[Project Reeda]yup. engines out
Started by NorCalToy, June 22, 2008, 01:50:16 PM
KDXSR5
cranking t-bars is how you do a ghetto/free lift on an IFS rig
If you plan on keeping it somewhat stock for a while, I believe you can use some OME (Old Man Emu) Landcruiser springs to get a pretty good boost in rear hieght and it also addas a bit of firmness. Last time I saw this mod was on I believe yotatech or whatever it is called. Reasearch it a little bit and see what you find.
That rear coil lift and cranking the front t-bars will give you some added height to run larger tires. Ask rocksurfer or maybe jimbo (I know, I know) about how to make IFS work off road. Especially rocksurfer.
NorCalToy
Quote from: KDXSR5 on June 23, 2008, 01:49:02 PM
yea i know you CAN crank the tbarsi just dont know how to do it...
if i didnt think i was on jimbo's ignore  list id ask him, but he hates me so...yea.i may PM rocksurfer, not a bad idea.
i need to do some reasearch and question, you think i can stuff 33's w/out lift? it looks badass, but idk how much lift they had...
:flamer: IFS
KDXSR5
scratch the landcruiser stuff... that is for newer 4runners
Crank t-bars and OME rear coils should make it tall enough to fit 33x10.50s. From what I have read, 33x12.50s require a lot more work to make fit on the 4runners.
NorCalToy
what about 34x9.50's?
jk. ok gotta link as how to go about cranking the tbar?
:flamer: IFS
NorCalToy
damnit todd, alright, i guess ill search, but its kinda pointless to be a able to fit bigger tires if you lose all/most of your uptravel...
:flamer: IFS
KDXSR5
NCT :headshake: you don't lose very much if you don't crank them all the way... it is IFS, you can't screw it up much more than it already is
here are some t-bar crank/adjustment links
http://www.off-road.com/trucks4x4/article/articleDetail.jsp?id=398514
http://www.4x4wire.com/toyota/tech/torsion_bars/
I do not believe you need to upgrade t-bars, but it is your money. I hope these links help.
NorCalToy
thanks buddy :gap: ill check em out in a few minutes, i waas just googling about em, and read an article where some DBAG said "One final note: Do not drive one uninsured in the winter. The 4Runner is a stable vehicle, but if it slips on ice, there's a good chance that it will roll. Mine protected me fairly well in my rollover, especially with the Smittybilt bumper. "
:flamer: IFS
KDXSR5
here is a little something on helping travel with cranked t-bars: http://home.4x4wire.com/joe/tech/shock/
KDXSR5
Read this, it is about fitting 33s on a 3rd gen truck with minimal lift, all the ifs stuff should still apply to you (there is not a whole lot of info for you, but an interesting read): http://www.brian894x4.com/33INCHTIRES.html
KDXSR5
This whole site has a lot of cool info, not necessarily all helpful to you, but lots of neat stuff none the less: http://www.brian894x4.com/
NorCalToy
yup, i mid-read right now. :thumbs: i think ive stumbled across it before, some of the stuff the dude says is a little off, but mostly its all pretty true.
:flamer: IFS
and i wouldnt stuff 33s on a cranked 4runner... youll loose alot of turning radius and it will ruin your fenders when you "flex" it out or wheel with it..... TRUST ME.
KDXSR5
33x10.50 should be ok though, at least I think so
Quote from: KDXSR5 on June 23, 2008, 03:00:34 PM
should be yes... crank the tbars all the way, get some uniballs or megaballs, and get some stiffer rear coils maybe spacers too or go 63s in rear.
uniballs/megaballs are replacements of the stock ball-joints and have a HELL of alot more travel in them, allowing them to travel more up and down.... without binding and breaking or over stressing them. I can get you alot of info from my buddy Kyle who lives in So-Cal and did this on his 86 reg cab. he prerunned that bad boy and did everything he could to the stock setup to make it work the best it could with 2.0 Fox Coilovers.
NorCalToy
get it if you can please HO, it would be appreciated,
and as you can see, i cleaned up the thread a lot.
:flamer: IFS
NorCalToy
so what about rear lift coils, could i find longer coils with the same diameter and bolt them up to acheive some lift in the rear? or is it kind of a nono to mix coils like that?
