4xFlyin build1982 1st Gen.. Dual Diaphram Booster
Started by 4XFlyin, October 11, 2008, 03:29:36 PM
86toyota
so you rotated it 11* or you rotated it so the pinion was at 11*? and was that the angle with your dual cases and everything?
Quote from: 4X Flyin on November 17, 2008, 08:26:31 PM
Once the knuckle and pinion where at the right degrees I welded the axle up. Then I cut the knuck on the other side and made sure it was at the same degrees at the other side and welded it up. I did this whole procedure by myself. In the past I had someone help me. The secret was using long pipes as pictured to rotate the knuckles. They only needed to rotated just over an 1/8" to get the correct rotation. Having a good quality angle finder makes a big difference. I also used my digital angle finder to get the knuckles the same degrees.
T86OTA
4XFlyin
I just went and reread my post to remember.
How much it was rotated after being cut I don't remember. Basically I figured out how much to rotate it by rotating the axle until my pinion pointed to my transfercase flange. I put the angle finder on the flange and measured. The flange sat at 10 degrees. Then I took the axle form underneath the truck. I just placed it on jackstands. I cut the knuckles one at a time. Doing one knuckle first is good. This way you can hold the other knuckle to turn as pointed out in page one. While on the jackstands I adjusted the rotation of the axle so that the flange was at 10 degrees or at 80 degrees depending on how you have the angle finder on the flange. Basically 10 degrees from vertical. With that set you will be able to see that the caster will be off dramatically. So while holding the pinion at 10 degrees you rotate the one knuckle that is cut to the desireable caster you would like. For me it was 5 degrees. While my pinion was sitting at 10* my caster was at 5*. Them I welded it up. I then just repeated the same to the other knuckle. I highly recommend getting a digital angle finder to set caster as the regular angle finder can be off a degree or two very easily.
Hope this helps.
My build up. Getting linked
RokCrawlinToy
4XFlyin
Quote from: RokCrawlinToy on December 10, 2009, 01:57:27 PM
Did you order the rest of the DOM yet?
No, but my 2 1/4" exhaust kit came in today. This rain sucks.
4XFlyin
RokCrawlinToy
Quote from: 4X Flyin on December 10, 2009, 09:56:26 PM
Did you finish boxing up those rear seat mounts?
4XFlyin
Quote from: RokCrawlinToy on December 11, 2009, 12:31:55 AM
No I will do that after the rig is up and running.
axled89
i haven't seen the progress,  damn you have done alot, looks great man.  when do you think you'll take it out???
i love oregon wheelin.
4XFlyin
Quote from: axled89 on December 11, 2009, 10:08:39 PM
Looks like I may take it out to view King of The Hammers in Feb.
axled89
that will be sick.   just do it right/ break every thing in and change oils.    no rush!.
hilux-1983
RokCrawlinToy
Quote from: 4X Flyin on December 11, 2009, 10:58:55 PM
:rofl2:  :rofl: Didn't you tell me that last December?  Or was that the  :beer: :beer: :beer: talking?
4XFlyin
Quote from: RokCrawlinToy on December 21, 2009, 08:48:14 PM
You so funny. You should see my exhaust. It is coming out nice.
RimLock4x4
Gutting a 86' toy 4 runner. Hey 4x Flyin, thought you might give me some information on the best rear articulation linkage 5 point, or 4 point or anything else?
Thanks for your help,
RimLock4x4
4XFlyin
Quote from: RimLock4x4 on December 31, 2009, 02:06:48 PM
Some good info for you is on this link.
http://www.4wheeloffroad.com/techarticles/suspension/131_0307_four_link_suspension_part_2/index.html
I also highly recommend looking at the Pirate4x4 FAQ for Toyotas for good info. I did not use a link calculator. I really just followed the guidelines in the link above.
slower
never once have i ever wanted to see the reduce speed ahead sign so bad
4XFlyin
Quote from: Yota87Truck on January 03, 2010, 06:10:02 PM
WOW, nice work!
Quote from: slower on January 03, 2010, 06:39:19 PM
that truck is sick man nice fab work!
Thanks... I just finished up the complete exhaust today. Had to start all the way in the front with a "Y" pipe. I finished late, so I will post up pictures on Wednesday.
TacoRunner
www.4WHEELUNDERGROUND.com
[email protected]
axled89
RokCrawlinToy
Quote from: 4X Flyin on January 03, 2010, 07:40:23 PM
It's Wednesday, where are the pics????:snapshot:
4XFlyin
Pics as promised.
I bought a universal exhaust kit from Jegs. It is 2.25" along with a Magnaflow muffler. This was my first attept at doing an exhaust. I was going to have my exhaust guy do it, but he wanted $700.00 to do a "Y" pipe and exhaust from scratch.
4XFlyin
#203
Welded up the recovery points for Jeeps  :greengrin:  Sorry Rugged Jeep
TacoRunner
[email protected]
Yota4life
wow this looks like a sick buildup. Nice work!
pumkin toy
97 4runner Limited
4XFlyin
Quote from: Yota4life on January 06, 2010, 02:23:50 PM
Quote from: pumkin toy on January 06, 2010, 04:58:50 PM
exhaust turned out good
Thanks... Little by little it's coming along.
minicrawlin
This thing is an inspiration to everyone i think.  :thumbs:  You do beautiful work man! Keep it up i'm excited to see it done!!
the rocks Rock in South D SON!
motormouth559
threads like this keep me up late at night,
and my girlfriend pissed at me :)
