4xFlyin build1982 1st Gen.. Dual Diaphram Booster
Started by 4XFlyin, October 11, 2008, 03:29:36 PM
4XFlyin
#150
Quote from: TacoRunner on September 03, 2009, 05:50:43 PM
You can also us an 85' rear too. 86' is when they changed it. let me know if you need help this weekend, I'll be there.
Thanks for the offer. I will let you know. I am hell bent on making it to MCR8 so I decided to weld the cracks on the axle. Failure is not an option.
82 1st Gen with 4.3L vortec and 4l60e. Linked front and rear
My build up. Getting linked
http://board.marlincrawler.com/index.php?topic=50700.msg711361#msg711361
4XFlyin
My goal was to have the rear links done by Thursday night so I could measure for drive shaft lengths. By 11:30 pm I was done. Long day. What is cool about the link set up is that there is only 1" of difference in drive shaft length from full compression to full droop. Friday morning I am headed to to Coast Driveshafts and hopefully I will get them back by the end of the day.
Jud
"bout tree fiddy"
hilux-1983
Quote from: 4X Flyin on September 04, 2009, 12:04:31 AM
Yup, yup, you go boy!!!!!!!!!!!
pumkin toy
97 4runner Limited
xyzalvarez
i really enjoyed looking at you fabrication..
keep the good work on!
GJToyotabug
4XFlyin
Made some outrigger plates for the rear main hoop.
4XFlyin
4XFlyin
4XFlyin
4XFlyin
Working late into the night to get it done. Neighbors must love me.
:phone: Hello Police.. My neighbor is making a lot of noise next door. There is alot of banging, grinding, sparks going everywhere and the night is lit up from welding flash. Can you please come over and shut this guy down?
4XFlyin
I did not get the truck done in time for MCR8 unfortunately. Here is the latest.
Installed Sky's rear disk brake kit. I just plasma cut the backing plate off as I really did not feel like pressing the bearing off. It was way simpler than I thought it would be.
When insatlling the caliper brackets I would recommend using some locktite on the threads as the hardware they give you is bearly long enough for the nylock to engage on the threads. Overall a nice kit.
4XFlyin
This is were my rear cage work stands for now. I got enough done to give it a basic set up. I will add more tubing later to include a spare tire holder and more bracing.
4XFlyin
The coilovers are on and the truck is sitting on rear tires.
4XFlyin
Jud
Bummer you didn't beat the punch. Toobing looks sweet though. Hopefully we'll see you there next year or maybe sometime sooner.
"bout tree fiddy"
4XFlyin
Quote from: Jud on September 14, 2009, 11:11:11 PM
Thanks.. I really tried, but there was so much to do. It is coming together though.
CrazyYota
TIMS89CRAWLER
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
RokCrawlinToy
HEY!!!  :whip: Get back to working on this thing! Since you were  :gay: and didn't get it done by Roundup.
4XFlyin
Made a tray to hold tool box and other stuff. Used some 3x4x3/8 angle iron to attach perforated grid. The angle iron will also be used to support a center bump stop.
4XFlyin
4XFlyin
Cut up some 3/16 plate to make tail light brackets. LED's
4XFlyin
4XFlyin
Wilwood proportioning valve for rear disc breaks
4Runtoy
TIMS89CRAWLER
that is seriously just badass work there! this thing is coming out all kinds of sick man! keep up the good clean work! :biggthumpup:
www.choptechfab.com
CHECK THE BUILD
illinoisyotadriver
man that there  is some serious work right there
86toyota
Quote from: 4X Flyin on April 19, 2009, 02:45:28 PM
Painted the front links and front axle. I was going to clear coat the front links, but just went for flat black. Much easier to touch up.
on the bottom pic did you have a problem with that housing warping on you at all, or did you even check that?
T86OTA
