unclejs revamp (playing DR )
Started by unclejpl4x4, November 18, 2007, 08:38:20 AM
unclejpl4x4
#330
I found out that the guy was using the wrong tool and im not the only one who got screwed on head work. and im still buring oil i got get my leakdown tester from work and stop being lazy and make sure the valve seals are good.
update: i passed inspection a week ago.  Also rechecked the head bolts Click click :)
I pulled out the O2 sensor black as sin  cleaned it / pulled the EFI fuse. going on a long sunday drive in a bit.
also i found out what i wanna do for the intake http://www.yotatech.com/f88/pics-swapping-battery-airbox-148248/
Keep the stock air filter set up run pipe threw the fender then out the anntnI hole up the a-piller.
BUt i was also thinking on a supra 5m air box swap i got more reading to do so if anyone has done this or has a spare :)
KDXSR5
I did the air box relocation, but I never finished it with going into the fender. I just got burnt out and moved on to other things. I am sure you saw it in my thread like last year, I think you made comment on it.
ive got that v6 airbox that came in that red 4runner
So is the engine shop going to make it right and fix it, as well as paying for all your gaskets, etc?
unclejpl4x4
Quote from: kneedownnate on October 11, 2009, 01:59:19 PM
never thot about really his shop is way out of my way and ts not even worth the fustration it is what it is.
we took the truck out for a 3hr tour  did some highway 5th gear 60mph 20miles stop at wallmart no smell, then went exploring  down this little atv trail  nice little spot side burms constant tree branch smackged ( note to self maybe i should not paint the truck)   follow it all the way ti this nice hill open area, turned around found another atv trail took that 2 a river  then  headed home. wass mostly in 4L/first just above idle  I did not smell that bad fuel fumes tilll i drop off my buddy but it was barely noticeable.
Usually after drive half way 2 work i can smell it. So i say cleaning the O2 sensor was a 90% improvement.
unclejpl4x4
e-bay parts shows up  now if i can find the time to do it.
elbow
tube
brockbuilt85
you can buy the parts for an airflow box reduction on ebay? interesting!
is it like a kit or justa cut to fit yourself thing?
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
unclejpl4x4
brockbuilt85
i shall be watching your progress from now on sir, and make a desicion on wether or not im gonna do that based upon your progress. lol
:eye: :eye:
Turd Box Build:
unclejpl4x4
ya i wanna start on this but it's gonna rain all weekend.
illinoisyotadriver
unclejpl4x4
#341
well it's a nice day out and i got time to play DR with the truck    stilll running crappy and using a qrt of oil a week :thud:
doing comp and leak down test today   adjust valves, check head torque,  change oil , clean plugs
So far
                             #1                      #2                         #3                             #4
comp test                185                      180                       185                             178
O tummy says lunch time and my aunt/ cousins wife stoped by  shes been in cali for 18months  lol shes ready to come back to the east side something about darn hipppies
those are damn good numbers
i wonder if they even bothered to put new valve stem seals in that head
unclejpl4x4
#343
well i opened 1 valve at a time and pressurized the cly i did not see or hear and air from around the springs.  i think my motor sucks so good  it's pulling oil out of the valve cover :dunno:
I rig up a vent and blocked off the ports on the TB and intake gonna see what happens ill take a pic in the day time tomarrow.
unclejpl4x4
well heres the bypass i did late the other night it's not pretty but its a expariment
o NOTE: on the way home i hade the windown open my :eye:s where burning a little i could smell something and ran a little crapy    but in the morning it ran great.   im starting to wonder the truck just hates me and loves to f with me.   I think for a experiment im gona start blocking off crap/removing
BUBBA
yea i would think it doesn't like you
My budget beater
Elton
looks good sure hope your still not using them garbage fram filters
*** YELLER ***
except BACON
unclejpl4x4
ya i moved it to the far pass side case the fumes where killing me  but on a good note the truck has been runing better  O and i have been noticing a cloud of smoke if i put the brick on the skinny pedle  stilll using a quart a week
unclejpl4x4
a little update    i had no heat  stupid thermostat failed open  only been in ther for 3 months  pos advance auto parts. got a new one from napa.
I have heat  :)  trucks been running cold / not at normal temps for a while now.............
I still have not found a drill bit yet so i can tap the sender hole on the thermo housing  ill get to that in a week or 2 .
but right now i need help on gauges  i have a bunch of gauges  but was thinking of just installing the oil-P and W-temp in the center vents got the idea from summit mustang pages.
crapy night pic i got get a day one zoomed out.
Dr.Maxwe001
Joe  if that is where its gona stay forever then thats fine but just remember  when its there its there If i were you and you still have the space I would mount them down low where the sunglasses holder is that way they will not get in the way of a drink in the cup holder. that is simply the easy way to run them down low out of the way easy to wire them in behind the dash and they are easy to glance at when you need to just my  :twocents:
[img]http://bo
Dr.Maxwe001
Joe here is a picture of the ones in my truck again keep in mind this is in MY 93 truck
:turtle: :turtle: :turtle:
[img]http://bo
unclejpl4x4
I also forgot  i have not used the center vent in 4yrs i always use defrost/feet  i can't stand heat/cold blowing on me.    I got some info from some people on this matter   and i thank all for there input.
unclejpl4x4
 :beerchug: got my 45$ cold air kit from e-bay the same one PAtaco got  I like it  and i did notice better throttle responce.
Only down side is the AFM is out in lala land so i started  on making a bracket wich is not done.  Also got my gauges finished I like them now i just got finger out why there not lighting up at night.
O and my new head came from engibiulders streetrv, 268 T cam and re-ring kit.
PA_taco_13
learn the hard way
"my dixie wrecked"
east coast crawler
Redbeard1
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
Redbeard1
unc I was looking back to all the frame repair you have been doing and I have a frame that is all ready cut tp and I could send you that section of the frame rails if you want them so you can fix it right. PM me if you want them i need to make room in the garage.
RIP Bobby Long
unclejpl4x4
 :beerchug:using Wii sucks load longer then ddial up/   motor is apart pistons out i got find a good hone tomarro and i got some cleaning 2 do/ well alot relly
