply #3 on: Feb 01, 2004, 11:41:01 PM »
bingo
Last post May 12, 2014, 09:57:36 PM
by jestto
Last post Nov 11, 2014, 03:38:17 PM
by blackdiamond
Last post Aug 07, 2016, 07:03:21 AM
by Hickory Nut
Last post Aug 06, 2017, 02:06:40 PM
by WhiteDLite
Last post Jun 08, 2017, 05:55:56 PM
by Jarhead