:flamer: IFS
94runner
you should just get the complete OME lift. its got new shocks, BJ spacers (so you dont crank your t-bars), HD rear coils and shocks for the back. that'll fit 32x11.5's perfectly and if you crank the t-bars a little more you can fit 33x12.5
1994 4runner: toy axles, 37's, armor,
Phazertwo
Quote from: NorCalToy on June 23, 2008, 04:51:24 PM
Coils don't have a bolt pattern... they are usually clamped in, or welded in...  Cut the coil crap out, and run some Chevys, or stock 3rd gen leaves in the rear. Get a add-a-leaf, or some small blocks, crank the t-bars. Throw on some 33's and a locker in the rear, and enjoy/wheel the piss outa it.  I ran my truck bone stock with a locker and a bobed bed. NEVER let me down.
PZ
edit:  I also had sliders.  Saved me from ALOT of body damage!
92 xtra cab, with some stuff...
Quote from: yotabj on October 30, 2006, 10:01:02 AM...why buy when you can build?
#48
Quote from: NorCalToy on June 23, 2008, 03:11:42 PM
add this guy and talk to him.
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=14232241
he will be able to help you out TREMINDOUSLY!
and id stay away from coil lifting the rear more then 1.5 inchs from stock, with the stock links and panhard, without redoing the setup, as it will reduce travel a lot and put unwanted strain on the setup.
id go with a stock 3rd gen leaf setup with some blocks and shackles or 63s.
as for the front to match either setup, crank the front 1-2in and get 1.5 bj spacers. that should get you 3inch front and back. you want a little more lift in back for the extra weight and for towing.
Prismo
Quote from: NorCalToy on June 23, 2008, 01:35:34 PM
or i could just get a pickup rear axle and save the trouble of grinding all the :pokinit: off and putting new :pokinit: on, i just need to find an IFS truck housing and the nill be good to go, or better yet a complete axle RTR, and then someple simple welding and ill be money. plus then i could weld up the truck axle and have a spare 3rd member, since the 4 pin V6 3rds are a pregnant dog to weld anyways...
and whats the deal on cranking the T-Bars?
You are better off finding a leaf sprung housing, the 4runner rear housing looks like a Christmas tree with all the brackets on it.
You can crank the torsion bars on the front to raise it. It will give you quite a bit harsher ride the more you crank them.
Here is the method http://www.4x4wire.com/toyota/tech/torsion_bars/
I am too slow someone else posted it already
Quote from: Prismo on June 23, 2008, 06:21:01 PM
I totally agree.
NorCalToy
Quote from: that HO kid on June 23, 2008, 06:25:16 PM
I totally agree.
yup tha
Quote from: Phazertwo on June 23, 2008, 05:27:19 PM
lts the plan sometime here pretty quick, depends on how the money situation is after the motor swap, of fixing the engine. then once i can get a buildup of cash goin again, ill look into doin it.
PZ
what i meant was getting a new set of coils from something else, and the n be ing able to fit them into where the stock coils were, not that they had a bolt pattern to them or anything. :thumbs:
thanks for the posts, ill review them and do some research on different ideas suggested, im looking for as cheap of lift as possible (still safe though) that i can run for a while until i can get the cash for an SAS.
:flamer: IFS
NorCalToy
ok, that came out seriously gay. its really complicated to fix, but you can pretty much tell what i wrote in there. :thumbs:
:flamer: IFS
NorCalToy
and also tonight istarted building a spare tire carrier. its going to to mount into the 2" reciever hitch and sit right behind the tailgate, i should have it finished tomorrow and then painted after that.
:flamer: IFS
KDXSR5
first, before modding it anymore, you need to fix the engine problem
KDXSR5
I gotta see this spare tire carrier... posts lots of pics
NorCalToy
Quote from: KDXSR5 on June 23, 2008, 08:38:02 PM
meanin what? you wanna see it? or you have no faith in my fab skills?
:flamer: IFS
Phazertwo
X2 on fixing the engine.
Looks like for just over $100 you can snag the right stuff to hang the pickup springs from your runner.
However, the 63"ers are a better idea IMO, since you can use them to match your SAS later, and they will flex to keep up with the bad ass aftermarket springs that are out there now.
PZ
NorCalToy
Quote from: Phazertwo on June 23, 2008, 08:43:12 PM
PZ
yea yea, im not spendin money on anything else, the tire carrier is built out of scrap i collected at my house. :thumbs:
:flamer: IFS
KDXSR5
Quote from: NorCalToy on June 23, 2008, 08:42:46 PM
I wanna see what you came up with! Do you think I am a doubting kind of person? :gap:
