My baby gets Lexus filters imported from Japan and of course Toyota brand oil
I believe White Trash hates Pennzoil and I stayed away for a long time until I joined BITOG forum and saw actual test results.
I hate pennzoil after tearing down engines years ago. I can't say anything about the current furmulation but just the facts I saw years ago has kept me from running it today. Honestly I can't see the point in most of the arguments. Just run a known oil and change the filter often. As long as you don't scorch the oil it'll be fine, the cheap filters will clog up quickly though so they need to be changed more. Years ago my grandpa ran synthetic in a brand new buick. He changed the filter and added a quart every 15k miles. Car was still ticking at 300k so appearantly it was a good idea...
[size=8]FRAM OIL FILTERS SUCK DONKEY NUTS![/size]
the fl1a ford fitler that i use is huge.... i beleive it is the same one rocksurfer is running in size.....frams comparative part number is the ph8a, and it is the same size as what most ford trucks and mustangs run, my explorers run them too....
Valvoline Durablend 5-30 and my filter is a Valvoline V01. It's not the correct filter by the book but it is bigger than the stock by maybe 2 1/2 times and it has the same thread, ports and seal. Made for old International trucks.
Currently I run valvoline max-life semi-synthetic 10w-30 with a NAPA Gold (Wix) filter... engine is an 88 with around 200,000-ish... still runs strong from idle to 6000 without making a tick or knock. I change the oil every 3 months regardless of milage. I put about 4000 miles on this truck a year.I have ran the stock sized filter since the first change and have never had a problem. I have tried larger capacity filters such as the ford one, and all it did was cause my oil pressure to raise slower, other than that, I did not see a gain at all.The rebuilt engine I am dropping in (the original 85 engine) is getting broken in on Rotella-T for first 100 miles using NAPA Gold (Wix) filter, then I am going to switch over to Valvoline Synthetic 10w-30 for the rest of the motor's life along with NAPA Gold (Wix) filters.
Yeah that is the Fram # but I wouldn't use a Fram even if you paid me to, even if I were a distributor.
for mine i use 10-40 castrol and i use k&n oil filters
How much more capacity will this yield with the bigger filter?
Started by yo Engine
Started by twistedtoy92 « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by Hilux92 Engine
Started by RossGo « 1 2 3 4 » General 4WD Discussion
Started by bamajojo9 Project Research and Build-Ups
