Juds One Ton Single Cab
Started by Jud, July 29, 2008, 10:28:19 PM
0 Members and 12 Guests are viewing this topic.
Blingn
i got a seat Jud going in thursday let me know
Jud
Quote from: Blingn on August 26, 2010, 10:16:59 AM
I'm pretty sure I can't go until Friday evening if I make it even riding with somebody. I will deff keep it in mind though!
"bout tree fiddy"
Jud
Here's some pics of the motor mounts. I moved the motor up a little for more clearance for when I eventually link it. They're just my old RockStomper mounts welded to the stock motor mount brackets then some 1.75x.120 tubing left over from my cage and some random angle iron I had in my bucket of fun. I love not paying anything while building new stuff...
Drivers Side
Passenger Side
I noticed my frame was tweaking a little right on this bend so I laid some 1.5"x1/4" flat steel down and weldedit to the frame to dispurse some force away from the center of the bend.
Probably gonna leave the intake here, I may move the evap canister and raise the intake a little higher.
I cut the cage off, welded all the back sides of the joints, painted it black and welded it back on. I like it alot better black...
Now I'm REALLY debating on narrowing the front end when I start bending tube or keeping it the full width of the stock hood.
"bout tree fiddy"
might as well jsut dovenose it now.... you know you will want to later......
Jud
Quote from: jimbo74 on August 31, 2010, 10:29:02 PM
Yea but everybody and their brothers dovenose everything these days. Maybe I'll make it narrower that stock but still not fully pinched...
"bout tree fiddy"
<MIKE>
Quote from: Jud on August 31, 2010, 10:30:06 PM
x2 i think just a "mild Dove"  would look dope.
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
Doof
shits looking pretty good. glad to hear you dialed in the cage finally.... pinch it and call it a day, like what jimbo said. you will end up doing down the road when your not happy with the half pinch. do it right the first time and dont look back
Jud
Well having no money means SLOW progress.
I built a battery tray the other day and finally used some old garage door opener chain track T iron I've had around forever to build a radiator mount. I also got a lot of the wiring re taped up and the AFM wire extended.
Here's a few pics of the battery tray, I used some angle iron I had laying around. I know a ratchet strap tiedown is "ghetto" but the way I've got it setup it's legit.
"bout tree fiddy"
Jud
Got a new job today, start Thursday.
Hopefully there will be steady updates soon...
"bout tree fiddy"
snowshoebrue
sweet, what you gonna be doing?
Jud
Quote from: snowshoebrue on September 22, 2010, 05:17:00 AM
Lube Tech/Shop pregnant dog at Walkers Automotive in Modesto.
"bout tree fiddy"
brockbuilt85
bout time you got back to work slacker :gap:
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
gnarrkill
Quote from: Jud on September 22, 2010, 02:51:40 PM
we have the same job hah you will be suprised the places they put oil filters now days
79 toyota duals,caged,40 mtrs
the build thread i dont update
http://board.marlincrawler.com/index.php?topic=65367.0
Steve_925
ratchet straps are for real men
UA 342
STEAMFITTERS
Jud
Quote from: brockbuilt85 on September 22, 2010, 05:25:02 PM
Yea I know finally, I've been laying soooo low lately
Quote from: gnarrkill on September 22, 2010, 05:27:50 PM
we have the same job hah you will be surprised the places they put oil filters now days
This isn't my first ball game... Some manufacturers are stupid as :pokinit:.
Quote from: Steve_925 on September 22, 2010, 05:49:13 PM
touche
"bout tree fiddy"
gnarrkill
totally agree bro. also air filter placements. i work for a gm dealership. and its stupid on what some of the designers do now.
-Jake-
my wife has to take the oil filter off her Lexus IS.  I can't get my arm down in the tiny hole.  I think they designed it for tiny asians or something  :laugh:
brockbuilt85
Turd Box Build:
P-DiseToy24
How many feet of tubing do you think your used?  and that's 1 3/4 right?
Jud
Quote from: P-DiseToy24 on September 23, 2010, 10:37:54 AM
On my Cage?
I used just shy of 4 sticks with enough left over to build a fender hoop for my trailer and have a few couple foot pieces laying around.
"bout tree fiddy"
Jud
Pulled it off the trailer and back into the yard yesterday. I got some new (used) 14" ProComp ES3000's from a buddy for the rear, I'm hoping they wont limit droop but we will see. I finally got a EQ (ARC Audio XEQ) for my stereo, I've been running my ipod straight into my amps but you can only get so much out of that because of the ipod having close to 0 output power. That also cleaned up alot of stereo wiring, I use to have to run five RCA Y's to make up all 6 channels. Now I have 2 channels going into the EQ then the 6 channels coming out of that. I also upgraded from my entry level JL RCA's to JL Marine RCA's, they should hold up to weather alot better (even though I've never had a problem with it)
I also put my half doors on it and started to pinch the front fenders in. I'm going to cut the hood probably tomarrow.
"bout tree fiddy"
P-DiseToy24
front end is gunna look tight. You still gunna keep the tube on the inside of the fenders?
Jud
Quote from: P-DiseToy24 on October 11, 2010, 11:22:48 AM
No tube yet, I don't have a bender and it will be a while before I can buy one. I moved back to Modesto from Chico a while ago and I have no buddies down here with benders, super wack.
"bout tree fiddy"
Jud
Got a little further on it today. The headlight mounts are temporary until I get a bender and tube. I ended up self tapping my fender to my hood and cut the fenders in half right about at the fire wall.
"bout tree fiddy"
P-DiseToy24
haha thats sweet with the fenders conected to the hood... lol looks crazy
brockbuilt85
the front end kinda reminds me of a willys
Turd Box Build:
bigarms23
i like the look are you going to run a fj crusier grill
locked 4x4
Is that the stock radiator?  it looks tall for some reason
Jud
Quote from: locked 4x4 on October 16, 2010, 11:41:00 PM
Yeap it's the stop radiator. I really wanna get a side tank radiator for it, Never had a overheating problem, I just like the idea that if the coolant gets low it'll still flow through the fins.
"bout tree fiddy"
toyotanner
is that some crazy bird feeder on the top of your truck?
