The Eighty-Sixed Runner
Started by Doof, September 27, 2007, 08:22:00 PM
0 Members and 19 Guests are viewing this topic.
whats the next step
keep the runner
2nd gen extra cab/first gen bed
Doof
Quote from: Duffil on March 02, 2008, 08:04:10 PM
have you guys tried tieing the LSPV arm all the way up and see if it changes what you get at the cylinders?
no i dont think so. ill do that also and see what it does
Quote from: tom w. on March 02, 2008, 08:09:02 PM
What about front brakes? I don't think my rear pads even touch the drum, but I can still stop in a jiffy.
fronts are clean and shooting clear fluid like its coming out of the bottle. im stumped but hopefully the morning brings good news for my breaks
lilbuddy
Quote from: sillywilly on March 02, 2008, 09:53:08 PM
Oh i totally forgot about that... I forgot you cut yours off.
I will go to bet if you put up the arm all the way they will work great after being bled.
RIP Kyota.... you are the man
GET IT!!!
Doof
didnt you cut that off?
or matt did. i dont remember, but ill check it out
Duffil
that's probably your issue then.  when i swapped on my 1" MC the other day i had the arm down and couldn't bleed them until I tied the arm up.
mine is cut and with the stock MC i had to have it up, but I cut the strap before i tried to bleed.
Doof
thanks for the idea... hopefully it works :crossed:
lilbuddy
Quote from: sillywilly on March 02, 2008, 09:56:26 PM
No Im not like matt and just dont cut stuff off randomly..ususally without asking
GET IT!!!
Doof
lol, its on clowns shoulders then. i should go chop his off with out him knowing it
lilbuddy
Quote from: sillywilly on March 03, 2008, 08:36:15 AM
He already hacked it
GET IT!!!
DTB
you need to just get rid of that thing and get a prop valve from summit....cleans up your whole braking system to the rear and its safer
Doof
like i have that kind of money
Ramrod
its only $35  try getting your brakes power bled, i got mine done for free at a tire place and it helped alot
Doof
ill check out american tire and see if they can do it, or les schwab.
i ziptied my LSPV up and re bled the rear. didnt so :pokinit:. i didnt have time to blow the line out or swap it out with the one from the 88. that will be a weds project if i cant get my brakes power bled
ontherocks
Quote from: sillywilly on March 03, 2008, 08:16:10 PM
huh, mine is way down there and mine work. mine is zipped to my e-brake cable.
4.7 t-case, welded rear, 33s, sr5 buckits, sas sooner than later. http://board.marlincrawler.com/index.php?topic=74399.0
Doof
Quote from: ontherocks on March 05, 2008, 09:42:53 PM
dunno... and now i have the death wobble from hell. my whole runner was jerking around when i was cruising at 35 or so, but at highway speeds its pretty smooth. u bolts are all tight. im going to check my trunion(sp) bearings and see whats going on. also going to be swapping out the rear axles friday so i have 6 lugs holding on all 4 tires, also going to get to the bottom of my :pokinit: for nothing brakes, and prob get my half door design taped off
Quote from: sillywilly on March 05, 2008, 10:09:54 PM
hey i found out my booster is bad... you check yours?
Doof
nope... im over it. ill just deal with no brakes till a catastrophic failure happens
NorCalToy
damn. thats pretty gay. how are you stopping with no brakes? gears obvoiusly but like complete stops?
:flamer: IFS
Doof
there is so much air in my lines that it stops me, slowly... or one of my front brakes works... idk whats going on with the brakes. its time for a whole new brake system all around. disks in all 4 corners and no air in the lines
NorCalToy
thats the way to get some.
:flamer: IFS
ontherocks
coulda knocked off a tire weight, i had dw real bad and couldent figure it out til i put on scotts tires.
COToy91
this was a whilw ago but how did removing the overloads help out the flex
Doof
Quote from: ontherocks on March 07, 2008, 06:22:51 PM
i have BB's, no tire weights
Quote from: ColoradoToy91 on March 07, 2008, 06:42:34 PM
night and day better
46&2
Trunions may play a part in it but have you checked your steering arms to see if they are on there tight? also have you aligned it properly?? My tow was off and it gave me horrible death wobble around 20-35 mph, at highway speeds it was fine though. All it took was adjusting the tow and it completely went away.
Goose
Quote from: sillywilly on March 06, 2008, 09:12:58 PM
Thats the spirit!  :biggthumpup:
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
Doof
well here is the new shiz.... im in the process of mapping out my half doors, but im not quite sure where i want to cut the \____/ and how low to make it, and what not... ill use my paint and give some examples....
and for the brakes. i am in the process of getting rear disk, and i am also swapping out my rear axles so i have 6 bolts holding my tires on in the rear... but anyways, as soon as i get those set up i need to build my mounts for those for buy them, depends on the $, and also need to buy a bigger MC. but thats going down pretty right quick like
ill post the pics of my gutted doors and a design or two of what i have in mind
Goose
For my half doors, im gonna higher up than needed, then bend the outer door skin down to make the tops.
Itll be like one smooth fold from outside to the tops of them if it turns out right.
Then get a big sheet of semi-thin sheet metal and sheet the inside so its all smooth, weld it all and smooth out the kinks..
hard to explain, but... youll see..
www.slagfactory.com
My Buildups:
'90 ext. cab
'94 4Runner
NorCalToy
makes sense goose. only problem might be when you fold over for the top it is a curved piece of metal so it wont sit all the way flush and wont be as comfy to rest your arm on as a flat piece of metal will. just sumthin to think aobut.
:flamer: IFS
tom w.
Quote from: NorCalToy on March 10, 2008, 09:18:55 PM
That's not a problem. I did it like that with mine.
Goose
I was kinda thinking of carpeting the inside and possibly the tops too.. but idk..
Definitely gonna incorporate a cup holder into the top...
www.slagfactory.com
My Buildups:
'90 ext. cab
'94 4Runner
Doof
#1199
im gunna tac prob some 16 gauge sheet metal for the tops, then go out to my old work and tig it up for shits
ok so no paint pics of the design im shooting for...but here the pics...
parts runner
[spoiler]
[/spoiler]
doors
[spoiler]
[/spoiler]
go to post 12 for what im shooting for... but add a few twists of my own
http://board.marlincrawler.com/index.php?topic=43096.new#new
