IC's linked 88 on fodees Saturn 1.9l engine swap
Started by IronClad, December 06, 2007, 10:22:44 AM
Dingman.
Yea i dont know,  i was wanting to just run all 8 lug stuff, 5.38's, and some kind of locker.
Shoot me a price anyway once you figure it out, it would all prob be worth more to someone wanting to keep 6 lug.
IronClad
Im probably going to be asking 1700 or so for the front since you could essentially bolt it into a toyota with a cross member change and run it.  Has a HAD toy flange .250 wall tierod and a .188 wall draglink all with 3/4" hiems and setup to be under a toyota and probably 400 for the rear
Annihilation  Fabrication
Do you need a Hammer?
IronClad
Copy and paste from my for sale add to also get it here aswell.
Ok guys here goes. Everything is still in the truck and i havent pulled a single part so if you want to buy somthing you'll have to give me a min or you can come and pull it. Prices are very firm and not interested in any sort of trade unless you have a Drift boat that is at minimum 16foot by 48" wide. Cash in hand first come first serve basis.
Chevy 60 front, 5.13 gears, welded, crossover arm, 2" .250 wall tierod with 3/4" hiems, 1 1/4 .188 wall draglink, 6 lug wheel hubs and 1/2ton chevy brakes, HAD 60 to toyota flange. Also has a 2x8 ram and hoses, SS braided brake lines with toyota adapters. $1800 This thing is basically ready to bolt into a toyota with a fullwidth crossmember, Add oil and go. Also have an Artec 60 truss id throw in for another $100 bucks, the truss has been sitting in my hallway in the box for the past year and a half
Chevy FF14b, 5.13 gears, welded, 6lug conversion and 1/2ton chevy disk brakes. Setup for 4 link and coils, 1350 Ubolt yoke. $400
89 TBI 350, wiring harness cut down to bare bones, New distributor, Comes with ECU and ALDL plug ( not connected to harness) and a set of non carb approved block hugger
headers $400
TH350 4wd K Case. Works great no slip or anything $300 have a very nice B&M cable shifter that can go with too for another $100
AA TH350 to Toyota tcase adapter, 21 spline, Basically brand new. Id venture not even 15 miles on it. Truck was built and ran around a couple times on the street and in the dirt then parked. $350
Dual toyota cases 21spline, stock gears, MC07 adapter $500
Everything located in Oroville CA, 95966. Will not ship, PM me and we'll go from there
