4xFlyin build1982 1st Gen.. Dual Diaphram Booster
Started by 4XFlyin, October 11, 2008, 03:29:36 PM
4XFlyin
I picked up a Dual Diaphram off of a Turbo MR2. The bolt pattern to the fire wall did not match up. I looked at drilling new holes on the fire wall, but that had issues. I decided to cut out the back off my original booster and weld it to the MR2 booster. I cut off the studs on the MR2 booster to make it flush. I also took apart the MR2 booster for the weld process. After all the fabbing it was a liitle bit of a issue getting the backing plate back on as it has to be slightly pressed so the that the tabs can be punched in that hold it together. In the end it bolted right up and works nice. I did have to extend the rod so that I could attach it to the brake, but that was easy.
82 1st Gen with 4.3L vortec and 4l60e. Linked front and rear
My build up. Getting linked
http://board.marlincrawler.com/index.php?topic=50700.msg711361#msg711361
