unclejs revamp (playing DR )
Started by unclejpl4x4, November 18, 2007, 08:38:20 AM
whats the specs of the cam joe
i need to know  lift,  duration  and  *
should have sent you a spec sheet
topar
unclejpl4x4
Quote from: 79coyotefrg on February 14, 2008, 07:08:21 PM
its in my sig
enginbiulder cam 268c/torker    .425 looks like
thats a  wimpy cam,  whats it doing ??
unclejpl4x4
OK so i have been pondering what 2 do with the gauges i got and had a idea
what you guys think
not line of sight   but i can lean over and see them
unclejpl4x4
I knew i would have 2 replace this hose sooner or later  (  :psss: power steering hose gose 2 cooler )
well sooner is here    any one know the size/diamiter
I don't wana down the truck  bad weather coming/and or  i might have 2 go out.
Quote from: unclejpl4x4 on February 20, 2008, 10:05:14 AM
what you guys think
a pillar pods  :yesnod:
unclejpl4x4
ya but thats more $$ + i don't want a tube runing in my a arm  there mech gauges
unclejpl4x4
mech gauges / tube
first pic
second pic A-piller
yes i do... but thats why you hide the lines and wires BEHIND the a-pod thingy..... you wont see it.
unclejpl4x4
ok worked on the back brakes sunday.
Been having ajusting problems/p-brake.
The lever for the right side P-brake arm was packed with dirt  from mud puddles i recon   took me 30mins 2 get that drum off  :_order:  and kinda chiped the pad  :hammerhead: The left side came off like in 2mins
Cleaned them sanded the pads alittle    the pads are worn funny  from rust/mudd bight in there but have plenty of meat   I still got 2 ajust them more  I can still spin the tires with the p-brake on
unclejpl4x4
#134
O and for my noise   im starting 2 get worried.
This only lasts for a 20secs-min  when starting cold   + the cold Idle is high  I forget how 2 ajust that. <--help
1. maybe the ajuster for the Tchain   and the chain is slaping on the metal giude till it works right
2. 1or 2 rockets are not geting oil for a few secs
3. pistion rod/crank  not geting oil for a few secs
well got plenty of oil pressure 83 PSI at cold Idle  :yikes:
and of couse its 43 out side so no knock  :eek:    i got about 200 miles on this oil  im gont let it warm up and idle down  then change it
you did clean all the oiling holes in the head and block with a  bore brush right ?
you are running a 10w40  right
unclejpl4x4
the head/block was machine shop cleaned.
and yes 10/30 moible syth
ok on start-up it jumps 2 90pis then comes down 2 70    but jumps @ over 100  on throttle-up
maybe the guage is air bubbled
trucks running atm warming up
what brand of oil pressure guage ??
i use a sunpro from autozone
my truck has always  had 80 psi  at start up  but comes down after its warm
unclejpl4x4
snap-on guages
it came down 2 40 at idle but is still getting up 2 90 at rpms
and now i got a anti-freeze leak from a spring clamp on the throttlebody  :thud:  what a monday    got run 2 the store and grab a hose clamp  :down:
I think im gona call them in a bit  then maybe slap on this oil pump from my master engingbiulder kit
unclejpl4x4
OK oil pressure problem fixed  :crazy:    Replaced the LC pro oil pump    with the one from the enginebiulders mater kit  :eyebrow:
cold idle 60 psi
warm temp  40 psi idle    65 psi at 3000+ rpms  ( same as the LC pro ad4tized )
change the oil
mounted the oil P guage i have
Now I talk 2 tech at LC  :phone:     took the LC pump apart  I see  :dunno:  it has 2 go back 2 them for a new one or credit.  :crossed:
Got check the truck 2 marrow  and see if it still knocks  I think it will  :dunno:
Redbeard1
glad you got it figured out :thumbs: lookin good
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
unclejpl4x4
OK so this knock is driving me crazy
So i decided 2 pull the valve cover and check on t-chain slapisum   ( never had a metal wear pad before)
This is at 1pm sunny out
( moter off) so i take the cover off  and use a screw driver 2 check the long side of the chain theres a lot of defletion more then what i think there should be.
Now its 8pm and dark.
( coil unhooked)  I had my buddy crank the moter over  2 watch the tensioner it moved a little but not as much as the slack i had.
(so I tell him started/turn it right off oils gonna go flying)  well i did not get 2 see the tensioner  I don't believe the amount of oil that came off the front of the cam was crazy oil was on my face all over my hood/engine    ground next 2 the truck and my moms car 8 feet away.
I put the cover back on  im heading over 2 the car wash ATM :headshake:
Redbeard1
RIP Bobby Long
unclejpl4x4
trying 2 take the bed off 2 fix the rust problem..................... but i can't get the dam bolts outs iv been at it for hrs im ready 2 say f it
unclejpl4x4
Ok heres a update phase 1 is not done but since i got no yob i got get it done befor i get one.
So im starting on the rear frame.
I pulled the bed off sat/sunday   some bolts where cut off some cam out  :_order:
unclejpl4x4
the bed has a nice home for the meantime   got rust there 2 i got fix.
truck looks so cool i almost don't wana put the bed back on.
unclejpl4x4
ya i got take off the class 3  and exaust end.  i got a alot 2 clean up.   the rest of the frame seams solid so im gona forgo plateing.
